Question about Panasonic LUMIX DMC-FZ200 12 Megapixel Digital Camera - Black
How t to take a panasonic FZ200 camera apart to dry it out
Why can't I set self timer to take 3 shots. LUMIX dmc fz200
as far as i know the fz 200 has only 2 option , instant and delay, i may be wrong on this, if your camera has an option to use a lcd timer remote ,you set the desired number of shots with delay
Jun 01, 2015 | Cameras
How do I take Panasonic fz150 apart that has had water intrusion
I dont think thats possible. Some parts might be permanently damaged. give it some time, otherwise contact Customer Support and/or get(buy) a new one.
Oct 02, 2014 | Panasonic Lumix Dmc-fz150 - Kit Digital...
Original software for
You fine all software on the Panasonic website. Just log in and use your own name when asked. Goto support and download the software and drivers you need.
Perhaps they ask for the type and serial number of you camera.
Aug 02, 2014 | Panasonic Lumix DMC-FZ200 - Digital camera...
How to set language on lumix fz200
Panasonic DMC-FZ200 change language setting
switch on and press menu/set button in set up scroll down until you see a symbol of a face with a speech bubble select this and then select the required language.
the manual
  • Panasonic Lumix DMC-LX7 Camera User's Manual Guide (Owners Instruction)
  • can be downloaded from the following site.http://www.camerauserguide.net/panasonic-lumix-dmc-fz200-camera-users-manual-guide-owners-instruction/14129
    i hope this was useful.
    May 28, 2014 | Cameras
    How do i set language on lumix fz200
    The manual never mentions how to set the language, so I think the models are sold in more than one language, depending in what country you bought it, it will have hat language. When you have a camera with the Japan language, I'm sure there will be no other language in it.
    May 28, 2014 | Panasonic Lumix DMC-FZ200 - Digital camera...
    Hi, I have just purchased the lumix fz200 and have been using it for a week. I went to take some pictures yesterday and when I turned the camera on, I could not see out of the LCD monitor or the viewfinder...
    Sounds crazy but just make sure yo have removed the lens cover. If it does not work then something is wrong with your Panasonic and i would immediately return it for a another new unit that works properly. You might want to check manual to see if you are doing something wrong but I don't think so.
    Aug 28, 2017 | Panasonic Lumix DMC-LZ2 Digital Camera
    Need software to download pictures from panasonic dmc FZ200
    You don't need any special software.
    The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
    Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can us any photo cataloging program such as Picasa.
    Mar 24, 2013 | Panasonic LUMIX DMC-FZ200 12 Megapixel...
    The camera is a Lumix Panasonic DMC-FH20 and went in to the water at the public swiming pool, it has not worked since then even though I belive most of the water is gone. I tried removing the screw on the...
    Hey Terry,
    The chlorine in the pool water is defiantly not a good thing to be in your camera.
    However, remove the battery (you should remove the battery as fast as possible whenever electronics get wet) and place the camera into a bowel or mason jar, then fill it up with dry rice. Leave to dry in the rice at least over night.
    The rice will draw away any remaining moisture.
    If I were you, I would take the camera to where you bought it, or to a local camera shop (where they do repairs etc) and ask them if you could try inserting a new battery into the camera. If it works, go ahead and buy the new battery. If not, then you may need to think about buying a new camera.
    Mar 07, 2011 | Cameras
    Panasonic LUMIX DMC-FZ200 12 Megapixel Digital Camera - Black Logo
    Top Panasonic Electronics - Others Experts
     Grubhead
    Grubhead
    Tom Chichester
    Are you a Panasonic Electronics - Other Expert? Answer questions, earn points and help others
