Question about Neff Watches
Neff daily hands wont move - Neff Watches
Changed the battery, hands move slowly but doesn't keep time...help
There is likely something wrong with the gears and mechanisms inside.... you can contact the manufacturer and ask if others have had a similar problem, and see if they might have a solution. Other than that, you may just have to get a new watch.
Feb 07, 2016 | Neff Daily Sucker Blue & Black Analog...
How do i turn off alarm on my neff flava watch ?
Here is a YT video that is helpful for this question:
Neff Flava Watch SKU 7879816
answers can be found here:
How to change time on neff flava watch
Apr 13, 2015 | Neff Flava Green
Neff daily watch
Does it come with a battery in it? I've had watches where there was a little clear plastic tab you had to pull to allow the battery to make contact and the watch to run. If not, then all I can suggest is to but another brand of watch. Here's their web site link. At the bottom of the page is the contact link...good luck.
Front Page
Mar 29, 2014 | Neff Daily Watch - cyan/pink/black
I bought a Neff daily black analog watch at Zumiez about a month ago as a present for a friend. the problem is that the minute hand and hour hand do not move... you can move them to set the time but once...
I would take it into a jeweler and they will put a new battery in it for $4. If that fixes it all well and good, if not it cost you 4 bucks to prove it needs to go back under warranty.
Feb 06, 2014 | Neff Daily Sucker Blue & Black Analog...
The second hand is not moving even when i wind it
This watch is an automatic type and may you not be able to wind it up use the crown wheel (winder). The details on their web site do not describe the operation of the watch, so I can't be absolutely sure about this.
You can wind an automatic watch by swinging it genetly from side to side for few minutes.
When fully wound, the watch will remain working for 42 hours (when not being worn).
These watches thrive on being used and if used daily, they should remain operating.
Dec 24, 2010 | Christian Dior Dior Chiffre Rouge...
Second hand stops for a few seconds and then starts again over and over again
Try manually winding it (assuming it's not a quartz watch). If a mechanical watch is not worn daily it will run down and need to be manually wound to get going. Turn the crown clockwise about 40 turns.
Apr 25, 2010 | Tag Heuer WK1120.BB0314 Wristwatch
My wifes recently repaired Rolex loses about an
Is it an automatic self wind or wind up? An automatic watch has a weight that winds the main spring and if you wind it by the crown it will not stop. If its one that you wind by hand then the watch should be wound daily at the same time...like right before bed or when she wakes up. Wind gently until it stops. That costly repair should come with a warranty so if she consistently winds daily and still loses time you need to send it back!
If the watch is an automatic then she can gently hold the watch in her hand and rock it back and forth a good 20 times or so and that will give it a good winding! This is a common issue we see at our watch repair business. Some people do not move enough during the day to keep an automatic movement wound. If thats the case then there is nothing ong with the repair, just make sure it gets a good daily wind! :-)
Jan 10, 2010 | Rolex Watches
WATCH
Press MODE 5 times until you see H-SET on the right side of the dial in the box. Then press the ADJUST button. You will now notice the current TIME you have already set on your watch will appear in the box and flash where H-SET was. This will help you know what time to set the hands on. While holding down the FORWARD button you will see the hand start to move. I could not move mine in reverse, only forward. Simply set the time and you are finished.
Jul 18, 2008 | Casio G-Shock G511-1AV Wrist Watch
Watches Logo
29 people viewed this question
Top Neff Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Neff Watch Expert? Answer questions, earn points and help others
