Question about Dryers
Got kleenmaid clothes dryer, all the wire in side have been out
I need to know were all the wire go on the dryer, so i can get it going. Thank you
I got the wiring diagram to fix the dryer.
Posted on May 20, 2009
My kleenmaid ked600 condenser dryer is giving me a F4 error code. And not heating. Could it be the thermostat? Where can I locate the meaning of the error codes ?
In case of F0, F1, F2, F3, F4 failures,
contact your service technician without
hesitation.
http://www.kleenmaid-appliances.com.au/assets/pre2011_manuals/Use&Care/DR/KM_DR/KED600.pdf
and then I found this
"F4? Too much lint in the lint filter, front housing, or in the condenser Clean lint from lint filter and/or condenser I would just contact them.
http://www.kleenmaid-appliances.com.au/support/contact-us/
Mar 04, 2016 | Dryers
I own a Kenmore clothes dryer, serial #ME2475807, model/stock #96573220. Recently the heat stopped working. It still spins the clothes around, but does not heat up to dry them properly. I think it needs a...
Unplug the dryer and take the back off
The backsides is where the element is located.
The back side components look like this:
Their are 2 limits mounted on the heater chamber:
More here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 12, 2011 | Kenmore Dryers
The dryer turns on but isn't warming up so clothes are not drying.
Look for goop on the dryer sensing bars. get some windex and clean them . The moisture sensing bars send back resistance readings to the control. No moisture sensed and the control thank they ain't no wetness in them clothes, it goes for cooldown and shuts down with wet clothes.
thats one scenaio. if that don't fix it we will go to the next step. let me know
Feb 10, 2011 | Kenmore Elite HE4 Electric Dryer
Believed over loaded with clothes now will not start
First thing you need to cheak is the breaker on your house panel.At times it may kick out on 1 side it should be a double 30 amp.you should be getting 220volt If not that then you may want to cheak if your door switch is working.If not door switch then you may have a burnt out thermal fuse located on the blower housing rear of the dryer on the bottom left side .There are 2 small blue wires going to it.Try bypassing the thrmal fuse by connecting wires and taping them together then run the dryer. Hope i helped:)
May 17, 2009 | Dryers
Kenmore 90 series gas dryer, NO HEAT!!!
Hi, if you get no glow on the ignitor and you have voltage its the little white two terminal fuse on the exhaust side that has no continuity on the series 80 it has 2 blue wires, these complete the circuit for both gas valves and the ignitor. If you have an ohm meter it you will find it rite away. Hope this helps.
Mar 21, 2008 | Dryers
Dryer does not dry clothes
On the top of the heater box there is a thermal fuse that blows if the dryer overheats, on this model it could occur if the air circulation fan is faulty, or the condenser valve is faulty, alternatively the sump hose filter may be blocked, only a closer inspection of these items will determin which the problem is.
Regards
Advisor
Nov 13, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Dryers Logo
91 people viewed this question
Top Dryers Experts
