Question about 3M Portable Labeler Kit PL200K
LABEL STALL DETECTED - 3M Portable Labeler Kit PL200K
What causes the printer to stall after changing label roll or ribbon.
Try resetting the printer:
Turn off the printer, (in the back) then turn on the printer while holding down the Reset button on the top. Release the reset button when the light turns green then wait for the printing to stop. IMPORTANT: Next press the reset button for 1/2 a second. If you hold it too long it will not reset the printer properly.
Feb 20, 2013 | Intermec EasyCoder PC4 Label Printer
No gap detected
This could be caused by a couple of issues:
  • Dirty sensor (use compressed air and blow out printer)
  • Wrong media (using labels with black bars obscuring the gap and making it non-readable by sensor)
  • Wrong label format for size of labels used (make sure label size matches the template size)
Zebra printer no gap detected
Dec 12, 2012 | Zebra Eltron TLP 2742 Thermal Label...
Out of stock
Morrisettepa: This error occur when the labels are not detected, 1. the label is out of sensor, 2. the label sensor is dirty or blocked. Clean it, adjust in correct position and perform a sensor calibration. Press and hold FEED button by 5-6 seconds and release it. In display you can see CALIBRATION SUCCESS, if not, then repeat the quick calibration.
Sep 15, 2011 | Datamax DMX-I-4208 Label Printer
What does it mean when the printers shows "position fault" in the error screen?
Amr141: "Position fault" was refer to label not detected by the printer. You can make a quick calibration press and hold FEED button by 5 - 7 seconds and release. Also check the label and ribbon are installed ok and the label sensor is not dirty.
Roberto Martinez
padrino99@prodigy.net.mx
Sep 06, 2011 | Datamax I-4208 Thermal Label Printer
Gap not detected
GAP NOT DETECTED error in displayProduct: T5000rSymptom
GAP NOT DETECTED error in display.
Possible Cause
Dirty media sensors, wrong label length
Recommend Solution
Clean the upper and lower media sensors by spraying them with dry air. This should bedone every time the media (label stock) is changed.
Before running the Auto-Calibrate operation, check the QUICK SETUP or MEDIA CONTROL menu for the 'Label Length' parameter. It should be set to the length of the label, not counting the gap.
Check that the sensor type has been set in CALIBRATE CTRL menu to match the media and ribbon.
"Gap" Select when using media with a liner space between die-cut labels or when using tag stock with notches or holes as label length indicators.
"Mark" Select when using media that has horizontal black marks located on the underside of the label liner or tag stock.
"Advanced Gap" Select when media is gapped but also has a dark background.
This sensor arrangement looks through the ribbon, and will not work if ribbon is too dark.
"Advanced Notch" Select when media has a notch that is placed in a dark line on the back of the stock.
Check the position of the media sensor. It should pass through the center of gaps or marks or notches, but not through pre-printed areas if possible.
Run Auto-Calibrate in CALIBRATE CTRL menu, which sets Gap and Paper Out Thresholds
Feb 24, 2011 | IBM Infoprint 6700 R40 Printer
Printronix t5000r "GAP NOT DETECTED"
pls you can checked it by gap adjust lever. it is available in right side of printer.
Aug 17, 2009 | Printronix T5000r Label Printer
Prints only part of label
Fixed problem. Labels were too thin so LED was still being detected to stop progress of labels. Fixed by sticking some backing paper over the sensor and seems to be working fine.
Jun 12, 2009 | Zebra Eltron Orion LP2443 Thermal Printer
CD label (Neato) printing problem
Try to change your paper type to plain paper - it could be because it is a bit glossy that it thinks it's photo paper that is not inserted correctly.
Jan 04, 2009 | HP Photosmart C8180 All-in-One InkJet...
GAP NOT DETECTED ERROR ON PRINTRONIX T5000 PSN
My label printer quit printing the barcodes on the labels.
I am just getting a series of lines.
I have tried unplugging the machine and still have the same result.
I have tried to calibrate but that is not working either.
Thanks in advance for any suggestions.
Jul 21, 2008 | Printronix T5000r Label Printer
3M Portable Labeler Kit PL200K Logo
434 people viewed this question
Top 3M Office Equipment & Supplies Experts
Lampdeng.com
Lampdeng.com
Electro Med Services...
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
