Question about Moen Villeta 3912ST Satine/Polished Brass Showerhead, Easy Clean 400
Glue for handheld shower
When taking the handheld shower head out of the box, the rotating plastic part was broken off inside. Tried an epoxy glue, but it didn't hold. Any ideas.
  • 55 Answers
If you could find out what kind of plastic the head is made of try that glue that works on that type of plastic. Different glues work on different plastic.
Posted on Jan 01, 2014
Piece of lid broke off
Sand the area on bottom of piece along with areas surrounding the broken piece. Get another small piece of plastic that is large enough to cover the broken piece and adjacent areas and apply the glue to that using a good epoxy for adhesion. Let it set up and it will hold - trust me.
Sep 27, 2016 | Cuisinart Dough Blade Plastic for DLC-2014...
I need to reattach a couple of plastic pieces that fit on the under side of the seat on my motorcycle. The pieces have broken off as the bike was probably dropped at some time. The two pieces plastic...
There is a two part plastic glue found in hardware stores, but if you are trying to end join two narrow pieces together without adding a backing piece, it won't work.
Dec 17, 2014 | Adhesives, Coatings & Sealants
Getting a rattling noise, from inside of R11s driver after hitting a ball
The most common thing is a piece of epoxy glue broken off in there. The pro shop can drill a small hole in a non-stressed spot and squirt some glue in to trap the loose bit.
Jul 21, 2014 | Taylormade LD R11S DRIVER - Graphite
Waterpik troubleshooting
Make sure the washer is setting inside the shower head properly. If you over tighten it you could crack the body of the shower head making it impossible to repair. Be careful. Remember you may need thread sealant too.
May 18, 2013 | Waterpik EcoFlow Watersense with...
How to seal a small hole inside the door of dishwasher from the metal end of the top rack hitting along the inside of the door.
Remove the epoxy, and clean the area with alcohol.
When dry, add a small amount of GOOP adhesive to the area. The door must be left open for at least 12 hours for the adhesive to set enough to prevent sagging. unit should not be used for a total of 24 hours for complete hardening.
The GOOP adhesive is available in the glue/adhesive sections of hardware and big box home center stores.
As an appliance tech I have used this product for many years on tubs of all types to save my clients from expensive repairs. It holds very well, yet can be removed if need be. As time goes on, you may need to add a little more to cover any additional wear that may occur.
Let me know if it worked out for you.
Apr 13, 2017 | Frigidaire Dishwashers
My washer lid switch is not broken but i cannot screw the screws into the holes on the switch because the plastic that surrounds the screws is broke. what should i do?
If you still have enough surface area to work with, you can repair the plastic where the screws go with two part epoxy. You can get it in a package that looks like a big double barreled syringe. Take the switch right out, cut a piece of plastic from a plastic lid or something similar to fit, and glue it on with the epoxy. When it is dry, drill two very small holes where the screws are supposed to go, and reinstall it. It will probably outlast the machine. (do not try to fix it with crazy glue or anything like that. You need the thickness of the epoxy)
Feb 19, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Is there a way to glue or bond or somehow repair broken plastic on a side mirror on a 2005 RAV-4?
Yes there is is you have a broken glass you can go to a local mirror shop and they can cut you a new one for about 10 bucks, then you can supergule it onto the inside fixture where the glass rests and hold it for about 4 minutes in place. Or use masking tape to hold it in postion. There are some plastics that super glue wont stick to so you may have to try 5 minute epoxy to hold it in place mix enought so that the epoxy will surrround baracket that holds the mirror.
Jul 19, 2009 | 2004 Toyota RAV4
Leaking maax shower drain, can I remove the grate and seal it from the inside?
try this:
you might but it will depend if it is pvc then yes any other material you might be able to use a waterproof epoxy but it will harder to repair because of the epoxy but the pvc you can prime and glue the seam from the inside..
Nov 09, 2008 | Maax Shower Drain 10000041-105
Moen Villeta 3912ST Satine/Polished Brass Showerhead, Easy Clean 400 Logo
67 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
