Question about Tacx Motor Adapter for FORTIUS / COSMOS 220 Volt T1941.50
Tacx T1941.50 no power - Tacx Motor Adapter for FORTIUS / COSMOS 220 Volt T1941.50
Do you sell pasts for this trainer ie part number t1495.22
NOPE we sell nothing here on FIXYA . just give away advise when we know the answers
Mar 03, 2015 | Tacx Cycling
Tacx bushido display
It sounds like you already have battery problems. The unit functions until it exhausts what power it has and then blanks to reserve power for saved information. Contact the manufacturer.
Mar 11, 2017 | Tacx Bushido
Tacx flow set up
Where did you buy it? Why not just contact them and ask for assistance? Alternatively bring it into a bike shop or bike co-op and ask them for help.
May 14, 2017 | Tacx Flow
My back tire is skipping in the trainer and I have played with the tension but it's still sticking
Some tires do this, the smooth drum does not have a good grip for a standard road tire.
The solution is to replace your tire with a trainer specific tire. There are several companies that make them. My favorite is Continental but Vittoria and others offer models as well. These tires use a special rubber that grips the drum better and lasts far longer than a standard tire.
#1 - Continental Ultra sport (indoor)
#2 - Tacx indoor trainer tire
#3 - Vittoria Zaffiro indoor trainer tire.
NOTE: THESE TIRES SHOULD NOT BE RIDDEN OUTSIDE ON THE ROADS. They are a special compound for the trainers and do not have enough grip for going around corners on the road.
Dec 15, 2010 | Fluid Cycleops 2 Trainer
I have a specialised Allez road bike with quick release wheels, the side of the spindle with the release leaver on it won't fit into my Tacx sirius trainer. Any ideas?? Thanks Andy
If your rear skewer's unique lever design prevents it from being clamped you might want to seek out one of the garden-variety (boring) old-school skewers for use on the trainer. Plus, if it gets marred, no-biggie.
A visit to your Local Bike Shop might solve yoor problem.
Mar 09, 2010 | Magic Tacx I-magic Virtual Reality Gel...
Have the TACX fortius multiplayer. My kids do
go to the tacx forums
http://tacxforum.ilink.nl/index.php
Sep 28, 2009 | Magic Tacx I-magic Virtual Reality Gel...
Won't power on
The product uses a power cord, if the power supply is a power cord with electrical connections at each end. Figure 1: Power cord c00057913.jpgThe product uses a power module, if the power supply is a power cord connected to a power module. Figure 2: Power module c00745315.gif
  • If the product uses a power module (adapter), go to Step two: Check if power is supplied from the power module.
  • If the product uses only a power cord, go to Step three: Check if power is supplied from the power cord.If the product uses a power module (adapter), follow these steps to make sure that power is properly supplied to the product. Figure 3: Power module c00745315.gif
    1. Check the power module part number against the part number listed in the User’s Guide to make sure that the proper power module is being used.
    2. If the power module has a permanently attached power cord, do the following.
      1. Disconnect the power cord from the wall outlet.
      2. Disconnect the power cord from the product.
      3. Wait 30 seconds.
      4. Reconnect the power cord to the product and the wall outlet.
    3. If the power module has a detachable power cord, disconnect the power cord from the power module and reconnect the power cord to the power module.
    4. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
    5. If the product does not turn on, or the power light built into the power cord does not glow, plug the product into a wall outlet in another room.
      • If the product or power light turns on when connected to a wall outlet in another room, there is an issue with the power supply in the previous room.
      • If there is still no power to the product, then the power module, power cord, or product might be defective. Proceed to the next instruction.
    6. Connect the power module or power cord to another HP Deskjet or Photosmart product to see if the power module is functioning.
      • If the power light does not glow, the power module might be defective. Replace the power module and the power cord.
      • If the power module or power cord works on the other product, the product facing the issue might be defective. Proceed to Step four: Service the product.
If the product uses only a power cord, follow these steps to make sure that power is properly supplied to the product. Figure 4: Power cord c00057913.jpg
  1. Inspect the power cord for visible damage.
    • If the power cord is damaged, replace the power cord.
    • If the power cord is not damaged, continue with the next instruction.
  2. Disconnect the power cord from the wall outlet.
  3. Disconnect the power cord from the product.
  4. Wait 30 seconds.
  5. Reconnect the power cord to the product.
  6. Reconnect the power cord to the wall outlet.
  7. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
  8. If the product still does not turn on, plug the product into a wall outlet in another room.
    • If the product turns on when connected to a wall outlet in another room, there is an issue with the power supply in the previous room.
    • If there is no power to the product, then the power cord or the product might be defective. Proceed to the next instruction.
  9. Connect the power cord on another HP Deskjet or Photosmart product to see if the power cord is functioning.
    • If the power cord does not work on the other product, the power cord is defective. Replace the power cord.
    • If the power cord works on the other product, the product facing the issue might be defective. Proceed to Step four: Service the product.
Step four: Service the Product If you have completed all the steps listed above and are still experiencing a problem, service the product by calling hp at 1800-474-6836
Apr 29, 2009 | HP Photosmart D5160 InkJet Printer
Tacx Motor Adapter for FORTIUS / COSMOS 220 Volt T1941.50 Logo
150 people viewed this question
Top Tacx Cycling Experts
ray gallant
Donald Ayers-Marsh
JC Garza
JC Garza
Are you a Tacx Cycling Expert? Answer questions, earn points and help others
