Question about Performance Teknique ICBM-770 Peformance Teknique Mono Channel (1200 W atts Max Power) Car Audio Amplifier
How do you get more power out of the amps
On the perfamance teknique amps is level supposed to be the gain.Is it clockwise or counterclockwise to get more power.
    Novelist:
  • 150 Answers
Clockwise should be more power
Posted on May 20, 2009
Clipping always lit
  1. Make sure nothing is plugged in.
  2. Turn the GAIN, LEVEL, and FX knobs for each channel, counter-clockwise all the way.
  3. Bring the MAIN fader all the way down.
If the signal LED's above the MAIN fader are still lit, then the board most likely has a short in it and will require repair.
If the signal LED's are dark, repeat the following on each channel...
  1. Rotate GAIN clockwise until the mark on the knob is at "12 oclock".
  2. Rotate LEVEL clockwise until the mark on the knob is at "3 oclock"
  3. Raise the MAIN fader to "0".
  4. Check LED's - if they light up then the channel you are working on is "noisy" or has a short in it.
  5. Return GAIN, LEVEL, and MAIN to "all off".
  6. Repeat with next channel.
Jan 25, 2014 | Behringer Xenyx 1202fx Mixer 12 Input 2...
Amp works on low side and full no high side
high level inputs are for speaker level inputs.Like if you used speaker wires right off your radio for input.Low level inputs are rca type inputs
Dec 19, 2012 | Performance Teknique Icbm-770 Monoblock...
88 ford f 150 - where can i find the spark plug wiring diagram- I have the book but it doesn't mention it. And what is the firing order
300 straight six 153624 distributor rotation clockwise, 232 v6 142536 distributor rotation counterclockwise.
255/302/360/390/460 15426378 distributor rotation counterclockwise,
351 & 400 W & M 13726548 distributor rotation counterclockwise.
Jan 14, 2011 | 1988 Ford F 150
Cobra cb brand new and cant get it to work
get your swr checked by a cb shop. 90% of all cb problems are a poorly or not tuned antenna.
Sep 15, 2009 | Cobra 29 LTD CB Radio
I have a pioneer gm-x 304 amp. I want to know what are the lpf-off-hpf switches for< and what sdhould I set the input levels to?
Hello packs6,
The lpf-off-hpf switches control the "low pass" and "high pass" filters. When driving full-range or component speakers the filters are usually operated in the "off" position to send all frequencies to the speakers. When driving a subwoofer, the best position is "lpf". If you have a separate amp to power a subwoofer, this amp can be used just for the high frequencies by putting the switches in "hpf".
Input levels should be adjusted to match your receiver output. You don't want the levels so high that distortion results. But you want it high enough for the amp to be able to produce maximum output. Start at about midrange and adjust the receiver volume to a little higher than a comfortable listening level. Adjust the amp gain (level) counterclockwise until you begin to hear the speakers distort. The turn the control slightly clockwise until the distortion disappears. That's the best setting.
Hope this helps.
Sep 02, 2009 | Pioneer Car Audio & Video
I have 2 perfomance teknique 700wts and i dont know what kind of amplifier use
Hello perezmagdiel,
That 700 watts is maximum peak power, not RMS. If you're looking to not spend a lot of money for an amp, but want something that sends enough power to the Performance Teknique's, I'd recommend a 2-channel like the Boss Diablo D400.2. It's plently powerful enough and if you change out later, the amp can be bridged. And for inexpensive, it's got a lot of nice features, including a remote level control. It's 2ohm stable in stereo. Nice, for under $70.
Hope this helps.
Jul 17, 2009 | Performance Teknique ICBM-892 Car Audio...
Audio system set up
Well one problem is you might need a smaller amp depending on how many speakers you have, 1200 watts is way overpowering for 300watt max speakers and could possibly blow them and even catch them on fire!!!! But everything else is compatable because all of your epuipment is of a newer products but if you dont have 4 guage wires or anything else make sure you get them heres a list: 4 gauge wires for power and ground, REM wire "blue is the normal color" RCA jacks, A compacitor, fuse for battery to amp to keep system from blowing up, 8 gauge speaker wire or even 12 guage to hook up from the amp to the speakers, That should be the common things you need to have a good thumpin system!!!!
Sep 12, 2008 | Performance Teknique ICBM-892 Car Audio...
Not enough power delivered
This sounds like a gain setting problem on your amp. The best way to adjust is to set your volume on the head unit to about 75% volume and then adjust the gain up until it sounds distorted a little. Back it off jst enough for the distortion to go away and you are set. Only other thing to try is use a multimeter set on Ohms to test the resistance of your speaker configuration. Looks like 2000 is th peak power (not RMS) and is only possible at high current configurations. You are probably running at 4 Ohms, but this amp only puts out rated power at 1 ohm stereo or 2 ohm bridged. Many people say Performance Technique are overrated, so maybe not even what it is rated at - 350 x 2 @ 2 ohms bridged (probably only about 175 x 2 at 4 ohms bridged)
Feb 06, 2008 | Performance Teknique ICBM-9540 Car Audio...
Car Audio & Video Logo
196 people viewed this question
Top Performance Teknique Car Audio & Video Experts
hoyzee1
Jose Velazquez
Jose Velazquez
George Nalley
Level 1 Expert
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
