Question about Refrigerators
Unplugged our refrigerator to move it. now it doesn't cool. Is there a reset button?
  • 1 more comment
  • pnv94 May 20, 2009
    Unplugged our refrigerator to move it. now it doesn't cool. Is there a reset button? Amanga side by side refrigerator model #9502331273
  • ellery queen May 11, 2010
    As far as I know there is no reset on that model, they usually just turn back on, sorry.
    What is the make and model?
  • 864 Answers
If you tipped it on its side you may have caused an air bubble to form in the refrigerant.
Plug it in, leave it empty, set for maximum cooling and do not open the door to check it for several hours.  Put a thermometer inside to check the actual temperature after three or four hours to see if it is getting cool.  Listen for the compressor to come on and whether there are any strange noises.  If you hear gurgling in the coils the refrigerant should be working OK.
Posted on May 20, 2009
Refrigerator and freezer not cooling
Check the start capacitor on the compressor and the thermal cutoff switch. It is where the wires connect to the compressor.
Jan 05, 2014 | Whirlpool ED5VHGXM Side by Side...
My refrigerator shows a code "OF" or "0F" where the temperature settings usually show, we tried to put the temperature settings back but couldn't. We unplugged the refrigerator to reset it but it sti
Cooling Off mode (also called Shop mode), is designed for use by retailers when they are displaying refrigerators on the shop
floor. In Cooling Off mode, the refrigerator's fan motor and lights work normally, but the compressors do not run, and
the refrigerator and freezer do not get cold.
To start Cooling Off mode, Touch and hold the Energy Saver button and the Power Freeze button for 3 seconds during normal
operation.
The refrigerator chime sounds and the temperature display flashes OF OF.
To cancel Cooling Off mode, Touch and hold the Energy Saver and the Power Freeze buttons again for 3 seconds.
Source: http://downloadcenter.samsung.com/content/EM/201104/20110414114919054/110323-QS_Guide-POLARIS-EN.pdf
Dec 30, 2013 | Samsung Real Stainless Steel 30 Cu Ft Side...
Samsung fridge not cooling
If the compressor runs but doesn't cool then it is possible you are low on refrigerant. Also if you recently moved the unit by laying down to transport from one place to another, it may have developed an air lock in the lines and may cure itself by simply letting it sit over night unplugged
Oct 31, 2012 | Refrigerators
Hotpoint Refrigerator constantly runs and doesn't shut off normally.
Sounds like the thermostat is not working that is what tells the compressor it is cold enough shut off.
May 17, 2012 | Hotpoint Refrigerators
Fault code EF is flashing on my Electrolux fridge FSC23R5DSB6. What does this code mean?
EF on the Electrolux refrigerator digital display means "evaporator fan."
The long answer is, it doesn't necessarily mean there is something wrong with your Electrolux refrigerator.
Turn the power off on the digital display and carefully unplug the refrigerator from the power source. Leave the refrigerator unplugged for three to five minutes. Plug the refrigerator back in and give the refrigerator a few minutes then turn the power button back on. Press the default button on the display and see if the EF code goes away.
Electrolux recommends that you do not plug the refrigerator into an outlet that has a reset button. If your refrigerator is plugged into one of these outlets, try plugging it into another outlet and see if the refrigerator resets itself.
Hope this helps.
Jul 21, 2011 | Refrigerators
I lost colling in freezer then in refigerator . I unplugged and then replugged in didnt work I also have not recently moved.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 23, 2011 | Amana 22.6 cu. ft. Side-By-Side...
I moved ref from my sons to my house brought in house plugged it in and it started up. seem like cool air blowing out about 20 min or so. then i noticed it wasn't running. unplugged it for 20 min then...
Here is a tip that I wrote on moving refrigerators...if you did not do it thisway then you may well have ruined a perfectly good refrigerator.
Moving a Refrigerator What is the best way
If you already have moved it wrong, you can sometimes get it working byplugging it in and unplugging it a number of times with an hour or so inbetween.
heatman101
Oct 16, 2010 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
Reset button
There are no reset buttons, try unplugging and leaving it unplugged for 10 minutes or so, if it doesn't start working again you may need a new control board
Jun 14, 2009 | Frigidaire FSC23F7D Side by Side...
Model rs2533sw panel not reseting after being unplugged
I had the same problem (panel would not start up - just flashed one dash after a power outage).
The solution above: pressing the top two buttons for 12 seconds (Power Freeze and Power Cool buttons) reset the panel and everything is working fine now.
Thank You!
Dec 24, 2008 | Samsung RM255LASH Side by Side...
Refrigerators Logo
599 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
