Question about Insignia Televison & Video
32'' insignia TV volume stuck down
Behaves as if the volume switch on the TV itself is stuck down. Decently tech savvy, so I tried pretty much everything other than tearing it apart, and fully disconnecting the manual switches. Isn't the remote, took it's batteries away. Tried keeping it unplugged for awhile, isn't that. Buttons are not physically stuck down. Cannot do anything with either the remote or the manual controls as the phantom signal for the volume seems to override everything......THANK YOU FOR ANY SUGGESTIONS/FIXES!
    Top Expert:
  • Insignia Master
  • 43,113 Answers
This may turn out to be a failed component internally.
Posted on Dec 31, 2013
SOURCE: Insignia NS-LCD32FS strange behaviour
Sometimes this can be fixed by removing the power plug from the wall and either allowing it to sit or grounding the power leads together (UNPLUGGED) to remove and residual charge. I know it sounds nuts but it has worked for me on three separate electronic devices
Posted on Apr 11, 2008
SOURCE: Volume n my tv keeps going down
same
Posted on Apr 15, 2008
SOURCE: Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
Posted on Aug 23, 2009
  • 3 Answers
SOURCE: 42" LG 42LC7D LCD TV stuck in demo mode?
Did you have any luck? My LG is stuck in demo mode too. Menu button doesn't work, and keylock was on as default so I can't use the buttons on the TV itself.
Posted on Nov 30, 2009
John-INSG
  • 312 Answers
SOURCE: i have cablevision box and remote controll for it.
A variety of remote control codes can be found at InsigniaProducts.com. Failing that, try codes for the following brands: Orion, Emerson, Memorex, Sansui, Sylvania, Zenith.
Posted on Jun 17, 2010
Volume turns up by itself
This might be a remote control issue, so try this: remove the batteries from your remote, then press all of its buttons and install new batteries. If the problem persists after that, your TV may require repairs. Service can be obtained, if needed, by carrying your TV in to the place of purchase.
Nov 27, 2011 | Insignia Televison & Video
Menu keeps flashing remote control wont work, cant change channel or volume.when i hold down channel up andmess with remote sometimes it changes channel. channel down button is only one that doesnt change...
U have 2 situations:
1st U have a tv Key stucked or internal control board defective.
2nd U have a broken tv remote control.
Note: Check for stuck pressed keys on TV, if not send to repair shop, for checkup.
Nov 29, 2009 | Insignia IS-LCDTV32 32 in. Television
When i turn the tv. on, the volume line appears all the way to zero. if i turn the volume up, it goes up but when i release the up button the volume goes down all by itself.
It sounds like one of the volume down buttons is stuck in the activate position. The same as if you were holding the down volume button continuously. It could be either the volume down button on the TV or the remote. I would try remove the batteries of the remote then adjust the volume by the TV buttons.
If the volume doesn't go back down then the remote is the problem. In order to fix the remote you may need to take it apart. This is normally easy to do just locate any screws that may be holding the remote together. If you don't see any screws then you will need to pry the two sections apart. Separate the circuit board and rubber buttons and clean them both with some rubbing alcohol and reassemble it. If it still has the volume issue you may need to replace it.
If the problem persists with the remote deactivated then it's the volume button located on the TV. That is a little more difficult. You can try wiggling the button or some canned air (used to clean computer keyboards) to blow it clean. However it may need to be disassembled to gain access to the switches for proper cleaning.
Hope this helps.
Oct 19, 2009 | Toshiba 32A33 32" TV
Volume decreasing to zero by itself
Have you looked to see if the Button on the tv itself is stuck in. Press it and you might be able to feel for it sticking. If this is the case you may want to try a baby wipe or something similar to try and sort this out. (dont use a sopping wet cloth)
hope you get this sorted.
Little Dish Fitter.
Oct 07, 2009 | Toshiba 32A33 32" TV
The volume is turning itself down all by itself. The volume on the remote won't work, but the remote is fine with the other TV controls.
It sounds like the button is stuck. Take the remote apart if you can and see if the key is stuck somewhere. This happened to me once with a rubber key type of remote. It drove me crazy.
May 10, 2009 | Sansui HDLCD3210 32 in. LCD TV
Cannot turn tv off with power button or remote , must unplugpower
It could be a stuck button on the set. check to make sure they all feel the same.. If one don't feel right try to free it .. If a button is stuck it wont let any of the others work or the remote.
Mar 29, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Tv is stuck on channel 25
30 YR SERVICE TECH
THER ARE NUMEROUS THINGS THAT MAY HAVE CAUSED YOUR PROBLEM. TAKE IT IN TO A SONY AUTHORIZED SERVICER
Jan 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Volume fix problem
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there Good Luck! This worked for me.
Aug 02, 2008 | Yamaha RX-V659 Receiver
Rca
eeprom porblem my friend take it to a tech for repairs.good luck
May 17, 2007 | RCA 32V550T 32" TV
Televison & Video Logo
179 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
