What channel number is 4kids on - Computers & Internet
    Problem Solver:
  • 6 Answers
Not sure if this still run on any TV stations block. It was on CBS, FOX, UPN, CW/WGN. your basic local channels.
http://en.wikipedia.org/wiki/4Licensing_Corporation
Posted on Jan 07, 2014
What does RF CH mean?
What is the difference between a RF channel and a virtual channel? The RF channel is the channel that the TV station uses to broadcast its signal. Before the conversion to digital, TV stations were normally identified by their channel number, and most people knew that a particular network was on a specific TV channel. While analog broadcasting was being phased out and all TV stations were converting to digital broadcasting, it was necessary for the TV stations to continue to broadcast their analog signals on their original RF channels, and also broadcast their digital signals on a different RF channel. However, since the TV station used their broadcast channel as part of their identification, they wanted to keep using the same channel number. To allow this to happen, the new digital television broadcasting standards (ATSC) provided TV stations the ability to continue to use their original channel number and also tell the TV set to tune to the new RF broadcast channel when their virtual channel number was selected. The original channel number is called the virtual channel number, and it will be followed by a period and a second number (3.1, 7.1, etc.).
One of the benefits of converting to digital for the TV stations is that they now have the ability to transmit more than one program at the same time on the same RF channel. The number of additional channels they can broadcast is determined by the resolution of the program (SD vs. HD, text only, music only, etc.). The second number in their virtual channel number indicates that one of the additional programming sources from the same TV station is being viewed (10.2, 10.3, 10.4, etc.).
When selecting an antenna, it is important to understand the difference between the RF broadcast channel and the virtual channel. Antennas are designed to receive specific ranges of RF channels, and the antenna needs to be selected for the RF channel you wish to receive. TV stations broadcast in two broad frequency ranges, called VHF and UHF. RF channels 2 through 13 are considered VHF, and RF channels 14 through 51 are considered UHF. In order to pick up the channels, the antenna has to be designed for the correct frequency range. It is very common today to find that TV stations using virtual channels 2 through 13 are actually using RF broadcast channels in the UHF range. Although not as common, some TV stations using virtual channels 14 through 51 are actually transmitting in the VHF range. An antenna designed for only UHF channels will not work effectively for RF broadcast channels in the VHF range, and an antenna designed for only VHF channels will not work effectively for RF broadcast channels in the UHF range.
Apr 09, 2015 | Televison & Video
Hi...juz wanna know wat wud be d possible solution for this tv problem. It lacks some channels and didnt respond correctly to the channel and its station. In other words besides that it lacks some channels...
HI. I guess you mix the expression channel with number. The "channel" is the division in "places" for each transmitter in the entire TV frequency spectrum. The "number" is just the preset number one gives to a certain channel stored in the TV. F.i. on can use number 50 to channel 4, which it the last channel in the lower VHF band.
When you to to "manual" tuning, and you select "4", then you may receive this channel, and assign it to any number you choose between 0 and the max presets possible. (mosly 99). After storing, you can choose another "channel ". It is also possible to choose in H or S. H are the regular B1, BIII, UHF channels. (rsp. 2-12, 21-69). The S band contains frequencies in between and above these bands.
Hope this explanation is of any help to you.
Oct 01, 2014 | Televison & Video
Channel numbers missing
local channels are usually below a channel 1000. they are always on same assigned channel. If your cable box or tv has it, it has option to not display channels with no service on them. you can't reassign the channel numbers. they are channels but not being displayed.
Apr 10, 2014 | Televison & Video
Missing cable channels
You need to contact your cable service provider about this, it is a signal issue not a TV issue.
Apr 24, 2017 | Samsung SyncMaster Televison & Video
How to block channel(50) sms
Pliz stop SMS my Number 9726494044
Sep 28, 2012 | Cell Phones
When doing an autoscan, we get channels that are .1, .5 etc. such as tbs is not channel 64, it is 63.5. How do we get the channels in the whole number line up?
Hello:
The TV channels that are found with decimal points are digital sub-channels. Broadcasters can include sub-channels of additional programming without requiring additional channels. Unless it is also broadcast on a "whole-number" channel, there is no way to change the number in your lineup.
Mar 05, 2011 | Dynex Televison & Video
Can only change the channel to single numbered channels.
Three dash option does mean it will look for three numbers. You would then have to put in three digits, so for example if you want to go to channel 31 then key in the numbers 031, for channel 42 key in 042, If you want a lower such as channel 8, then key in 008. Try this.
Aug 04, 2009 | Televison & Video
Mitsubishi 65513
Its on the way...good luck with the kids
Dec 11, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Programming
Most Regency Scanners have the same basic programming setup.
Try the following.
Press "Manual"
One of the channels will show up in the display, probably channel 1.
Enter the frequency you want to enter, example 162.550
Press "Enter"
The channel number will flash,
Enter the channel number you want to put that frequency in, example to put that frequency into channel 4 enter the number 4.
Note that on some models for channels 1-9 you must enter the channel as a 2 digit number so enter 04 for channel 4.
You can repeat this process to enter all the frequecy's you want and just change the channel number.
Also check out
http://www.w7fg.com/index.html
for scanner and old radio manuals.
from WikiAnswers
good luck
-voodoomox
Dec 06, 2007 | HP PSC 1410v All-in-One Printer
Computers & Internet Logo
David Payne
David Payne
