Question about Wesco Talking Dalek Alarm Clock
How does it work?
I got the clock for christmas and unlike other clocks I've gotten, it just isn't obvious how to use it. I've played around with it an can't figure it out. It's fresh out of the box, and hasn't been modified in any way. Please help!
GE spacemaker range model number jmp28g0r1wh display goes blank and oven turns off
the model number isn't correct.check and send the model number again.if you changed the sensor this should take care of the f3 error code but the clock shouldn't go blank and oven stops.like i say your model number doesn't show up as a good number,if this machine has a fan in it you could have a bad fan motor,the fan cools off the electronics and if it isn't working the clock assy. can get hot,damage it and it will do this,also i've seen on some models there's a screen where the fan is and dust gets stuck on the screen and the fan can't blow any air,i'm just telling you what i've found before but it sounds like the clock assy. is heating up and shutting down,if there isn't a fan in your model it sounds like you have a bad clock assy.if you send the model number i can look it up for you.
Nov 15, 2011 | Kitchen Ranges
Trouble code 8001050F
Here’s what’s going on right now: something with the PS3’s internal clock has borked in some pre-slim models. This is not a PSN issue; it has to do with your PS3’s clock. This clock is NOT related to the OS clock. It seems to be a leap year bug. Setting your clock ahead will do nothing. All PS3s around the world were affected at the exact same time.
Does this affect me?
-If you have a Slim PS3, you’re good to go. Continue playing it as normal.
-If you have a “fat” PS3, you may be affected. Some fat PS3s have worked ok, but it seems a good majority have been bugged.
What does this bug mean?
-If affected, your date and time has been set to a random past date. This prevents you from signing into PSN, playing any PSN games, or using any DLC. Your trophies will also not display correctly or be able to sync.
How do I fix it?
-You can’t. Even if you don’t sign into PSN, it won’t help. This is a hardware issue.
So, what do I do?
-Wait 24 hours. Other products that have had similar bugs have corrected themselves after the “bugged” day. On Monday around 6pm central time, all PS3s will automatically correct themselves…maybe.
-If that doesn’t work, we’ll need a firmware update from Sony, which should be a pretty important priority for them right now.
Did I lose my data/themes/etc?
Your save data/games/dlc/themes are fine. They’ll be fixed when the PS3 is fixed. Trophies are uncertain right now, but they’ll be fine if you’ve synced them before the PS3 was bugged. Unsynced trophies are an unknown right now.
If I have a bugged PS3, can I still use it?
It’s probably not a good idea, as I have no idea what will happen to the trophies you earn during the bugged time. Movies/media will work fine.
How do I fix it?
So, what do I do?
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
Error code 8001050f sops me from playing fifa 10
How do I fix it?
So, what do I do?
My play station will not let me play any games. It says an error occurred during the start operation (8001050F).
.. Here’s what’s going on right now: something with the PS3’s internal clock has borked in some pre-slim models. This is not a PSN issue; it has to do with your PS3’s clock. This clock is NOT related to the OS clock. It seems to be a leap year bug. Setting your clock ahead will do nothing. All PS3s around the world were affected at the exact same time.
How do I fix it?
So, what do I do?
Jun 11, 2009 | Sony Playstation 3 (PS3) Console
Error messages 8001050F and 80010514 disc will not play
=-=- Here’s what’s going on right now: something with the PS3’s internal clock has borked in some pre-slim models. This is not a PSN issue; it has to do with your PS3’s clock. This clock is NOT related to the OS clock. It seems to be a leap year bug. Setting your clock ahead will do nothing. All PS3s around the world were affected at the exact same time.
How do I fix it?
So, what do I do?
May 09, 2009 | Sony Playstation 3 (PS3) Console
Oregon Scientific Radio controlled Thermo Clock RMR382A -
Check the channel mode that you are in. I play with the channel /memory buttons on mine and I finally get it to work. Sometimes it worksfor weeks sometimes just a day. Just glad I can get it to work - thought it was the remote unit but I was wrong.
Sep 03, 2017 | Oregon Scientific RMR-182A Clock Radio
Radio controlled clock won't set
it sounds like its working but its setting daylight savings time mine has an option to turnoff .that's makes scents if it always 1 hour off exactly.
Feb 15, 2008 | La Crosse Radio Controlled Atomic Clock
Will not play cd
just received by durabrand under the counter cd/radio plugged it in and all i get is static on both what can i do to fix it
Jan 24, 2008 | Durabrand W375-K Clock Radio
Wesco Talking Dalek Alarm Clock Logo
Top Wesco Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Wesco Audio Player and Recorder Expert? Answer questions, earn points and help others
