Question about Cameras
Replacing front panel on rolleiflex 3.5f tlr camera
Synchronising timing & exposure gears of front panel with body.
Rolleiflex sl35 mirror stuck in the open position and shutter won't release to send the mirror back down.
Try this: Give the shutter button a few quick, hard pokes with your finger. Don't be shy, you've got to give it a few good jabs. This can get the mirror unstuck. It's helped me before...
Mar 10, 2014 | Rollei Genuine Slr Sl35 Etc Front Body Cap
Mamiya C3 film advance
Hi there,Here's a link to a PDF instruction manual of your camera body.
http://www.cameramanuals.org/mamiya_pdf/mamiya_c3.pdf
It is possible that the crank handle is missing, as it is a removable piece. Bring your camera to a camera shop and see if they have a box of old parts to replace it with. You can either use a regular round knob, or (if you're lucky) one with a crank on it.
Aug 01, 2012 | Mamiya Used C3 Professional Tlr Body...
I require a replacement shutter mechanisum located at the bottom of the main body
I would check Ebay for someone selling a camera for parts that you can harvest parts out of. Mamiya doesn't make parts for these cameras anymore, another option is to find a master machinist that can custom fabricate a part/parts for you. You can also check with camera repair shops that might be willing to sell you the parts directly so that you can install them yourself.
Repair shops:
http://www.keh.com/Repair-Center.aspx
http://www.camerarepair.com/
Other links that might work for a machinist:
http://www.skgrimes.com/
Nov 02, 2010 | Mamiya C330 F Professional TLR Film Camera
Dark, cloudy viewing 35-135mm Sigma lens
The problem sounds like the camera did not reset properly after the last exposure. Minolta deigned the camera to keep the aperture fully open except during exposure.
During exposure it snaps the aperture down to the selected opening, then opens it again to allow enough light for proper focusing. If it did not fully open the blades after the shot, much less light would pass through the lens. The viewfinder would be darker and look murky.
Most likely cause? Dried up lubricants in the camera.
Next likely cause? Teeth broken on a plastic gear.
Get it to a camera repair place. Get estimates first.
Dec 30, 2009 | Minolta Maxxum 7000 35mm SLR Camera
What model Rolleiflex would have serial number T2163332?
Hello. Your camera is a Rolleiflex TLR model with a removable focusing hood. It was introduced in 1958, It has the famous Tessar lens, designed by Paul Rudolph in 1902 when he worked for Zeiss. It is Bay size I.
If you would like to download the entire data base you may. Here it is:
http://www.rolleirepairs.com/models.htm
Nov 18, 2009 | Cameras
Rolleiflex 3003 Battery Pack
where i can find the battery back, for 3003 the batteries can refield
May 28, 2009 | Rolleiflex 3001 35mm SLR Camera
D300 Manual exposure problem
likely there's nothing wrong with the D300 - all that's happened is that its inadvertently been set into bracketing mode and hence it cycles through 3 or 5 or 7 different exposures each time it is activated!
Sep 22, 2008 | Nikon D300 Body Only Digital Camera
Continuos timed exposures
You may need to have the camera plugged into the computer and operated by the software that came with it. It might have a feature there called intervalometer.
Sep 13, 2007 | Olympus EVOLT E-510 Body Only Digital...
Cameras Logo
23 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
