Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
THOMSON Scenium 52" widescreen rear projection TV
Weird problem for the last 6 months....TV starts with static streaks across the screen ( picture is visible)....starts running normally after warmng up for about an hour....
Of late it takes much longer sometimes two to three hours for the picture to get normal and now in addition to the static lines there is a green noise all over the screen ....the green keeps turning yellow...then it forms a huge square yellow which keeps vanishing and reappearing.......
  • singha699 May 21, 2009
    Thanks Palaboy......completely lost the picture yesterday.....its just the screen filled with yellow noise....the audio is clear...Thanks for the tip anyway.....
ladywinn
  • 5138 Answers
SOURCE: RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Posted on Feb 17, 2008
Slinteriors
  • 8617 Answers
SOURCE: Thomson Scenium 52" backprojection tv, Does not start
try resodering the connections on the flyback. Its fairly comon for that model to have hairline cracks at the solder joints which will cause the symptoms youre describeing.
Posted on May 27, 2008
SOURCE: rca scenium turns off and on
I wish I had the idea to install a cooling fan, a local repair shop fixed mine by replacing a power supply component, cost $575 including sales tax. I suspect that a cooling fan would increase the life of the power supply, I will install one!
Posted on Dec 04, 2008
  • 185 Answers
SOURCE: red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Posted on Dec 26, 2008
  • 157 Answers
SOURCE: thin red line, green line and yellow line going across the screen
the problem is vertical collapse,i am not so sure you can trouble shoot this on your own but you can send the board to eithor pts electronics or tristate module for repair
to get a price get the number off the sticker--left hand board(looking from the back) it will start CTC195---- write down entire number before you call them
Posted on Sep 02, 2009
Testimonial: "good suggestion."
Hello, I have a 52"
you do not give a model. is the tv plasma, rear projection or lcd as they have different ways of lighting the screen so i can not advise further
Aug 26, 2011 | Thomson Televison & Video
RCA Scenium 52 DLP
you should take it to a tv repair shop to look it over, they charge $50 and they will tell you want the problem is.
Dec 17, 2007 | RCA Scenium D40W20 40" Rear Projection...
Hi i want to ask about a lamp that related to thomson tv thomson 61 dsz 644 dlp hd tv lamp what is its price ?
http://cgi.ebay.com/LAMP-THOMSON-SCENIUM-61DSZ644-RP-HD-DLP-TV-/270697798709?pt=LH_DefaultDomain_205&hash=item3f06d89c35
Mar 09, 2011 | Thomson 61DSZ644 Rear Projection Lamp...
Tv not coming on just red light flashing on and
thomson scenium jw 611s not coming on just red light flashing on and off at front of tv
Jul 13, 2010 | RCA Scenium HD65W20 65" Rear Projection...
Won't Turn on
Check the batteries in the remote 1st. If that don't work, call a TV tech to replace the IR sensor in the TV
Jul 27, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Thomson Scenium 52''Rear Projection TV set -
you have a laser that has gone out blue or green take the face off and see which of the colors you need you can still find lasers on ebay if you need one but it will require someone with a little expertise to replace them. if this is not for you then its time for a new TV this is probably the best option its more expensive to fix in most cases than to replace..........I hope this helps
Jul 20, 2009 | Thomson Televison & Video
Thomson scenium 52 inch tv.
have a look in your tv's manual and see if you can find a command degauss this should correct the wscreen
Mar 05, 2009 | Televison & Video
RCA D52W17 ANTENNA/CABLE ANALOG INPUT
are you looking for this part?
http://www.partstore.com/Part/Thomson/RCA/264658/New.aspx?ModelMfgName=Thomson&ModelBrandName=RCA&ModelNumber=D52W17BYX1
if so, just make sure your model number is on the listed devices.
Nov 11, 2008 | RCA D52W23 52" HDTV CRT TV
May 27, 2008 | RCA Scenium D40W20 40" Rear Projection...
Blue haze around image, yellow streak
the tv color circuit is off frequency change the color ic take a look on the crystal that gives the 4.8.mhz burst could be that it needs to be replace dont rule out the video IF change the two ICs you mention.good luck.from the look of your tv screen that is my conclusion.good luck.email me at nicodhem@yahoo.com
Apr 04, 2007 | Samsung HC-P4241W 42" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
627 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
