Question about Bosch AquaStar Indoor Natural Gas Tankless Water Heater with Vent Hood #125
I stopped the device. I don't know how to restart it.
I just put the handle from UUU to O the little flame disappears and now I don't know to relit the flame.
  • 30 Answers
Hold in your pilot button, then push the spark button repeatedly to light your pilot. Once its lit, hold that pilot button in for 30 seconds to heat your thermocouple. once its heated, release the button, and slide the slider to burner position. Turn on hot water fixtures to get the unit to light
Posted on May 06, 2014
Why does my pilot light on my hot water take not stay lite
It depends on many factors, including brand, type of heater, age, gas pressure, maintenance, venting, proper installation of thermocouple, bad thermocouple, air intake cleaning, if the flame is clear blue etc.
Copy following link to read more:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#pilot
Sep 20, 2012 | Water Heaters
I have an Atwood G6A-8E water heater. It stopped working last year so I took it to Camping Wprld. Their R&I'd the tube and igniter. He cleaned to tube and adjusted the igniter. The water heater...
Have you verified that you have 12 Volts DC to gas valve when it is trying to ignite? If you have the little thermal cut-off ( looks like a small diode ) inside plastic sleeve going to terminal on thermostat, remove it and connect female end on that brown wire directly to thermostat terminal and see if it lights.If it does, get a new thermal cut-off. It's a safety device so don"t go without it. It shuts off gas to valve if there is a flame up.
Aug 14, 2011 | RTO Atwood Water Heater - 6 Gal LP
I have a reliance power vent heater model 8 40 navto . When the water temp called for the heater to work the solenoid started clicking and when it stopped the pilot flame was out and cannot be relit. The...
First suspect is always to clean combustion parts.
I don't have that specific manual, but assume unit has digital gas control valve thermostat.
http://www.reliancewaterheaters.com/lit/om.html
As a general rule, the gas control thermostat activates the blower and turns on the gas, and controls flow of gas to pilot.
If the ECO is tripped, or there was FV event, or the gas valve thermostat is bad, or the combustion parts and tubes need maintenance and cleaning, then the pilot will not relight.
Open following link for older Reliance troubleshoot manual, plus some troubleshooting resources and illustrations:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Add a comment and say what you did to restore functionality.
Jun 13, 2011 | Reliance Natural Gas Water Heater Control
I have a 50 gallon gas Whirlpool water heater that I installed March of 2005. It's a 9 year warranty. It just started to flame out this morning. I relit, then turned to warm. It started to light up,...
Hi, I work in a plumbing store and that problem you described is related to a piece called thermocoupling, its a coppery thin line that heats up and controls the flow of the gas. If not this then I would check to see if your flue pipe is a bit clogged as the heat is not able to flow up quickly enough. Another culprit can be a problem with the vent pipe on the roof, as a non properly functioning vent will let draft down to the flue pipe. Most likely I think it is the thermocoupling though. Hope this helps!
Dec 03, 2010 | Whirlpool Water Heaters
Water heater pilot keeps going out. Relight and may stay lit for a day and then goes out again. Now won't even light at all. Has an igniter button. Also says to clean intake screen every 6 months. Where is...
the intake screen or as is called flame trap is located on the very bottom of the heater underneath. this is very important that you keep this clean or it will keep going out. this is the only way this heater has to get air to the burning chamber.
Nov 23, 2010 | RELIANCE ELECTRIC WATER HEATER
HEATER WARMS UP AND THEN GOES OUT.THEN IT HAS TO BE RELIT TWO OR THREE TIMES A DAY
Relighting the pilot of any water heater is a pain. The first thing to do is call the water heaters manufacturer for information on your specific make and model. If your water heater is under warranty, they will provide technical advice and free parts.
1. Replace the water heater's thermocouple. Make sure the pilot flame is centered on the shiny end of the thermocouple; it requires a certain amount of heat to produce enough electricity to open the main gas control valve.
2. Replace the main gas valve control.
3. Replace the water heater; I know this not what anyone wants hear.
Aug 26, 2010 | American Standard Water Heaters
Pilot lite went out and will not relite
The thermocouple is not functioning. The t/c is the small (sensor) tube that the flame touches and should have a small copper tube (capillary) extending to the gas valve. (IMPORTANT: The capillary tube should not have any kinks or crimped places...Only gentle bends. A crimped tube will require t/c replacement.) The flame will deposit a coating (minerals) that will insulate the t/c and prevent it from working. Clean the sensor with steel wool, fine sand paper (emery board) or scotch pad. Now try to relight the pilot making sure the t/c sensor is contacted by the flame, if not, shut off gas and adjust. Once aligned and contacted by pilot flame, hold for a minute, allowing the t/c to warm up fully and signal the gas valve to operate when knob is turned from pilot to operate.
Jul 16, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Pilot light goes out each time the jets stop heating
This is most likely a thermocouple problem. Try replacing the thermocouple. If it still does it then the draft from the fire is pulling so hard that it pulls the flame away from the thermocouple just after the flame goes out. readjust the way the pilot flame hits the thermocouple to keep it on the thermocouple...
Heatman101
Mar 21, 2010 | Little Giant Water Heaters
Pilot light went out but will can,t get it relit it only stays on as long as I hold the button down
Is the thermocouple in the pilot flame? & does it get hot [glow red] If not adjust position until it does & make sure it's clean
If thermocouple gets hot but no relight, replace couple
Oct 26, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Bosch aquastar 125b ng
Replace the thermocouple.
Thats the flame sensor.
If the gas valve is not sensing flame it will not stay lit.
T-couple's are about 9 bucks.
Nov 06, 2008 | Bosch AquaStar 2400ES-NG
Bosch AquaStar Indoor Natural Gas Tankless Water Heater with Vent Hood #125 Logo
97 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
