Question about VIEWSONIC - MONITORS Viewsonic Vg1932wm-led - Lcd Display - Tft - Led Backlight - 19" - Widescreen - 1440 X 900 - 250 Cd/m2 - 1000:1 - 10000000:1 dynamic - 5 Ms - 0.2835 Mm - Dvi-d, Vga - Speakers - Black - Vg1932wmled 19in Wide Led Lcd 1440x900 250 Nits Sp
I have my ps4 hooked up to my viewsonic monitor im getting sound but i want my sound to connect to my external speakers
I have a hdmi to dvi cable ps4 only supports hdmi so i dont have those red and white wires so the sound is going straight into my pc monitor but im trying to see if i can get the sound from the monitor to go to my external speakers
Would Roku work on HPw1907 with sound?
Some of the options you mentioned will carry audio along with the video from your Roku to your monitor but not the VGA for sure it's just video on that cable. I think your HDMI/DVI converter might work though. Worth a try anyway???
Let us know how it goes? We can all learn something here.
Sincerely,
Frank
Mar 29, 2015 | Computers & Internet
Xbox360 to pc monitor
HDMI to DVI works better than HDMI to VGA because VGA only uses simple RBG scheme.
Additionally the only way i see the Xbox getting connected to the extrenal speakers is if you get the speakers connected to the monitor/tv or whatever you are using directly. I havent tried or do not know of any way to connect the Xbox to speakers directly.
Dec 17, 2013 | Microsoft Xbox 360 Console
I have internal speakers on the monitor and I can't get the external speakers to work. There are no troubleshooting directions.
Try to check what type of connection you're using if its HDMI, DVI or VGA. If happens you're using HDMI it has a capability to give sound you just have to check the settings on the monitor or on the pc tower unlike the VGA and DVI you need to use speaker jack to have a sound on your monitor.
Example Pics.
HDMI connector
DVI connector
VGA connector
Hope I've helped you somehow.
AnEspera
May 08, 2011 | Computers & Internet
My DVI has no signal but my VGA does! what do i do? Please help me!!!
Your HP2009M monitor supports (3) methods of accepting signals from a computer. They are: 1) VGA, 2) DVI and, 3) HDMI.
You would connect the computer to the monitor using one connection only. Generally the VGA is the least desirable as it is an analog signal. The DVI and HDMI method provide digital paths into the monitor and often perform better. Your computer may only offer 1 or 2 connection choices, so you'll have to choose a cable type that is supported by both the computer and the monitor. The HDMI choice will pass audio signals to the the speakers in the monitor without needing to run a second cable between the stereo audio jack of the computer and the audio input jack of the monitor (located next to the HDMI jack) or to a set of external speakers (unless of course you prefer the external speakers).
The message you're seeing is normal. Once the monitor is connected to your computer, there will only be one active selection; VGA, DVI or HDMI. Since you're using the analog VGA jacks and cable, it is expected that you'll see a message that there is no signal present on the DVI (and HDMI) inputs when attempting to view signals on other inputs.
I hope this helps and good luck! Please rate my reply, thank you.
Feb 26, 2011 | HP 2009M Monitor
I dont have a hdmi connection to my lg e2350vr flatron monitor and there is no sound is it because i dont have the hdmi lead
the dvi (or vga) connection from a graphics card to the monitor does not carry audio.
in this case, the cable doesn't matter because your monitor doesn't have speakers. it does have an 3.5mm headphone jack, but that is only to transfer sound if it had come in with hdmi cables.
if you want sound, you will need external speakers
Jan 13, 2011 | LG E2350VR 23" Monitor
No audio/cable box to computer monitor using hdmi/dvi
Hi lauriesbc
if you take the audio feed from your cable box via the line out sockets then plug into line in on your sound card you shud be able to get audio.....
hope this helps
Feb 16, 2009 | Dell Dimension 3100 PC Desktop
Acer H213H No sound
Dude, the hdmi is just for the video signal, you'll have to use a separate audio cable to get sound from the integrated speakers.
Jan 02, 2009 | Computers & Internet
I want to hook up external speakers to my Acer H213H for when my PS3 is hooked up to it.
What method are you using to connect to the monitor?
If you are using the HDMI -> DVI adapter it does not support sound. HDMI does, but DVI does not.
If that's the way you are set up then all you need to do is use the HDMI -> DVI adapter for your video and use the regular RCA connections for audio.
You can set the video and audio settings in the PS3 with the "Display Settings" and "Sounds Settings"
That way you just use the red and white RCA ends to connect to a speaker system, the yellow won't be in use at all.
Dec 10, 2008 | Acer Computers & Internet
What do i need to got sound out of my hdtv?im using a hdmi to dvi cable.
if you have no optional external speaker on the ps3 you may have an earphone socket which can be connected to your tv's pc sound input via a 3.5mm or 6.5mm jack plugs.
Aug 13, 2007 | Sony Playstation 3 (PS3) Console
VIEWSONIC - MONITORS Viewsonic Vg1932wm-led - Lcd Display - Tft - Led Backlight - 19" - Widescreen - 1440 X 900 - 250 Cd/m2 - 1000:1 - 10000000:1 dynamic - 5 Ms - 0.2835 Mm - Dvi-d, Vga - Speakers - Black - Vg1932wmled 19in Wide Led Lcd 1440x900 250 Nits Sp Logo
65 people viewed this question
Top VIEWSONIC - MONITORS Computers & Internet Experts
David Payne
David Payne
Are you a VIEWSONIC - MONITORS Computer and Internet Expert? Answer questions, earn points and help others
