Question about Panasonic RR-930 Microcassette Transcriber
How do i clean the heads on a panasonic microcassette transcriber rr-930
  • 145 Answers
SOURCE: High pitch sqealing noise
This is caused be a bad record switch. As a temporary solution, incert a blank tape, push the record switch, then stop. Repeat about 10 times. This may clean the contacts of the record/Play switch but it will probably need to be replaced.
Posted on Nov 08, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: spindles will not turn
There is a rubber drive belt that needs to be replaced, Panasonic part RDV101YA. This place says they have them:
http://www.partstore.com/Model/Matsushita/Panasonic/RR930.aspx?ModelAliasNumber=rr-930
I've never had to work on one of these so I can't say exactly what you might have to remove to get to the old belt and pulleys it rides on. But it's usually not too bad of a job to change a belt.
Posted on Dec 05, 2008
  • 18 Answers
SOURCE: have a panasonic RR930 microcassette
If neither rewind nor backspace work, the common problem would be that the solenoid grease has dried up and the solenoid is not retracting all the way. However, the track that the mechanism moves in also wears out, as well as the plastic rocker that depresses the rewind button where it engages the metal slide.
If backspace works but not rewind from the pedal then the problem is the pedal.
Posted on Jul 28, 2011
  • 18 Answers
SOURCE: My Panasonic RR-930 transcriber speeds
Start by cleaning the capstan roller. The rubber roller and small steel rod just above it, control the tape speed. Just a little lint, build up or animal hair wrapped around this can cause the speed to vary. Clean with alcohol and a Q-tip.
  • 145 Answers
SOURCE: the backspace on my Panasonic
There is a switch on under the tape deck that wears out or comes loose. This is something that needs service. We can fax it. 8663219780
Posted on Aug 16, 2011
After erasing a tape I have a high pitched noise when I step on the foot pedal
If it works fine otherwise, I wouldn't spend much time worrying about it.
You might want to clean the heads and the capstan.
Jun 01, 2014 | Panasonic RR-930 Desktop Cassette...
Cleaning and demagnetizing recording head on microcassette transcriber machine
You no longer need to demagnetize heads they aren't the same inductive materials they used to be. To clean you just need alcohol and a cotton swab. Clean head and capstan roller and capstan.
Jan 25, 2013 | Sony M-2000 MicroCassette Transcriber...
The sound is very faint even with the volume turned all the way up.
When you open the cassette door, there is a metal piece in the back that pushes the tape ajainst the head. If that is broken or bent, you can get low audio. Other possibilities are a dirty tape head or misaligned head.
Aug 01, 2011 | Panasonic RR-930 Desktop Cassette...
Have a panasonic RR930 microcassette transcriber. Right now the foot pedal will not allow rewind though when I press the pedal I can hear it engage. I can, however, rewind right on the unit itself. ...
Mar 23, 2011 | Panasonic RR-930 Desktop Cassette...
My Panasonic RR-930 transcriber speeds up and slows down as I play back tapes. The problem seems to be with the machine itself and not the foot pedal or the tapes. Where do I start?
Feb 02, 2011 | Panasonic RR-930 Desktop Cassette...
Spindles will not turn
Nov 12, 2008 | Panasonic RR-930 Desktop Cassette...
May 20, 2008 | Panasonic RR-830 Desktop Cassette...
Panasonic RR-930 Microcassette Transcriber Logo
29 people viewed this question
Top Panasonic Radio Communications Experts
Jason
ray gallant
Are you a Panasonic Radio Communication Expert? Answer questions, earn points and help others
