Question about Emerson Microwave Ovens
Emerson 900W Microwave Oven model MW9998RD how to clear memory settings
Trying to clear memory settings from going to def mode
SOURCE: Emerson microwave 900w
i believe majority of emerson got programmin ERROR intheir KEYPAD.. my emerson microwave got similar issue ..its a brand new one abt few monts old..it started actin weird way ..its keypad wont work..tried many thing unplug it pluge it back in everthing tht necessary..but still keypad is locked..no not the child procted locked..it locked with a digits 00.00 ...sometimes it work sometimes it dont...so no clue wat to do ...
Posted on Mar 01, 2008
SOURCE: 900w Emerson Microwave Oven
model #: MW8992SB
Posted on Aug 16, 2008
najah
  • 180 Answers
SOURCE: Emerson Microwave Oven and Grill
The micro wave part is not working in your oven. It is mainly due to to the defect in the magnetron and the related components like high voltage side fuse and high voltage diode etc. you can check the fuse and the diode with a multimeter. If they are ok replace the magnetron.
Posted on May 24, 2009
  • 8404 Answers
SOURCE: 900E Microwave Oven Door Won't Open even after
Your latch has come apart inside the door or inside the oven. Probably a spring separated or broke.
Remove the cover --WATCH OUT FOR THE SILVER CAN - LETHAL -- and try to release the lock that way. I think you will be able to open it from inside but I also think your trouble is inside the door, though I dont have experience on this model. If the trouble is in the door, you will have to disassemble it. Look for hidden screws or a plastic strip which must be removed to separate the door halves.
Good luck in your project.
Posted on Oct 19, 2009
MicrowaveSvc
  • 9086 Answers
SOURCE: Emerson Model MW9325SL microwave oven looses power
It sounds like either a filter is clogged, an air vent in the back is blocked, or the internal cooling fan is not running.
We have a sound clip here of what a microwave should sound like when the cooling fan and high voltage section are working.
This overheating can happen if you put it in a cabinet or push it against a wall.
Many Emerson microwave owner's manuals are available for free download here.
Even though yours may not be there, there might be one close enough to help you.
For more help from Emerson
visit here or get help using your appliance at 1-800-898-9020.
Since it's new, it's under warranty, and any trouble you have should be taken care of.
Get help locating an authorized servicer or parts at 1-800-695-0098.
Posted on Oct 30, 2009
I have an Emerson 900W Microwave MW8999SB and it will randomly assign DEF1 and the rest of the keypad is difficult or not functioning. None of the quick buttons work, and only the 30-second button works....
Pressing the Clear/Pause button works. Sometimes. Most of the time, about a microsecond after pressing Clear/Pause, it goes right back to def1. Most of the time, pressing ANY button doesn't work. Usually takes me 10 to 20 tries to get anything to work. My microwave is about 3 months old. I will never buy Emerson again.
Sep 27, 2013 | Emerson MW8168B Microwave Oven
I have an Emerson 900W Microwave Oven, Model #MW8992SB. Def1 stays on continuously. When I hit "stop, clear" it beeps off and then beeps "Def1" immediately. Then eventually I am able to hit "1" or "start"...
So many microwaveso have issues because there are millions and millions of them. You need to study the booklet and set aside some time to explore it. Write down what you do and assess it. In about an hour you'll figure it out. Download the booklet! Ovens are similar with various timers. It gets complex owing to the size of the electronic controlsystem.but totally fixable!
Jan 15, 2018 | Emerson Black Microwave Oven
I have an emerson 900w microwave mw8999sb sn908003050mm. I have tried cooking in it and setting the timer at the same time to time something else that I am cooking. Can it be done with this type of...
The owner's manual is here, and it does not mention that as a feature.
One way to prove that is to press the "Kitchen Timer" pad while the oven is cooking and see if anything happens.
No modern microwave that we know of has this dual function, but it sounds interesting.
Nov 28, 2009 | Emerson MW8168B Microwave Oven
The oven sparks and gives a loud hum during use with plastic food containers. This scares my wife and mom terribly. I have an Emerson 900W microwave oven (model:MW8999SB).
It seems as though the container has a small amount of metal embedded in it ... don't assume just because it is plastic you can put it in the microwave.
Tip ... put just the plastic container in empty and try it. If the plastic get hot then it's the wrong type plastic for a microwave
Oct 02, 2009 | Microwave Ovens
Loud horrible beeper
It's a safety device, mounted inside.
Feb 12, 2009 | Emerson Black Microwave Oven
I just came on the internet to search the microwave, and mine is the 900W red version and i have only had it-well less than a year, and it just stopped. No noises, just stopped while i was defrosting some chicken. What the heck. Not cool.
Dec 17, 2007 | Emerson Black Microwave Oven
Microwave Ovens Logo
59 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
