Question about Kenmore 400 6942 Dryer
Dryer Gets Too Hot!
I have a Kenmore 400 series electric dryer, about two years old. The element seems to stay at it's highest temperature no matter which cycle I choose, timed dry, auto dry, (even air dry/tumble) which shouldn't have any heat at all.
Also, when I select a drying cycle, (and before I press start) I can hear a humming sound and the drum gets very hot inside.
Could this be a relay problem?
Thanks in advance.
  • 0flyingturtl May 20, 2009
    I replaced the old ducting and made sure there were no obstructions.
    Model Number: 110.C67492600
  • honeymokey
    honeymokey May 11, 2010
    Check the dryer vent all the way to the outside for blockage. Give model number to check for relay. You should not have any heat on air dry.
  • 198 Answers
Could be the heat switch on the motor or a grounded heat element
Posted on Sep 03, 2009
Whirlpool Dryer model LER4624BW2 doesn't get hot enough
What was your solution? I was thinking one or more of the multiple coils in the element could be burned out but not the entire thing I've see that happen before. Glad you got it fixed!
Mar 31, 2012 | Whirlpool Dryers
My kenmore elite dryer is only 1 year old and does not seem to get hot and takes long time to dry clothes
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
our dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Dec 12, 2010 | Kenmore Elite HE4 Electric Dryer
We have a Kenmore 400 dryer. It gets warm but will not get hot--it is only one year old --what should we check for?
there are 2 thin coil wires that have current flowing threw it. it gets red hot and provides the heat to dry clothing, if one of these wires brake your dryer wont get so hot. very common its made cheaper all the time so it wont last.
Sep 24, 2010 | Kenmore 62622 Electric Dryer
Dryer only heats on the highest heat setting
Some electric dryers have two heating elements. You probably have one bad heater and one good heater.
Apr 14, 2010 | GE DVLR223 Dryers
Kenmore 70 series
positon sensor or timer issue replace
Mar 09, 2010 | Kenmore 63942 Dryer
Have a65962 kenmore dryer the top of dryer gets burning hot while turned off
probably a stuck dryer element relay! unplug it and don't use it again until you get it fixed! or replace it!
not worth your life to keep using it! electric dryers are cheaper to replace than gas dryers! don't know how old it is, but if still under warranty, have kenmore fix or replace it! don't use it again!!
good luck! stay safe!!
Sep 28, 2009 | Kenmore 659 Electric Dryer
Kenmore 400 Series electric takes ver long time to dry.
Very common problem. You need to call a
duct cleaning company and tell them to clean
your dryer vent. Rule-of-thumb: dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint and
causing lint fires. This is definitely your problem. Good luck :)
p.s. one way to verify a clogged vent is
to go outside where the vent exits the house
and feel the air-flow. should have adequate air-flow.
Mar 09, 2009 | Kenmore 73952 Gas Dryer
Dryer not hot
Tht means that the element is not heating on.
You need to call a technician to test the element, the thermic sensor, and the control assembly.
The most likely is a defective heating element, that must be replaced.
Jan 31, 2009 | Kenmore 73952 Gas Dryer
I have a 2 year old kenmore series 400 electric dryer model 110.67422 and my problem is it will not get hot it turns light comes on just no heat i tested the contacts on the heating element with an ohoms...
if you got the meter to give you any reading the heater is good,so it must be the heaster box fuse,this fuse control the heat,if it get to hot it pops,.let meknow-mike
Dec 12, 2008 | Dryers
Kenmore 400 6942 Dryer Logo
688 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
