Question about Samsung SyncMaster 753S 17" CRT Monitor
Color of edges turned into green
The color of edges is very bad although the center of the monitor colors is very good as normal.. what is the problem ? and is it relate to 4R5Q KSMC2 ? Thanks in advance
  • Abd Elrahman Lotfy
    Abd Elrahman Lotfy Jan 01, 2014
    no its not the resolution..i think its damaged because of magnetic field..only the edeges is the problem but the middle of the monitor is ok
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 113 Answers
Check out your \Display\Screen Resolution It my be that it is set wrong
Posted on Dec 31, 2013
techman
  • 3130 Answers
SOURCE: Blinking power button
It could also be because there is a problem with the display controller in the computer. Try to hook up another monitor to this computer and see if it comes up. If it does not work with another monitor, the computer will need servicing. If the display does come up, the Samsung monitor will need service. Good Luck
Posted on Jun 20, 2007
SOURCE: Monitor color dominated by blue; Green and red colors fade away as yellow and black
probly just the chord connectin from your pc to the screen. just buy a new chord.
Posted on Jul 29, 2007
Benimur
  • 6966 Answers
SOURCE: colors
Hi, This sounds like a color driver problem with the RED. I will assume that the blue is good since yellow will only be present if the green and blue are both ok. Below is a copy of my response to a similar post at http://www.fixya.com/support/t181021-zenith_a25a11d_no_red_color "...If you are comfortable working with a soldering iron, a continuity (VOM) multi tester and a fair knowledge of electronic components, then perhaps you can repair the missing color red. You have to open the unit, expose the small printed circuit board that is attached to the small end of the picture tube. There will be many components present but you will need to focus yourself on three (3) transistors that are bigger than the others sometimes with an aluminum heatsink. It is also possible that instead of 3 transistors you will have one power IC. In any case these control and provide the drive for the 3 colors of your picture tube: red, green and blue. One of them is either dead or suffers from cold solder to any or all of its pins/legs. You have to visually inspect the solder joints of these big transistors/IC and determine if any is dull in color, loose of simply not connected. You may even try the shotgun approach and solder each of the pins/terminals/legs just as long as you don't cross solder creating a short between pins/legs. If this works, you're set, if not: You have to check with the use of the VOM and determine which of the 3 transistor is defective. If you are familiar checking continuity of base to collector to emitter and reverse, again you're set, if not perhaps you check all three and compare which have the same reading from the same position and which is different. Pls keep in mind the transistors have forward and reverse bias readings. If able to determine defective component, desolder, replace and solder. If it were an IC, replace the entire pack. If the above would make you uncomfortable, pls ask for the services of a qualified TV repair man and explain your problem..." Hope this give too an idea. Good luck and pls post again how things are or if you need further information. Kind regards.
Posted on Aug 20, 2007
stabelabel
  • 51 Answers
SOURCE: Samsung SyncMaster 730B monitor green color problem
video controller card has gone bad need new video controller card.
Posted on Mar 16, 2009
  • 84 Answers
SOURCE: My monitor's color is mixed with the color yellow
There is an option on the monitor to reset colour to factory default. Just bring up the on screen menu by pressing the left most button at the botton. Use the button next to this to highlight the colour settings which I think is the 5th or next to last option down. You will then see the option to reset colour and various other factory default settings. Happy computing
Posted on Jul 21, 2009
Can't red and green colors
This usually means the red or green or both primary color module is bad. Monitors come with 3 primary color module controllers and they use them in various combinations to make the other colors. The primary colors are blue, green, and red.
Sep 17, 2010 | NEC AccuSync 900 19" CRT Monitor
When turn on color is great..after a few minutes turn blue and green
Sounds like the lcd is bad but here is a way to verify that. Hook up a known working monitor to the computer, if the colors stay great after a few minutes then you know the original monitor is good.
If the colors turn blue and green after a few minutes with the working monitor then you know for sure that the video card is bad and the video card would need to be replaced.
Aug 23, 2009 | Vision V1721B (Black) 17 inch LCD Monitor
Yellow/green tint moving toward the center of the screen
Bad news the blue uv cut filter is discoloring its in the optical engine.
You are one of the many sony tvs that have this problem.
GOOD NEWS - sony will pay for yours
http://esupport.sony.com/US/perl/news-item.pl?news_id=115&mdl=KDFE42A10
Thanks
scott
May 08, 2009 | Sony KDF-E42A10 42 in. LCD Television
Color problem MAG Innovision 14" monitor
1. try to connect to another computer . if it is fairly good then it must be your computer is having a problem.may be your video card problem.
Mar 21, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
Hitachi 57SWX20B 3D Effect due to green light convergence problem
I'm trying to fix the issue on my 43FDX20B. So far, I'm able to move the lines up and down, but can't get the left/right motion to fix it. The attached link has the dynamic mode instructions, so you can correct this issue yourself.
http://home.comcast.net/~leebailey00/Hitachi_DCAM_Manual.pdf
The only thing I didn't have was the screen overlay jig the manual talks about. I decided to create one myself and use the screen as a beginning template. I went to our local hardware store and picked up some home window weather covering. The roll cost about $15, is a clear strong plastic and the template was very easy to create. I used a straight edge after I put dots on the plastic and measured the lines for being square and equal after I took it off my tv. Good thing is that if you don't like what you make the first time, you have a 25' roll to use to try again (ha).
Mar 01, 2008 | Hitachi 57SWX20B 57" Rear Projection...
Green shadows in dark scenes
You should contact Service Center to resolve this issue.
Jan 22, 2008 | LG RU-42PX11 42 in. EDTV-Ready Plasma...
Greeen!!!!!!!!!
You can try to Degauss the monitor. It still sounds like the video cable is bad. That last part you mentioned about the OSM (on-screen Menu) having normal colors comes from the monitor and has nothing to do with the cable or pc. That tells me its the video cable, or the video cable connector (pins maybe bad) or a bad connection somewhere. There could be a bad connector inside the monitor where the video cable is attached to the electronics board. Sometimes those contacts just get oxidized and quit transmitting a signal. They need a good cleaning.
Jul 01, 2007 | HP Pavilion M703 17" CRT Monitor
HP f1903 LCD Monitor mild flickering & color variance
I would bet it is the cable or connection. Have you tried connecting the monitor to a different PC?
Feb 14, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
Samsung SyncMaster 753S 17" CRT Monitor Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
