How to program tv without remote
I don"t have the original remote and the closed caption is on and i need to adjust the settings how can i do this on the tv or do i have to have a remote
  • 864 Answers
Some TVs have a set of buttons behind a door or panel on the front that will give you access to menu, arrow keys, etc.  You should be able to use those to make the changes you need.
Posted on May 20, 2009
How do you turn on the closed captioning?
U must have the tv original rmote.U have the tv original remote wright?Yes,look at the tv remote carefully for a button that said CC this button sit between the MTS and the DISPLAY buttons second row of buttons near the bottom of the remote.Pushes the tv remote CC button a couples of times u will get like CC1,2,3 so on 1,2,3 so on will give Closed Captioning if the tv programming offer it.If u don't have the tv original remote.Try website like Remotes.com to buy the tv original remote.I have one of this tv too.
Sep 14, 2011 | TruTech PVS31170S1W 17 in. LCD Television
I have a Sanyo TV DP32648 and the closed caption won't turn off. i don't have the original remote and even now have a programable logtech remote. how do i turn off the closed caption
You will need to have CAPTION button on the universal remote control to turn on/off the caption, if it does not have that function then you will need the original remote.
SANYO remote model GXBJ is needed for this TV.
You can get used one for $20 on EBAY or a lot more for new one at:
http://remotes.com/remotes/servlet/rs?a=gmi&smodel=DP32648&brand_pn=SANYO_DP32648&mode=large&v=1&uuid=A13140757813801
Aug 23, 2011 | Televison & Video
I have an Orion 19"
You usually need the original remote. The trouble with universal remotes is that they generally control only the basic functions of a TV (power, volume, channel) but not much else. Without the original, you often lose other functions. You can try the front panel buttons if yours has them. On some sets the on-screen menus allow you to access caption settings.
But are you sure the captions are coming from the TV? Sure, the TV is displaying them, but if you have a satellite receiver, cable box or digital set-top box, the captions may be coming from that device. This is likely to be true if the captions just mysteriously started and you don't have or aren't using the TV original remote. These devices often don't allow a TV's built-in caption decoder to work properly, so they provide captions themselves. You may have turned captions on using that device's remote. Check the menu for caption controls.
Jul 10, 2011 | Orion1934 19" TV
I have a panasonic TV. direct tv remote for a . while programming the timer, somehow closed captioning got turned on & i after hours of trying to get it turned off, NO LUCK. it's driving me insane!!...
I could do better with a picture of the remote. Closed captioning is usually a multi-press button, that is each press takes you through each of the four types of closed captioning and then off.
You can enable closed captioning on a DVD Recorder, it looks like the TV, but its only on the picture from the DVD Recorder.
If you have a PVR, you could have closed captioning on on that device.
Try tuning off everything else to make sure it IS the TV.
Turn on the menu and find the closed captioning settings and set to OFF.
Press the close captioning button on the remote (If there is one) and press CC repeatedly until it says OFF.
Try and control close captioning, timer and menus with the ORIGINAL remote and not a programmable one.
Programmable remotes are not always completely compatible.
Mar 20, 2010 | RCA Universal Remote Control
How to turn off CC without original remote27ms4504
Noway to turn off captioning right away without the original remote.But U can unplug the tv for an hour,tv well reset itself back to original setting.The Captioning will shut off buy itself.Because captioning reqiure CC buttion on orignal remote and must manually turn on and off.
Feb 08, 2010 | Philips 27MS4504 TV
Close captioning is on and there is no remote, other than the cable box remote - how do we turn it off
Without a remote for the TV or possibly a universal that you can program, you usually can't turn off CC..Please take a moment to rate my answer. Thanks...
Nov 24, 2009 | Sansui DTV2760 27" TV
Need to know how to put the tv on close caption
Captioned programs are marked in TV listings by "CC". so press the cc button on the remote and the closed caption option will be applied.press that cc button again to turn off the closed caption option.
1) Check the size and manufactured year of your television. If it was made after 1993 and is larger than 13 inches, it has a closed captioning system built into it. Otherwise, you may need to purchase a separate closed caption system, which are available at a number of online outlets.
  1. 2)Turn on your TV and access the menu for closed captioning. The precise location of the menu varies by television set. Most are accessible by pressing the "Audio" or "Set Up" menu on your remote, then scrolling down to the "CC" or "Closed Captioning" option. Check your owner's manual for precise instructions.
  2. 3)Turn the closed captioning option to the "On" position. It will then run closed captions for every program that broadcasts them. Newer sets may allow you to adjust the size, font and colors of the closed captioning letters to fit your individual tastes.
  3. 4)Tune to a particular program for a few minutes to make sure the closed captions are working. Note that while many broadcasts run closed captioning, not all of them do. If the captions don't appear, check your TV listing to ensure the program includes them.
  4. 5)If you're watching a DVd on your TV, access the DVD's "Set Up" menu. It should have captioned options, which allow you to show captions in English and possibly other languages as well.
  5. thanks.
Nov 11, 2009 | Televison & Video
How to turn off closed captioning without orginal remote?
well if it has a menu option go into menu then set up and change cc okay if does not have menu button try to find universal remote w/ menu option and try to change okay
May 18, 2009 | Insignia NS-RTV32 32" TV
There is a big black box blocking the screen and it will not come off. how do i solve this problem without a original remote.
Check your TV's closed-caption settings. You'll likely find it's set for TEXT mode. Turn off captions or set for CC1 or CAPTION 1 if you want to use the captions. Your trouble is due to the set blanking out a block on the screen where the text should go, but there isn't any text to display. Most TV remotes have a single button for caption control, so it's easy to get into text mode without knowing it. Then on channels where captions are being broadcast you'll see the box. On other channels or programs you don't see it.
Please take a moment to give this solution a fixya rating if it clears up your trouble, and thanks for asking here!
Mar 17, 2009 | Sanyo DS31590 31" TV
Closed captioning
I am sorry you don't. You will need the original remote. I have enclosed a link where you can see the original remote and order one if you want to. If you see the picture, there is a caption button on the remote to turn on and off the closed captions Good Luck. Here is the link http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=DS24424&brand_pn=SANYO_DS24424&mode=large&uid=11872683567810
Aug 16, 2007 | Sanyo DS24424 24" TV
Televison & Video Logo
669 people viewed this question
Top Televison & Video Experts
