Question about Exercise & Fitness
Avanti manual X Fit T220 momentum series belt is slipping, want to know how to tighten it.
SOURCE: how do I tighten the belt on my york t275 motorised treadmill?
http://www.yorkfitness.com/store/PDF/T275-INS_MANUAL_022005.pdf
Posted on Jul 30, 2009
  • 18 Answers
SOURCE: belt slipping have tried to tighten, just bought used
When the belt slips, it can be 2 different places. The trick is to look at the front roller when the belt slips. If the front roller stops with the walking belt, then the drive belt (between the motor and front roller) is loose and can't be fixed by tightening the walking belt. If the drive belt is slipping, it needs to be tightened or replaced. I need the brand and model number to help you further.
Posted on Mar 10, 2010
bwinton
  • 83 Answers
SOURCE: Treadmill is slipping. Already tried tightening
This sounds like either the drive belt is loose or the walking belt is old. First, check the tension on the drive belt. If the drive belt is not slipping, then walking belt may need to be replaced. I say may because without working on the unit, I cannot say that IS the problem.
Posted on Mar 19, 2010
bwinton
  • 83 Answers
SOURCE: belt is slipping
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
Posted on Apr 29, 2010
maxtreadmill
  • 832 Answers
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Posted on May 18, 2010
Belt slip on reebok edge 2.2 when wlking. Tightening fixed the slip but still slipped on running. Even with the hex keys at the tightest it slipped. I checked the belt on the motor and it looked OK?
Frequently Asked Questions - Reebok - Reebok Fitness
https://www.reebokfitness.com/.../FAQItem_-1_20101_30652_faq-tread
Jump to How can I loosen or tighten the walking belt? - ? Play this video Treadmills have two different styles of walking belt adjustment. To see which type ...
Reebok Edge Treadmill 2.2 - YouTube
? 1:49
https://www.youtube.com/watch?v=fWjbWV8f6wE
Aug 27, 2011 - Uploaded by redgoals
Reebok Edge Treadmill 2.2 ... and I feel when jogging im gonna fall off the end of it - I cant see a man using this at all - maybe just for walking.
running machine belt slipping? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 17, 2012 - i have recenty purchased a reebok edge series 2.2 treadmill but when i run in it the belt slips foreward then carries on the way it ... I sounds like the belt needs to be tightened. ... Walking belt on treadmill slips under pressure?
Jan 05, 2016 | Reebok Exercise & Fitness
Seat inca van 00 sdi 1.9 diesel.. tension polly came loose.. timing belt slipped.. I need to know how to reset it again. Where are the markings on the crank shaft and the cam shaft? Please attach any...
Timing belt set-up for a 2000 Seat Inca 1.9 SDi
1. Align the crankshaft timing marks on the flywheel / gearbox
2. Remove the valve cover
3. Lock the camshaft
4. Fit the injection pump locking pin
5. Loosen the camshaft gearwheel bolt, 180 degrees. Use a wrench to counter-hold
6. Loosen the camshaft gearwheel while holding it in place
7. Fit the timing belt in the sequence as shown in the below figure: a - b - c - d - e - f - g
8. Fit the timing belt and camshaft gearwheel together
9. Turn the tensioner clockwise to align both marks
10. Tighten the large bolt on the tensioner to a torque of 20 Nm
11. Check for correct fit
12. Lock the camshaft. Tighten the camshaft gearwheel bolts: 45 Nm. Use a wrench to counter-hold
13. Remove helping tools
14. Turn the engine two rotations by hand
15. Repeat the procedure if required
16. Fit the vacuum pump
17. Refit the crankshaft pulley. Tighten torque: 20 Nm + 20 degrees
18. Fit the timing belt cover
19. Refit the valve cover
20. Fit the ancillary drive belt
21. Refit the inlet air manifold hoses
22. Check the injection timing
Torque settings:
Camshaft gearwheel: 45 Nm
Tensioner pulley: 20 Nm
Crankshaft pulley: 20 Nm + 20 degrees
May 26, 2011 | Volkswagen Passat Cars & Trucks
My vacuum makes a really loud noise when I turn it on. It was working and now it smells like something is burning. I check the belt- it looks ok.
The belt may look okay but it still can be stretched or worn and can be slipping on the motor shaft and thats why you have the burning smell. I would try changing the belt. Here is a link to the manual and a link to the belt you need:
Bissell Momentum User Guide (PDF)
Bissell Momentum Replacement Belts
Oct 31, 2009 | Bissell Vacuum - Momentum Cyclonic 1 ea...
Kenmore 90 series dryer screeches when starts
The likely cause is your belt slipping. The reason it is louder when you start is just that...It pulls harder to get the tub rolling and as it gains momentum the belt doesn't have to work as hard. Your belt is worn and will eventually break. When it slips, it is wearing at a greater rate, so you may want to go ahead and replace it.
Jun 21, 2009 | Kenmore 63942 Dryer
I need help adjusting the belt on the trimwalk manual treadmill
May 13, 2009 | RTO 9002 TrimWalk Trim Walk Folding Manual...
My treadmil is slipping and I can not find an online manual.
Apr 04, 2009 | Exercise & Fitness
Belt slipping
Here are two solutions one is to get the belt centered on the treadmill and the other is to tighten the belt.
There should be two bolts in the rear of the treadmill, one on each side. These bolts adjust the rear roller of the treadmill. The walking belt will always go to the side that is looser. To get the belt back on track, (if you can start the treadmill so the belt is running) tighten the bolt on the side that the belt has slipped to. Tighten the bolt a little bit at a time. If you tighten the bolt too much, then the belt will go to the other side.
Mar 12, 2009 | Exercise & Fitness
Belt is slipping, even on the lowest power.
As far as the manual, I have not been able to found it anywhere yet.
Jan 22, 2009 | NRS Stex 8025TL Attachable 17 Inch Lcd Tv...
Squeal that sounds like belt spippage
The motor slides back and forth so there is know way to tighten the belt.The new  belt is needed if your old one shows any ware or if has shiny look to it which would mean its been getting hot and slipping.
May 16, 2008 | Maytag Legacy Series Top Load Washer
Miele T220 drum doesn't turn
sounds like belt may be slipping .. check idler pully for tightest against belt .. belt may be streached and need replacing
Oct 14, 2007 | Miele Novotronic T220 Electric Dryer
Exercise & Fitness Logo
41 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
