First in math login
Fractions
  • Computers & ... Master
  • 7,993 Answers
Here is the link to the login page. Enter your user name and password and click the LOGIN button.
http://www.firstinmath.com/
Posted on Jan 01, 2014
Where is the fraction key on this calculator?
There isn't one. You can convert some values to fractional form by using the >Frac command on the Math menu available by pressing the MATH key. You can enter a fraction as a quotient, but the calculator deals with the number internally by converting it to decimal form.
For example, to see one-half plus one-third, press
( 1 / 2 ) + ( 1 / 3 ) MATH 1 ENTER
Nov 05, 2010 | Texas Instruments TI-84 Plus Calculator
How do you enter a fraction
A fraction is just a division of two integers. Enter numerator, then press the division key and then the denominator.
If you press ENTER at this time your fraction will be calculated and displayed as a decimal number.
To keep it in fraction form you must press [MATH][1:>Frac]. The result will be a fraction but reduced to its simplest terms (an irreducible fraction).
27 [/] 48 [MATH][1:>Frac][ENTER] gives 9/16
Aug 17, 2010 | Texas Instruments TI-83 Plus Calculator
I have to learn how to operate a texas instrument TI-83 to do math (fraction)
This calculator, although very sophisticated, is rather unfit for heavy fraction calculations. There is no dedicated fraction key, but you can use the [MATH] menu to access a ToFraction command: symbolized by a fat arrow and Frac.
I am enclosing a few screen captures to help you figure out how to use your calculator to manipulate fractions. To get the first screen you press the [MATH] key (below the [ALPHA] key. The ToFraction command is the first one in the list. The second item allows you to convert a fraction to a decimal number.
In the following screen I show you how to enter a fraction (division key) and keep it in fraction form, albeit reduced. Fractions are reduced to their simplest terms
In the last screen, I show you how to convert a fraction to a decimal number by making use of the ToDecimal command (last command line on the left, result is one line down and to the right.)
Feb 09, 2010 | Texas Instruments TI-83 Plus Calculator
Where is the fraction button
Press MATH to display the MATH menu. >Frac converts a decimal to a fraction, >Dec converts a fraction to a decimal.
Feb 08, 2010 | Texas Instruments TI-83+ Graphing...
Fractions
  1. Enter a numerator
  2. Press [/] for division
  3. Enter the denomoinator
  4. Press [MATH]
  5. Press [1:|=>Frac]
  6. Press [ENTER]
Keep in mind that the fraction that will be displayed will be a fraction reduced to its simplest form.
To convert a fraction into a decimal number Press [Math][2:|=>Dec].
Jan 27, 2010 | Texas Instruments TI-84 Plus Calculator
Can't find fraction button.
There is no fraction button, but if you divide two integers (whole numbers) and want to keep the result as a fraction press [MATH][1:|=>Frac] [ENTER]. If the fraction can be reduced to its simplest form that is the result you will have.
27/48 [MATH][1:|=>Frac][ENTER] displays 9/16
Hope it helps.
Nov 18, 2009 | Texas Instruments TI-84 Plus Calculator
I don't know how to use fractions
Enter any fraction as a division problem and your TI 83 will evaluate it as a fraction.
For instance, 3/4 = three fourths.
Nov 13, 2009 | Texas Instruments TI-84 Plus Calculator
Fractions on my texas tI-83
You get access the command by pressing [MATH][1: |->Frac].
If you want enter a fraction and keep it as a fraction (albeit a reduced one)
key in the number then the sequence [MATH][1: |->Frac]., then [ENTER].
Practice : 27/48 [MATH][1: |->Frac] [=] gives the reduced form 9/16.
While this fraction is still in [ANS] memory, you can press [MATH][2: |->Dec] [=] to get the decimal value 0.5625
Hope it helps.
Nov 01, 2009 | Texas Instruments TI-83 Plus Calculator
How to us a fraction on the ti-83 calculator? I have home work due on this tues. and i dont know how to put a fraction in on this calculator .
Ther e is no dedicated key to do that but ther is a command ToFrac noted as ->Frac. To access it use [MATH[1:->Frac].
Two ways of using the command.
1. You want to reduce a fraction to its simplest expression
27/48 [MATH][1:->Frac] [ENTER] gives the reduced fraction 9/16
2 You do not want your results converted to decimal numbers
(27/48) [x] (5/7) [MATH][1:->Frac][ENTER] multiplies the two fractions and gives a fraction as a result. 45/112
3. Your result is in decimal form and you want to cast it into a fraction. The conversion will be exact only for certain numbers. Results kept in fraction forms are more accurate than those represented as decimals.
Hope it answers your question.
Oct 10, 2009 | Texas Instruments TI-83 Plus Calculator
Where is the fraction button on the ti 83 plus cac. look like
There is no fraction button. Any division of two integers you do is represented as a decimal number. If you want your fraction to remain a fraction you enter it as follows
7[ / ] 19 [ MATH][1:ToFrac] [=] displays 7/19
If you want to convert a decimal number into a proper fraction press [MATH][1:ToFrac] .
Exemple 7/19 [ENTER] gives .36842105. If without doing anything else, you press [MATH][1:ToFrac] you recover 7/19.
There are limitations related to the number of decimal digits in the floating point number.
.3684 [MATH][1:ToFrac][=] gives 921/2500 but
.36842 [MATH][1:ToFrac][=] gives .36842 : it is not converted to fraction.
Hope it helps
Sep 16, 2009 | Texas Instruments TI-83 Plus Calculator
Computers & Internet Logo
426 people viewed this question
David Payne
David Payne
