Question about Konica Minolta Bizhub C364 Color Copier / Printer / Scanner
Tray 3 cannot connect
It won't let me print from tray 3
  • Norman  J Weimar Jr
    Norman J Weimar Jr Jul 04, 2016
    Hi Trish , I want to help you with your question, but I need more information from you. Can you please add details in t
    he comment box?
    Trish is tray 3 displayed on the machine
Kevin Hayes
  • 167 Answers
SOURCE: Paper Tray Settings
You have Auto Tray Switching acticated (ATS). Unless you specify each tray/paper with different settings it will switch.
Go in to the utility menu and you can find this in the paper tray settings area I believe.
You can turn this off completely to avoid this in the future.
If you look around you can even just tweak the settings for this, but in your case i would just shut it off.
Posted on Jun 06, 2008
Bubbabear64
  • 2794 Answers
SOURCE: konica 7030 tray # 4 code
You should contact Konica/Minolta for that information. That requires an tech engineer from K/M to fix that issue if it is possible to do or support.
Posted on Jun 11, 2008
SOURCE: Printing on thick paper (thick 3)
You can print thick 3 only from bypass tray.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Posted on Sep 03, 2009
  • 5603 Answers
SOURCE: Printer error shows paper jam at paper tray and
Try two things:
Fan the paper before placing in the tray.
Raise the humidity in the room to at least 40% to avoid electrostatic sticking of the paper. Store paper in 40% humidity area.
Posted on Dec 16, 2009
roytardio
  • 106 Answers
SOURCE: ssyamHP8060_ machine always promting that
check the papaer setting the software and the cassette
Posted on Jun 13, 2011
Pull out the tray and verify the motor and the sensors.If the tray indicated paper empty change the paper sensor.
Dec 31, 2013 | Konica Minolta Bizhub C364 Color Copier /...
Sharp mx2300n tray 3
Sounds like you need to configure your print driver with the options that your machine has on it.
Check out my instructions on how to do this!
How To Configure Sharp Print Drivers with Installed Options to print...
Apr 30, 2013 | Sharp Mx-2300n Copier Color Mx2300n...
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
I can't get anything to print from tray 1, the manual feed. I'm trying to print envelopes and they keep printing on 8.5x11 paper from tray 2. If I put envelopes in tray 2 it won't print
Have you already tried this? After you click print and select your printer, click properites and select your paper from 8.5x11 to Envelope.
Jun 25, 2012 | Xerox Phaser 8560MFP Laser Printer
Won't recognize tray 3
If you recently had to printer off of tray 3 there is a possiblity that the connector broke when putting the printer back on. You say not recognized, is that through the printer driver? Print the configuration page for the printer and see is it shows a tray 3, or go to the diagnostics menu on the control panel of the printer and then go to paper path test. Under the "source" see what options it offers. If tray 3 shows here then it is likely just your print driver.
May 25, 2011 | HP LaserJet 2430tn Printer
How to set printing to tray #2? HP Laser Jet printer won?t stay printing on tray 2- They do a lot of printing from this printer in the wire room and for some reason it will not stay printing on tray 2-...
Thanks for the inquiry.
Print a configuration page from the menu to determine what Tray 2 is set to.Pull Tray 2 and make sure the rear paper stop is set to Letterhead. Make sure it snaps into place and is not broken or loose. If it's broken you may have to replace the tray.
On your computer got to the printer driver icon and right click for properties. Make sure tray 2 is set to 8 1/2 x 11. Tray 2 should now be the default tray unless tray 1 (Manual Feed Tray) is open and then it will pull from it first.
Let us know how this works. We need to eliminate these setup issues 1st and more steps can be taken if necessary.
Thanks for contacting FixYa.
Oct 20, 2010 | HP LaserJet P4015N Printer
Hp Laserjet 8150. Does not pick up from Tray 3....but the tray does lift
Start by pulling out tray 2 and setting it on the floor. Next take out tray 3 and slide it into tray 2. Print from tray 2. If it works, take the tray on the floor and put it into the tray 3 slot. Print from tray 3. If it fails change the feed rollers.
Nov 11, 2009 | HP LaserJet 8150 Printer
Do not see tray 4 in my print menu only tray 1 and tray 2
Hello sir; Do you see the tray 3 ,if did not see tray 3 as well, you better check the connector behind the machine, see there is connect property.
Aug 14, 2009 | Sharp MX-2700N Color Copier
Printer switches to tray 3 when out of paper instead of stopping
You can do one or a nother thing. You can change the paper size in paper tray 3 to Legal size or you can go into the user settings, under addtional funcation and choose, that tray 3 will not daisy chain when tray 2 is empty or you can make tray 3 not to be able to print too.
Mar 12, 2009 | Canon imageRUNNER 2200
Xerox 8560MFP won't print first page from one tray and rest from another
Microsoft word overides the print driver for page choice. Choose from within word File | Page Setup | Paper.
Tray one on this printer is the manual feed tray. tray 2 is the first drawer.
Ensure the printer driver is set up for the additional trays
Jul 02, 2008 | Xerox Phaser 8560MFP Laser Printer
Konica Minolta Bizhub C364 Color Copier / Printer / Scanner Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
