Question about Amana DLE330RAW Electric Dryer
Dryer does not turn on
I have an Amana Electric Dryer.  The dryer stopped heating so we opened the front to check the heating element which was fine.  We noticed a wire was burnt into on the electric cord so we replaced the cord.  When we tried to start the dryer it would act like it wanted to start until we let go of the button, then it would stop.  We noticed in putting the dryer back together a metal clip was on the inside of the drum (holding it) instead of on the outside.  Now nothing.... We replaced the thermal fuse and the receptacle on the back for the plug.  The light inside the dryer is now coming on but will not start.  So we are getting power now but nothing else.  Any suggestions?
  • 196 Answers
Sounds like the motor relay is not functioning. Sometimes the motor will work if the button is pushed but will stop when the button is released. This is caused by a loose wire at the motor or a bad motor relay.
Posted on Jan 26, 2008
I do not have any heat, but the tumbler works. this is an electric dryer. i looked in the machine and it looks like it will not be easy to get at the element. i had and older dryer and the front came...
If you look at the back of the toob when the dryer is running you should be able to see if the elements are turning red.In order to do this you will have to defeat the door switch(be careful, don't stick any part of your body in the dryer).
You may want to check your vent,if they stop up the dryer elements will shut off on high temperature.
Mar 02, 2011 | Amana NED7200TW Electric Dryer
My Amana Drier Model LE8407W2 stopped heating (everything else works fine). After checking the vent, I have decided to examine the heating element but am having difficulty accessing it. I have removed...
Most dryers are designed to be repaired from the rear. On the rear probably the whole back panel unscrews. Giving access to the duct where the heating element is located. Make sure to have the dryer unplugged while servicing it to prevent getting electrocuted. Your heating element will be inside of a metal duct that feeds hot air into the dryer remove it and inspect it for breaks in the coils of wire or burned areas. Having a good volt meter that checks continuity is a great tool to check dryer parts. There are several over heat sensors that can go bad over time to and can prevent the dryer from heating. These sensors and the heating element can all be checked using the volt meter on the continuity setting. Having a cell phone on hand helps to take pictures of wiring and connections inside the dryer before unhooking them to aid in reassembly. With sensors or element unplugged and a volt meter on continuity setting touch the red probe to one side of a connector and the black probe to the other side if there's no numbers or a beep on your volt meter suspect that part bad. I have fixed several dryers this way. Hope this helps you.
Jan 17, 2018 | Amana NDE7800AY Electric Dryer
Replace electric heat element in Amana dryer
You can find an exploded view of the dryer on Looks like you access from the rear service panel.
Dec 11, 2009 | Amana ALE643RB Electric Dryer
Amana Dryer model # LEA60AW. Dryer runs but no heat.
check the heating element and the high limit fuse
Jul 10, 2009 | Amana ALE643RB Electric Dryer
No heat coming from Amana Dryer
2 screws at the bottom of front panel if no screws there, then pry top off with wide flat screw driver then look inside toward top of front panel remove two more screws and the front should lift right out then remove screw/s in center of drum and lift out of cabinet there should be your heat element
Jan 17, 2009 | Amana NDE2335AY Electric Dryer
My dryer wont heat up...It just blows cold air....?????
It may be the thermal fuse but it could also be the heating element. The way to check is to open it up as described above and run the dryer. Watch the element and if it turns on then off again immediately then it is your thermal fuse. That is only about 15 dollars to fix and you can get a new fuse at any appliance repair shop. If the element doesn't ever come on then the element is burnt out and needs to be replaced. This is a little more expensive. I hope this was helpful and if you have any more questions feel free to ask me. Good luck.
Dec 31, 2008 | Whirlpool GEW9250 Electric Dryer
Amana electric dryer model LEA30Aw will not heat
The heating element measures 10 Ohms at 68 degrees farenheit. Usually if the element is bad, it will measure infinity.
Dec 24, 2008 | Amana Dryers
sounds as if the motor is overheating, shutting off and not restarting for 10-20 min??? if thats the casse sounds as if yooull need a new motor assemly
Dec 03, 2008 | Amana NDE2330AY Electric Dryer
Probably the heater element. You need to pull the back of teh machine off and check the heating element for continuity. If its open then its shot.
These are parts that normally go bad.
Check on ebay these can be had for less than 50.00
Oct 03, 2008 | Amana ALG331RAW Gas Dryer
Amana DLE330RAW Electric Dryer Logo
189 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
