Question about Avaya IP Office IP500 V2 Control Unit
Delayed dial tone when accessing a line from an avaya IP 500 in partner mode
SOURCE: avaya phone not working
Yes, check the wiring. Sounds like the blue pair isnt working at that jack.
What happens when you plug that phone into the extension port of the system?
Posted on Sep 17, 2008
  • 10 Answers
SOURCE: How to configure Avaya's IP Phone 5610?
Ensure the reachability of the call server from that port. To ensure the same, configure a laptop with the IP address and default gateway of the intended IP phone. Then try pinging the call server from the laptop.
If this works then the setting should work for IP phone too. Double check on the router IP address and Vlan ID configured on the phone.
Posted on Apr 02, 2009
SOURCE: How do I Change Tine on a AVAYA PARTNER 18D Phone?
Press Feature 00 (zero, zero) from station 10 or 11. Press left intercom button twice, press #103, and then enter time in military format (24 hr). Press feature 00 again. This is all done with the handset down.
Posted on Mar 15, 2010
SOURCE: programming manuals for avaya ip office 500
http://marketingtools.avaya.com/knowledgebase
Posted on Apr 14, 2010
SOURCE: Dial tone, can be called, hear caller, but caller cann't hear me.
The problem is likely either a conflict in compression or a speech path problem.
In Manager, is "Allow Direct Media Path" checked?
If so uncheck and reboot eh phone system, then reboot the remote phone.
Posted on Jul 30, 2010
Avaya Partner 18D Corded Phone...
Yes. Call forwarding is a feature provided by your telephone company, not a feature of any phone, and the procedure is dependent on the company. For some telephone companies, for example, you forward a call by dialing *72, waiting for a second dial tone, then dial the number to which you want calls forwarded. Please contact your telephone company for their exact procedure.
May 28, 2012 | Avaya Corded Phone avaparp18d
Call forward will not turn off, have tried *74 & *73 , have rebooted and turned off then on, call divert symbol still on and phone calls still diverted.
To set Unconditional Call Forward ON Dial "*72" for a dial tone. Dial the forwarding number followed by "#". Wait for dial tone. LCD will display "Call FWD Activated"
To Cancel Unconditional Call Forward: dial "*73" and get the dial tone, then hang up. LCD will display "Call FWD Activated
but, since you have tried those two, it could be that there might still be a different type of call forward option that is still ON, on your phone like Busy Call Forward and Delayed Call Forward 1. To Cancel Busy Call Forward: dial "*91". Wait for dial tone. Hang up.
2.To Cancel Delayed Call Forward: Dial "*93" for a dial tone, then hang up.
Let me provide you a link to the website which I used as a reference for your future reference.
http://www.grandstream.com/user_manuals/GXP_User_Manual.pdf
Apr 27, 2011 | Grandstream GXP-2000 IP Phone
Avaya / Lucent MLS-12D Partner MLS12D Display Phone - BLACK: when A user picking the Avaya phone up, user don't...
get more lines.
Or check Auto line select.
From ext 10 or 11:
press feature 00
press left intercom twice
press right intercom once
enter extension number
press **
then press the lines in the order you want them picked up (line 5, 4, 3, 2, 1 then the intercom )
press**
press feature 00 to exit programming.
When the extension picks, it will pick up line 5. If 5 is busy, it will pick up line 4 , etc....
May 16, 2010 | AT&T Lucent MLS-12D Phone
Lucent Partner 18D cant fully reboot itself
That one doesn't sound too good.
You could perform a reset through programming which should clear the scratch pad.
Thats done by entering programming on either ext. 10 or 11
Press feature 00 then the left hand intercom twice.
Next enter # 728, the display should say reset save all then reboot the system.If the problem is still there, then the processor is malfunctioning and will need to be replaced.
Dec 04, 2009 | Avaya Corded Phone avaparp18d
I dont get the dial tone when connected to the phone line. I connect a normal phone there is dial tone. Do I need to contact to my service provider to make work the IP phone?
I have been using Avaya for the past 6 months. I have faced similar problems. May be you can try connecting the phone in place of another IP phone and check if the problem persists. This can isolate the problem whether it is with the phone or the network.
For your reference I shall provide with the online manual.
http://support.avaya.com/elmodocs2/2410/16_300133_1a.pdf
And if you arn't able to find the solution in there, the probably you need to contact tech support.
Good luck !!!
Jun 30, 2009 | Avaya 2410 Corded Phone
Lucent Avaya Partner System Lost access to Voicemail
Obviously you lost your programming. Question is whether the unit is operational. Best thing to do is contact your local Avaya Business Partner for a repair.
If you tell me your location, I can recommend one.
Apr 01, 2009 | AT&T Lucent Merlin SP 34 Phone
Avaya 18D unable to make outgoing calls
Sounds like you changed your line selection. Changing line selection on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
enter **
press the lit line in the order you want the to be used, i.e. line 2 then line 3 then line 4 etc.
enter ** when finished with line selection
Press feature "00" to logout
Hope that helps
Mar 20, 2009 | Avaya Partner 18D Display Phone (315807BA)
I would like to forward all calls to my cell phone
Which system do you have? IP Office?
If so, at your phone, you need to set the number to forward to:
Press: *07*9xxxxxxxxxxx#
(where 9xxxxxxxxxxx, is the dial "9" access code to dial outand the number how you would dial it, followed by pound)
so for 555-111-2222...
*07*915551112222#
Once that is done, you need to turn forwarding on:
*01
To turn forwarding off:
*02
Upon entering the codes, you will get a double "blip" tone to confirm the acceptance of the code.
Dec 23, 2008 | Avaya 5400 Series 5410 Phone
Avaya IP Office IP500 V2 Control Unit Logo
Top Avaya Lands Phones Experts
george  peters
george peters
Shehu Pro
Shehu Pro
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
