Question about Walkera HM5#10 RC Helicopter
One prop will not turn
Propeller
If there's something tangled in it
Posted on Dec 31, 2013
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    When I start powerr-up 3 propellers turn in unison but one prop only starts to turn when the power is almost at full power
    I youtubed your Model: X4 H107 RC
    All propellers are in unison. Your model may be faulty.
    All videos I have found show all 4 propellers working at all times.
    Check the one propeller and see if there is anything obscuring it's rotation. Otherwise contact the store or the manufactuer.
    Aug 05, 2014 | HUBSAN The X4 H107 R C Micro Quad Copter 2...
    I have the Air Hogs Helix X4 Stunt Quad Copter and it flys to one side sometimes. One of the propellers will periodically stop. When I turn the throttle off that same propeller stops spinning earlier then...
    I have the same problem, two props spins freely when I spin it by hand in switched OFF position. and in ON position, when I turn down the left control to zero they continue to spin while other propellor stops. I know this info is not a solution but if there was a "how to replace motor or propellor" site. maybe I'd find a clue to why the props drag and get it to spin freely like it suppose to be. I could probably put a video together on that topic but if there is already one out there let us know.
    Sep 22, 2013 | Spinmaster Air Hogs Helix 360 Helicopter
    Remove bent propeller shaft 25 hp mercury two cycle boat motor 2005
    Take The Propeller Off,
    Use The Rear Thrust Washer As a Tool Turn It Upside Down And Put It Back On The Prop Shaft The Three Slots Should Match With Bearing Carrier.,Undo Three Bolts On The Carrier In The Back Of Gear Box,
    Turn Carrier Counter Clock Wise Until It Is Loose Remove Prop Shaft Complete With Carrier and Reverse Gear
    Mar 16, 2013 | Boating
    How do I remove my propeller if the propeller shaft turns?
    I'm not sure exactly what you are working on but, with motor off and in gear, the shaft should not turn. You should be able to put a piece of 2 x 4 , or whatever fits in the space between the prop and the cavitation plate, to wedge in and stop it from turning.
    Jun 27, 2011 | Boating
    I have a johnson 50 hp outboard when travelling in excess of 5 knots the prop stops turning and motor revs high.
    In the hub of the propeller is a rubber bush that stops damage to the shafts and g/box if something is struck with the prop.These bushes do give way and are repairable.See your local boat shop or look for a specialist propeller shop.Probably the latter as the boat shops sends the props to them anyway.Its called the propeller hub bush or just the prop bush.Just take the prop into them and all will be good.Hope this helps you
    Nov 19, 2009 | Boating
    2001 suzuki outboard water prop
    water prop? if your talking about the Propeller that rotates to propel the boat. only replace it if fins are missing. Aluminum and stainless steel propellers can be rebuilt. If your talking about the water pump impeller. the answer is yes. its rubber and should be replaced seasonly
    Oct 31, 2009 | Light Outboard Motor Boat Bass Fishing...
    How do we replace propeller on super cub?
    The spinner is simply pressed on. Pull the spinner directly forward while firmly holding the plane at the firewall. Once removed hold the prop by hand and use a wrench to loosen the prop nut. The propeller should slid off but may need to be unscrewed.
    To re-install, just reverse procedure. The prop needs to be firm or snug only. Do not over tighten. Be sure to press the spinner back on lined up with the prop blades. Then go fly
    Jun 14, 2009 | Hobby Zone Hobbyzone Super Cub Propeller...
    Vibrations after propeller strike ???
    chances are the prop has an unbalance condition...You can also check it for excessive runnout by simply referencing it against something and turning it. all blades should remain at the same distance from reference point as you turn it. You can do this to check the shaft as well.
    Jun 07, 2009 | 1994 Mercury Capri
    Minnkota trolling motor prop removal
    remove the nut and the prop will come right off. Just be careful not to loose the shear pin.
    Apr 22, 2009 | Minn Kota Endura 30 Freshwater Transom...
    Walkera HM5#10 RC Helicopter Logo
    Top Walkera Toys Experts
    Andrew Taylor
    Andrew Taylor
    Are you a Walkera Toy Expert? Answer questions, earn points and help others
