Question about World Wide Sourcing Dryers
Fan moterfs40m dbf0242
Fan moter will not work
1995 saab 900 blower moter doesn't work.
Is it manual fan speed control or Automatic climate control?
Feb 27, 2013 | Cars & Trucks
The blower fan on my AC/Heater isn't working properly.
check the capacitor on the moter or just replace 12.00 bucks. if it doesnt work you need new moter.
Oct 23, 2012 | General Electric GENERAL ELECTRIC...
No power to fan moter but moter runs fine
Heater fan moter or Radiator fam motor?
Dec 06, 2010 | 1996 Oldsmobile Eighty Eight
Moter does not come on I have checked the moter,
sounds like the fan is bad! they do go out
Jul 09, 2009 | Heating & Cooling
2004 gmc canyon fan moter for ac dont work
There is a fuse I would check first if you haven't tried that yet. They had problems with the switches in some of those vehicles. If you could take the control out and unpug then reattach the plug it may start working meaning the switch is bad.
You may have a bad fan motor. Do you have a test light to check for voltage at the motor itself?
Lastly, there is a resistor set that changes from low to high that may have one or more resistors burned out.
Dale
Dec 12, 2008 | 2004 GMC Canyon
Blower fan
it sounds to me like your blower moter resister or your blower moter switch are going bad both are right under the hood next to the blower moter one has 2 witers on it the other has 4 it usuley on the pass side right near the window
Dec 03, 2008 | 2000 Chevrolet Venture
Heater fan motor works itermitanly
it could be the wire behind the fuse panel itself or the plug that plugs into the fan check these with a 12 volt tester and you should be able to find the problem also check the fuses under the hood and if you have an owners manual check in there and see if any are listed and where they are located
Nov 21, 2008 | 2002 Lincoln Town Car
Dryers Logo
24 people viewed this question
Top World Wide Sourcing Dryers Experts
Dan Webster
Dan Webster
Are you a World Wide Sourcing Dryer Expert? Answer questions, earn points and help others
