NO SCREEN START S WHEN PLUGGED IN & NO DISPLAY
  • 1 more comment
  • lunyworld200 May 22, 2009
    I have a problem,
    My computer turns on but nothing shows on my screen
  • Anonymous May 23, 2009
    fthth
  • pedrooke_8 May 23, 2009
    I've got a IBM FRU PN 33P0595 motherboard. When I turn it on, the sata-hd works, the cpu fan works... But I got nothing on the screen. Some people say it's a 'jumper'-problem... Please help me!!??
    Novelist:
    Champion:
  • 256 Answers
We need some information, in order that we can help you. Please give us more details as to what happens. Before we take responsibility, we have to duplicate the situation in our lab, so tell us all you know and the way it happened. Thank you!
<arzobconst@yahoo.com> My name is Constantin
Posted on May 24, 2009
I have a Sanyo DP46840 with vertical lines on the display when powered up. I have not hooked it up to cable however I plugged it in and it said no signal and with vertical lines through the letters
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 27, 2016 | Sanyo Televison & Video
Senpera 2 when plugged into amp lights up but no display screen shows
Contact Peavey toll free at 877-732-8391 or by email at customerservice@peavey.com,
Dec 31, 2014 | Peavey Electronics Peavey Sanpera 2
My xbox 360 causes my hdtv screen to crash and display colored static. It only does this on the 'optimal display' of 1680x1050. I plugged in my laptop on the hdmi and it worked perfectly. Is t
Try manually choosing lower resolutions in your xbox display settings. My Insignia HDTV does that when switching resolutions like on Hulu in between commercials and then back to the show but only for a second or so. Also does this when going from the loading screens to the game screens for a few seconds when playing the game Split/Second
Jan 10, 2013 | Microsoft Xbox 360 Console
Have a Gateway Notebook KAV-60 with a broken screen. Trying to connect to an external monitor without any prompts or commands, as I can't see the screen. With an Acer Netbook I just plugged in the
Make sure the vga cable is in tight on the kav-60 and the external monitor.
Try the keystrokes to toggle the display. Normally you would Press and Hold the FN function key located at the lower left on the keyboard then hit the key F1 thru F12 that toggles the display. The correct F1 thru F12 key to hit will have LCD/CRT on it or it will have the icon of a display. The display toggles in three stages ( laptop only, external only or both laptop and external).
Apr 29, 2012 | Gateway Computers & Internet
Display will not come on plugged in or not
The UPS needs to have a good DC Buss for it to work. Before you buy the new battery disconnect the battery & unplug it from the wall. Push the on button to reset the logic. You may see the display flash breifly. Install the new battery. Then plug in the UPS and turn it on and enjoy
Oct 20, 2011 | Tripp Lite Tripplite Omniplus 1000 LCD UPS...
I have 2 identical Dell monitors on vga splitter plugged into port on laptop running Win 7. The NVIDIA control panel will only recognize the 2 Dell monitors as 1 display + 1 laptop display. How can I set...
you will have to change the settings in the control panel to an extended desktop once you have this lead connected click start control panel display change display settings you should a no 1 and a no 2 with detect and identify keep an eye on the television screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended tesktop always click apply after making any changes
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! red x right click select reinstall drivers hope this helps
http://majorgeeks.com/SiS_UniVGA5_Graphics_Driver_For_Windows_7_d6264.html
Apr 11, 2011 | Impact Acoustics 2-Port DVI-D VGA Splitter...
My fridge was moved around in the kitchen & I have plugged it in at a different spot & now the freezer & fridge is not working. The lights inside the fridge go on but the digital screen is...
The compressor in a fridge draws a lot of amps on start-up and it could be you blew a fuse . Scoot the thing out and take off the back and then check the voltage going up to the display you could have jarred a wire loose which is what I suspect Look at everything and see ,its something simple I'm sure.Take voltage measurements to see if the compressor is getting what it needs and the display as well,in between the two is a control board and that is where the fuse will be found if no wires are off.
Mar 29, 2011 | Samsung Refrigerators
The screen isn't working...i plugged in a vga cable yesterday to use as a screen but it changed the settings a little bit. I went in and plugged the cable in today to change it back to the normal settings...
Try booting into safe mode (press F8 repeatedly while starting up computer). Once in safe mode, you should have display (probably at 800x600) and you can reset it to whatever and reboot to normal.
If your settings are incompatible with the monitor specs you get results like you are seeing.
Oct 27, 2017 | Sony VAIO VGN-N160G/W T2250Notebook
I plugged my monitor into another computer i have and the start up screen pops up but then it goes black and says " input not supported"
You need to set the video output of the PC to the native resolution of your monitor: 1440 x 900 @60Hz. You are getting the meaasage because the resolution is too high for the monitor to display.
Mar 16, 2010 | Acer X193W LCD Monitor
Computers & Internet Logo
243 people viewed this question
David Payne
David Payne
