Question about Mr. Heater Portable Kerosene Heater - 175,000 BTU
My heater does nothing
Lite is on the power switch nothing happens
Heater turns off windows dont work and blinker relays dont work when driving
Try unhooking one of the battery cables and leave it off for at least 20 minutes. When you hook it back up the computers should re-boot. That has solved problems for me with heater, interior lites, power windows, AC, day time running lites, power mirrors, CD player, and wipers on GM autos and S-10 PU and Dodge trucks. None of the switches are connected to the device they control anymore. The switch tells the computer to open the window and the computer send a signal to the window motor. When the computer gets confused strange things will happen or not happen. Of course you may have to re-set your radio stations.
Sep 03, 2010 | 1999 Lincoln Continental
The burners will not ignite
if the unit is used you might have to removed the burner and clean the pilot sometimes rust built in the hole and need to be clean out. I had the same problem.
Apr 11, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
When you switch ds lite on green light comes on but nothing happens on screens dont l[ght up could anybody give some advice on how to fix
it sounds like it could of been overcharged this happens alot when the battery is over charged or a game is ejected with out powering down
Dec 11, 2009 | Nintendo DS Lite
I would like to test my goodman before i hook it up to gas i have red light with power applied when i short the thermostat wires nothing happens can you help
Yes! make sure the door is on the unit to close the power switch first and observe the cycles. This should be a 4-step cycle, #1, vent fan turns on.... #2 the pilot lites ups.... #3 the gas valve sends gas to the gas ports to heat up the box...& #4 the main fan should comes on!T Y V M !
Dec 09, 2009 | Goodman GMS90703BXA Heater
When i turn on the heater nothing happens i replaced the igniter on 6/22 and it worked ok i turned it on the other day and it run for a little then it quit. it is like it has no power what and were can i...
1st place i would check is pressure switch.this component is number 1 in failure frequency.depending on your model,it is either screwed into in/out header or behind front panel. check for continuity(with pump running) using multi-meter.
Aug 21, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
My heater will not ignite. The pilot is on but
The gasvalve has a pilot solenoid which is powered by in essence a thermocouple called a thermopile which converts heatfrom the pilot to to a millivolt output which is why you have to hold the pilot valve till it makes electricty. The main gas valve goes through a series of safety switches and through the thermostat so if any switch has a badoropen contact the heater will never fire find the bad part with a continuity tester and replace it.
Jul 18, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Won't fire
It may also be the high temp switches under the 2" inlet/outlet header. The 150 degree high-limit switch sits horizontal and corrosion happens often there. But be careful removing as if the header is corroded and the switch is also, water will flow out , so be ready to bypass the heater. You will have to replace the header. Try to jumpe that switch out and I'll bet the heater fires up.
Jul 10, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Laars Lite heater not working
1st time this happened to me the filter wasn't clean. 2nd time it was the pressure switch and for the third time they say I have to bleed the gas line, not enough gas to lite. And I also need the on/off switch gone bad.
Jun 08, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Dead Reddy heater 170T
When chaning the filters, did you clean out the flame chamber, a lot of carbon and suot will build up inside and cause the unit not lite.
Feb 14, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Mr. Heater Portable Kerosene Heater - 175,000 BTU Logo
56 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
