Question about Easy VIA 8650 W8001 8 inch Google Android 2.2 Flash 10.1 Support RJ45 Gravity Sensor Tablet PC Silver
Touchscreen does not work after uberoid firmware flash
W8001 resistive no 2 points
How can update my hkc tablet
I suppose you want to update to a higher Android version. I advise against it if you are a novice. First, you have to find an updated version of the ROM for your tablet specifically. Then, you will have to use an appropriate software to flash the ROM into your tablet. There is always a danger of bricking your tablet when flashing.
Jan 20, 2015 | HKC 7" Touchscreen 8GB Tablet 1GHz Android...
I need to know how to Upgrade the Firmware for the Irulu 7" 4gb Mid Google Android 2.3 Touchscreen Tablet
if upgrade is available it'll be shown in setting>developer option
from there directly you can upgrade it
else cannot
Mar 05, 2014 | Irulu 7" 4gb Mid Google Android 2.3...
My tablet will turn on but it wont go past the android screen what to do and how to fix the problem. please help
I had this issue. Your firmware is corrupted. The only way to fix is to install Uberoid (latest version 12.1) which will bring your tablet back to life.
http://www.pandawillforum.com/showthread.php?15703-Universal-WM8650-Uberoid-v12-1-(CUSTOM-ROM)
Oct 10, 2013 | Android Tablets & eReaders
PC802 Google Android 2.3 8 inch Flash 10.3 External 3G Resistive Screen Tablet PC
Only the applications that are compatible with each Android system should appear in the Google Play Store pages. If you are installing from your PC, it will inform you of any compatibility. If you are installing apps from 'unknown sources' you will run into trouble and, will damage your system permanently.
May 19, 2013 | Easy PC802 Google Android 2.3 8 inch Flash...
What to do when your HKC tablet wont charge
I had this problem with 2 of these tablets. I got one of hem working by upgrading the firmware. They had an issue with angry birds and some other games not working which they resolved with this firmware update. Go to their web site and follow the firmware update instructions. I think it seems to be a software issue with the battery and not the battery itself. After I upgraded, the tablets no charges and plays angry birds. I do have another one that didn't work when I did this but it's worth a try. Here's the link for the download and instructions. http://www.hkcdigital.com/upgrade-your-tablet/
Apr 04, 2013 | HKC 7" Touchscreen 8GB Tablet 1GHz Android...
How to master reset or reinstall software for a WM8650 UBEROID tablet?
Try see my blog lol, you can see video how to reset your tablet.
http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
Feb 26, 2013 | Tablets & eReaders
How to fix a hanged/frozen/non responsive Maylong M-250 tablet
You need to reflash it with a new firmware via the Micro SD slot. Just did this for mine and now it works great. The tablet has the chip WM8650. Use WM8650 uberoid v121.
http://www.androidsoldier.com/2013/08/universal-wm8650-uberoid-v121-all-in-1.html
Aug 15, 2012 | Maylong M-250 Universal Tablet PC
To many pattern attemps
Here is the solution for identity korean tab
hang in logo..pattern lock.......
all you need is SD card..512mb and up..
format SD card in FAT 32
here is the flash files
extract this file and put in sd card
inset the SD card and power on your tablet
PUSH the reset button beside the usb
you will not see it flashing..
wait till astro boy or android boy pop up...
then erase the file at put this file again in SD card
you will see Korean character
do not touch anything..just wait for 5 minutes then it will reboot once more.
done.........your tab is working again..... :-)
Apr 19, 2012 | Wintec Industries FileMate Light 7...
Easy VIA 8650 W8001 8 inch Google Android 2.2 Flash 10.1 Support RJ45 Gravity Sensor Tablet PC Silver Logo
20 people viewed this question
Top Easy Tablets & eReaders Experts
Are you an Easy Tablet and eReader Expert? Answer questions, earn points and help others
