Dash lights keep flickering after key is removed
    Top Expert:
  • Televison & ... Master
  • 75,289 Answers
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can vet an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/
Posted on Jan 01, 2014
MY HEADLIGHTS ARE BLINKING AND MY HORN IS TOO AND RELAYS ARE BLINKING TOO.
Search Results
    2002 saturn l200 headlights and dash lights blinking - Saturn ...
    www.saturnforum.com/.../saturn-l-series.../2002-saturn-l200-headlights-...
    Mar 6, 2013 - My wife told me that on occasion the headlights and the dash lights willblink when she lets off the. ... 2002 saturn l200 headlights and dash lights blinking.... 2000 LW2 dash lights Inop, spotts56, Saturn L Series Sedans & ...
    Saturn l-300 wagon has flickering lights - Car Forums at Edmunds.com
    forums.edmunds.com > Saturn > Saturn L300
    My wagon 2003 l-300 has flickering lights and when the radio is off you can hear the ...My Dad has a 2002 Saturn Lw series wagon. the transmition has been ...
    why a green light always keep flashing when running? - SaturnFans ...
    www.saturnfans.com > ... > Models > Saturn S-Series > S-Series General
    Apr 17, 2007 - 20 posts - ‎14 authors
    S-Series General. ... A green light alwyas keep flashing when my saturn 2002 sl2 .... I had a similar issue with the headlights of a 2002 Impala, but it was an .... I never noticed on my SL2, my L200 or on my Ion now if they come ... Flashing Dash Lights
    Oct 20, 2008
    Flickering lights?
    Nov 21, 2007
    L300 2004 - Lights Flickering - Have some help
    Nov 2, 2005
    Flickering Lights
    Feb 5, 2005
    More results from www.saturnfans.com
Feb 09, 2016 | 2002 Saturn L-Series
Dash lights wont turn off after ignition key is removed. they keep flickering
read the manual , and schematics on same yet. read it.
see how it all works. the use an voltmeter to fund the bad part.
free fsm.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
Dec 31, 2013 | 2002 Jeep Liberty
Recently bought a 99 CR-V. Had it tuned up and fixed almost everything. Runs very smoothly. One remaining problem is engine going dead while driving or just won't start after parking. Dash lights flicker...
Old post.
same here, there is only 2 paths (besides wild $$$ guessing)
1: yes, do scan it, if the tool goes dead (comms down) the ECU lost 12vdc power. (the CEL goes dead to , just key on, if no power to ECU/PCM.
2: or diagnose the no start.
what is flicker?, the dash lights come on key on to tell you power is ok and all things running them thinks they are happy,
some cars have immobilzers, and it does flicker at IMMO mode.
blocking you.
be specific on lights. what lights to what.
the operators guide is free, and shows each light.
Sep 24, 2013 | 1999 Honda CR-V
I have a 2000 Saturn LS2 that has flashing dash lights, i.e. warning lights, etc., when I start car. All the dash lights flicker and the gauges drop to zero. What is wrong?
same problem here as well. I'm going to try and replace the ignition cylinder. Does yours start? Mine starts, but can't get out of park unless I move key to run (put in neutral) and start again, Issue dash is going crazy and running light are flickering. I noticed yesterday that the turn signal lever is hot, so it might be some short in the steering column
Jun 20, 2013 | Cars & Trucks
Headlights and dash lights flickering
loose wire between headlight switch and lights.
Find it before it shorts something out.
Mar 16, 2013 | 1993 Chevrolet C1500
Dash lights flicker when ya turn key and wont start"" (then after you keep turning key serveral times lights quit flashing and car starts" what do you think it could be??
have battery checked, sound like battery weak or battery cables loose or battery post and cables need cleaning has a lot of corrossion.make sure you turn off radio before disconnecting negative battery cable if you decide clean battery cables and battery post,reason for turning off radio to keep from locking out radio play code.have battery tested battery volts should be 12.6 volts.
Feb 01, 2012 | 2002 Oldsmobile Intrigue
Parking and dash light flickering
First. I would look for a loose connector plug going to one of the fuseboxes, there could be corrosion in the connector even, Under the hood or under the steering wheel. 2nd. I would try to locate the ECM, could also be a bad connector there as well.
Jan 13, 2018 | 1995 Oldsmobile Cutlass Supreme
My dashboard and gauges keep flickering on and off
sound like you have a lose connection it could be the cables on to the dash or the socket it fits to. you would need to remove the dash and clean the connection and re fit it. if you push on the dash does it stop. ? just check this first as some times its just a tiny amount of play in the connections that's the problem .
Jul 03, 2017 | 2008 Jeep Patriot
Turn key will not start battery is good
Make sure the connections and the cables are good.No corrosion on cables.If the lights in the dash flicker this is usually a sign that the battery is not good or it is not making good contact.Have the charging system and battery load tested.Hope this helps.Good luck.
Dec 25, 2009 | 2002 Chrysler Concorde
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
