Maytag bravos mvwx600xw0
Our maytag washer that is only 3 years old is doing loads no matter the cycle in 2 hours time per load. I have timed all of the cycles and the average is 2 hours long which is completely ridiculous. I've also notice that when the machine is in any cycle the read out will say "washing" but nothing is moving in the machine. More like soaking our clothes. Same thing with the rinse cycle. It says it's rinsing but I hear nothing. Any aides on what is the issue???
  • 451 Answers
It is possible that poor water flow may be the culprit. Most washers operate on a water level system. The water levels have to be reached before the next cycle begins . If the water flow is slow this can extend the run time. To remedy this shut water off to unit disconnect hoses at unit. There usually are screens inside each hose connection on washer gently remove these and clean them.reinstall in washer. Before reattaching hoses put the unattached ends in a pail and turn the water on to flush out the hoses. Then reattach them and see if this solves the problem. Hope this helps.
Posted on Dec 31, 2013
SOURCE: My Maytag Front Loading Washer Does Not Fully Rinse Cloths MAH8700A
A friend had this problem and was ready to buy a new machine. Sometimes it worked and sometimes not. I took a last look before new machine and found a coin that would intermittently block the pump/discharge port on the machine.
Posted on Apr 14, 2007
Bob Gemmell
  • 209 Answers
SOURCE: Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
Posted on Sep 13, 2007
wagdom
  • 64 Answers
SOURCE: Maytag Neptune Top Load Washer - Rinse Cycle won't run - Machine says nF
Sounds like the 'Wash water' is not pumping out fully,You need to drain the water by lowering the empty hose into a bowl & check the pump for a blockage ( if the pump is an 'electric one' check that it is working). TURN POWER OFF FIRST
Posted on Oct 26, 2007
  • 90 Answers
SOURCE: washing machine
check pressure switch hose
Posted on Jan 06, 2008
  • 35 Answers
SOURCE: Takes almost 2 hours to complete a wash cycle
Have you ever cleaned it out? Its likely due to a plugged drain, not allowing the system to drain fast enough for the normal cycle. Check out my solution on
http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
-Todd
Posted on Mar 30, 2009
How to run diagnostic
Maytag Bravos MTW6600T Top Load Washer Run ... - Fixya
www.fixya.com > ... > Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test cycle related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test ccu related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer Diagnostic ...
Dec 02, 2015 | Maytag Bravos MTW6600T Top Load Washer
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Jul 21, 2014 | Maytag Bravos Top Load Washer
Maytag bravos model mvwx500xw0 will not drain and spin properly
This could be a lot of things. One of them is the belt on the bottom that connects the transmission to the motor, of course it could be the transmission/clutch.
Feb 22, 2014 | Maytag MVWX500XW - Bravos XTM HE Top Load...
Maytag bravos washer- bleach compartment wont drain during wash cycle
The solenoid that turns on to dispense the bleach is bad, or you have a clogged tube that goes from bleach dispenser to tub.
Apr 29, 2012 | Maytag Bravos MTW6600T Top Load Washer
Error code f 70 and 71
F 70 overloaded
F 71 suds detect
To review: You got too many clothes up in here and you is using too much soap. These machines measure the weight. Take some things out or if you only have a small load add some things. It also measures the water quality in a load to determine IF a load is clean enough. Too much detergent throws the machine off. Then it trys to correct the problem many times and that heats up the motor and wrecks the sensors.
Basic rule of thumb:
HE: (2) Tablespoons Per Wash load
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
This reduces/prevents:
1) Musty Odor
2) Errors/Interrupted Cycles
3) L-O-N-G Cycle Times (longer than time displayed)
4) Insufficient Cleaning Results
5) Small Water Leaks from the air vent behind the washer or at the
front door gasket
6) Damaged sensors
7) Reduced Spin Speeds (laundry not spin-dried effectively)
Apr 11, 2010 | Maytag Bravos 4.5 Cu. Ft. Washer
My Maytag front loading washer does not fully rinse cloths MAH8700A. I purchased this washer about 6 months ago. I usually wash small loads but have noticed it doesnt matter what size load. When first...
Is the drain path free-flowing? That is, does the water eject freely during spin/rinse? Maybe there's a restriction in the line, or it's too high above the washer.
Feb 25, 2007 | Maytag MAH8700A Front Load Washer
Washing Machines Logo
75 people viewed this question
Top Washing Machines Experts
