Question about GE Spacemaker JVM1640SJ Microwave Oven
TURNTABLE WON'T ROTATE
TURTABLE
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 114 Answers
Turntable motor. Just check to make sure the wires are still plugged into the moto
Posted on Sep 23, 2014
2 Suggested Answers
Sagar Tech
  • 107 Answers
SOURCE: Turntable in GE Spacemaker does not work most times. If rotate manually, may work for a moment -- but won't stay on.
I think you have the worm gear worn. Even the motter is okay. It comes with all things together, so just replace the moter .
Thanks
Please rate me
Posted on Nov 13, 2011
My HB77LGB works fine but when using oven for 15 minutes the turntable jumps off the central pink cog
Seating the glass turntable can be tricky. After installing the turtable, rotate it slightly to confirm it is seated completely.
Jun 14, 2014 | Siemens HB77L25GB 900 Watts Convection /...
AEG MCD2664E-m - plate not turning
There is no separate fuse only for turntable motor. Usually there is two fuse, one in High Voltage section (instead fuse could be HV protect diode) and another one for 220 V (light, turntable motor, fun motor, display....). If light work normally then is turtable motor faulty.
Dado
Mar 21, 2014 | AEG MCD2664EM 60cm Built In Microwave &...
Smh9187 turntable quit turning
1) the cabinet need to open for repair the small motor can be defective.test it see the diagram
2) test the plastic drive coupling+ring and roller assembly if is working properly , test and fix it.
see the diagrams and pictorial
God bless you
Jul 17, 2012 | Samsung SMH9187 Microwave Oven
The glass tray in my microwave won't rotate
The turntable motor is defective and must be replaced to remedy the situation.
Apr 04, 2012 | Whirlpool Microwave Ovens
Turntable
The turntable motor will need to be replaced, a common issue.
Mar 17, 2012 | Sharp R-405H 1100 Watts Microwave Oven
Thanks
Please rate me
Nov 13, 2011 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
Microwave lights, clock, and everything works except when you press start, it just counts down like its cooking, but the microwave is actually not on. No hum as usual or plate rotating. It just counts...
Hi, one of the most common reasons why the turntable won't rotate is that the microwave isn't clean. The turntable guide and carousel can get sticky, preventing the turntable from properly moving. If you have built-on food particles or liquids, fill a bowl with 2 or 3 cups of water and 1 tsp. of liquid detergent and lemon. Run the microwave for about 3 minutes. Clean the microwave with a cloth, including the base of the turntable, guide, carousel grooves and microwave base. Your microwave turntable won't rotate if the grooves on the base of the turntable do not sit right on the carousel. Also, check the position of the turntable guide. Place the guide directly under the turntable. Remove the turntable, and then reposition it into the carousel grooves.
Motor The carousel motor is located beneath the base plate of the microwave. If the carousel isn't turning at all, check the motor. Disconnect the microwave from the power source, and remove the turntable, guide and base plate. Try turning the motor to see if it's just stuck. If it doesn't turn freely after a few seconds, examine the motor to see if it's burned out or corroded. Use an ohmmeter to see if the motor has continuity. If not, you must replace the motor.
Bushings The drive bushings are plastic components that sit underneath the cooking plate. Remove the plate, and examine the bushings. Use a magnifying glass if necessary to see if any debris is caught in the plastic. Clean the bushings, and reinsert the plate. Turn the microwave on to see if it rotates. If the bushings are extremely worn or if some of the plastic is broken off, you need to replace it, which is a complicated repair for consumers. Contact a service technician for assistance.
May 07, 2011 | Amana Radarange Microwave Oven
Turntable not turning - no microwave cooking
Could be a reset or fuse within may just have popped Beware of excessive internal Voltages when servicing...
Apr 20, 2010 | Neff B7740N0GB Microwave Oven
Trim Kit for Over stove GE Spacemaker 1800
i think i am having the same problem, i spilled a cup of coffee inside of the microwave as i was reaching to get it and the turntable stopped rotating since then. what do you think could be the problem and how could i fix it?
Oct 09, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
