Question about 90129 20 Ounce Windex Cleaner
I tried to clean my windshield with windex and it froze on how do I get it cleared off?
It is only 2 degrees outside
    New Friend:
    Problem Solver:
  • 10 Answers
Turn on your vehicle. Allow it to idle in order to build engine heat. Turn on your FRONT defrost. Let sit until aforementioned windex has melted. If inside of windshield, wipe with paper towel. If outside turn on wipers.
Posted on Dec 31, 2013
Clean document feed MFC8710
try windex or windshield washer fluid
Feb 23, 2013 | Office Equipment & Supplies
Toyota Camry 2004 Defroster fogs windows.
2 possibilities:
1 - HVAC External Drain Tube stopped up with dirt, bee nest, etc. Hard to get to w/out a car lift. Need to clear and drain HVAC box.
2 - Leaking heater core inside HVAC box. Moisture from defog will smell sweet and be hard to clean off glass. Requires Dash removal and AC service to replace Heater Core. Very time consuming and Expensive A-Freeze fumes are also lethal if inhaled.
Try Solution #1 First, Least Expensive, Non-Lethal Condition.
Oct 16, 2012 | 2004 Toyota Camry
Wiper fluid keeps freezing drained all old wiper fluid and put in rain x -25 and it still froze
Rain X should have alleviated the freezing problem assuming that you circulated enough of it through the tubing and through the nozzles before it froze again.
Maybe try to disassemble the nozzle and soak in the Rain X solution or warm water to unfreeze it.
Trace the piping or tubing to the place where the frozen water exists and eliminate the ice by warming it up.
You may take the whole vehicle to a heated garage and let it thaw out, then circulate the fluid by pushing the button or switch to operate the windshield wiper fluid pump.
Jan 14, 2011 | 2008 Chevrolet Tahoe
I have new blades, they do not wipe smoothly, they make nois as they wipe .they like hesitate, if its raining hard they work fine. e
Hi:
Often this problem is caused by a filmy build up on the windshield. It could be from any kind of natural source, but often you need to go to great lengths to make your windshield squeaky clean.
Try wiping down the windshield with a soft cloth, soaked in a mild detergent...Nothing abrasive.
Then after that, use a high quality glass cleaner solution, such as windex, and go from there.
Hope this helps
Oct 06, 2010 | Chevrolet Equinox Cars & Trucks
I have dirty headlight covers and want to remove them to see if they can be cleaned. I have a 2001 Impala
Novus products worked for me. There are three strengths. No. 1 is a general
spray cleaner. No. 2 is a fine scratch remover that requires some elbow grease.
I find rinsing it as I work it in helps speed up the process. The yellowing and
small scratches are caused by ozone and sand blowing in the air. This product
won't make it factory new but it will give a much better cleaning than any other
product I've found. I've saved many friend's the expense of changing their
headlights.
Don't use windex or dishsoap on headlight plastic. They have ammonia in them
and causes microsopic pitting and fractures in clear plastic.
I bought my Novus products on line, saved gas running around trying to find it.
Jun 18, 2010 | 2000 Chevrolet Impala
WINDSHIELD FOGGING UP INSIDE WHEN ITS SUMMER TIME. I NOTICE THIS PROBLEM WHEN THE WEATHER IS HOT(SUMMER TIME). MY WINDSHIELD WILL BE COVERED WITH LIKE A SMALL FILM AND IT GLARES WHILE DRIVING ON A SUNNY...
HI,
I think you are experiencing normal condensation,
try putting the heat and AC control to the position that blows a small amount of conditioned air up through the defrosters. This dries the windshield.
Good Luck !!!!!!!!!!!!
Jun 03, 2010 | 1998 Toyota 4Runner
Windshield wiper on car iced up during snow/driving could not see
You can usually avoid that by using a good quality winter mix washer fluid that resists freezing, making sure the wipers are cleared of ice before beginning the drive and using the defroster to keep the windshield warm. In extreme conditions you just need to pull over and manually clean the ice off by hand.(only do that where it's safe). There are also specially designed wiper blades that will also help a bit.
Jan 03, 2010 | 2000 Pontiac Bonneville
Air conditioner constantly running, not cooling house
Check and see if it is froze up. Check big line at outside unit for ice. check filter and replace as needed. Check outside fan to see if it is running. Wash out outside coil If fan and compressor are running and has hot small line at outside unit. If not froze up and coil is clean you will need to call in a pro. If compress over heated you may need to wait for it to restart if coil was dirty. Again make sure out door fan and or unit is running and clean.
Jun 29, 2009 | Goodman CKL49AR49 Air Conditioner
Cabin air filter
it;s under the cowl vent panel.
Cowl Top Vent Panel Removal
  1. Remove the windshield wiper pivot arm (17526) . Refer to Section 01-16 for the removal procedure.
  1. Remove the front door weatherstrip (20530) to access the windshield outside side moulding screws.
  1. Remove the five windshield outside side moulding screws and the windshield outside side moulding (03136) .
  1. Pull the windshield outside moulding (03144) from the windshield glass (03100) .
  1. Remove the three Phillips-head screws from the cowl top vent panel (022A68) .
  1. Remove the three plastic screws by turning them 90 degrees to unlock.
  1. Remove the six pushpins from the front edge of the cowl top vent panel .
  1. Lift up on the cowl top vent panel and disconnect the windshield washer hose (17A605) at the Y-connector.
  1. Remove the cowl top vent panel .
Mar 15, 2009 | 1998 Mercury Villager
90129 20 Ounce Windex Cleaner Logo
Top R3 Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a R3 Vehicle Part and Accessory Expert? Answer questions, earn points and help others
