Question about Galt Horrible Science Scary Sand
Instructions for scary sand
Instructions the box didnt have them grrr
Instruction book
The instructions for using the manual clutch and transmission should be contained in the normal vehicle handbook. It is not something that can be easily duplicated here.
Stick shifts aren't scary. It is autos that are scary to us because virtually all cars here are manual. Those who take their driving test in an auto aren't allowed to drive manuals but that is as scary as it gets.
Mar 15, 2015 | Cars & Trucks
How do I connect a Wii to a Sanyo tube? It does not havethe red, white, yellow RCA connections
All we comes with this cable but if you not have RCA connection
which is Red Yellow and Blue ,Than you have a scary connector which is full of small pins you can use that normally in your WII box you will find a scary convertor if not you have to buy one.
Thanks
Jul 07, 2014 | Video Game Consoles & Games
Right margin starts out ok, but after typing in the middle of the page the margin will not return, have to turn the machine off and on for the margin to return to normal positiion
Your pulleys and rails and motor are gummed up, and need cleaned and lubricated.
The machine will loose it margins because it thinks it moved but didnt. Probably makes a grinding, grrr noise. When you turn it on and off it resets, thats why you can type a bit more.
Oct 23, 2013 | IBM Personal Wheelwriter 2
2005 Yamaha FJR 1300 glove box won't open
Hi, Dbensky for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2005 Glove box problem
Glove box gets stuck grrr FJR Specific Discussion
Yamaha FJR1300R Service Manual
OEM parts for Yamaha
Yamaha FJR1300R Owner Manual
Jul 01, 2011 | 2005 Yamaha FJR 1300
Received this sand pump. However there were no instructions on how to put it together. Shows it already together but it was sent apart in two boxes! HELP
They're all about the same. Skimmer outlet goes to pump inlet. Pump outlet goes to filter inlet. Filter outlet returns back to the pool. You will have to fill it with sand. Look at link: http://www.propools.com/instructions_index.php Most any of these instructions will work. Pay attention on how to add sand so you don't break the "spider" piping in bottom of filter. I usually have water in first to absorb the shock of adding sand. Don't let sand enter the stand pipe in center of filter. Cover with plastic cup or something.
Jun 30, 2010 | Sta Rite 21" Sand Filter 15HP Pump
Mixing formula for concrete garage floor,concrete,gravel and sand
There should be mixing instructions on the bag of concrete, but it is 1 part cement, 2 parts sand and 3 parts gravel.
May 24, 2010 | RTO M-D Building Products Carpentry &...
How do i solve a sticking accelerator on my 99 nissan pathfinder..... most times i have to stab at it, and then it jumps dangerously....... Scary!!!!!!!!
where the throttle cable meets the throttle body is a tiny set screw for idle adjustment. sometimes it gets gunked up. remove set screw and using a emory cloth sand edge of set screw. remember to mark where the set screw is before removing
Nov 17, 2009 | 2005 Nissan Pathfinder
Purchased new, didnt have an instruction manual in box, need one, please help
Here is your solution :
http://www.generalmanual.com/Scanners/HP-Scanjet-N6310-Document-Flatbed-Scanner.htm
Thanks,
Mukund Ubhadiya
www.einfochips.com
May 25, 2009 | HP Office Equipment & Supplies
The touch screen on my dcr-dvd108 will not respond anymore...
mine did the same thing, and i tried to reset it but that didnt work, my warranty had ran out and i didnt buy the store warranty,so i pretty much gave up on it as it still didnt work. well my wife got it and was determined to fix it. she saw some sand in the corner of the lcd, and took some paper and cleaned it out and now its working again! lol it was just a little sand in between the lcd and the lcd case causing it not to respond. try that or try some canned air to clean out the screen.
Feb 26, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Galt Horrible Science Scary Sand Logo
Top Galt Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Galt Toy Expert? Answer questions, earn points and help others
