Hello,my refridgerator seems to have a condensation proplem....the trays at the bottom of fridge fill up with water till its leeking on the floor then we know to dry it up...how do u fix this?? water is collecting on bottom of my refrigerator and seems to be coming from around the light area on top inside.
The condensate drain begins inside the freezer compartment behind the back panel and at the bottom of the evaporator coils. Every time the refrigerator defrost (about 3 times a day) the water needs to flow out the bottom of that pan in the freezer and into a plastic drain pipe to the bottom of the refrigerator into a pan on top of the compressor or side of compressor. Sometimes the drain is blocked inside freezer and there is a buildup of ice. But sometimes it is blocked near the opening that leads out of the fresh food compartment and then down to compressor tray/pan. If the blockage is near that exit then you will see a trail of water running down the back of the fresh food compartment and settle in bottom. The only solution is to slowly and carefully remove the drain pipe from the back and inside of refrigerator and clean it out. Let me know how you are doing on this and I will be here to help,Thanks Sea Breeze
It is a good idea to buy two good quality stainless steel thermometers and put one inside the refrigerator and one in the freezer. Any good restaurant supply store will have them. This gives you a better idea of how the temperatures in each compartments are being cooled.
