Question about Maytag 61002460 Refridgerator Door Shelf Bar
Maytag Abc2037dtb refridgerator is cold on bottom not cooling on top
Does not distribute refrigeration correctly between fridge and freezer
  • 19 Answers
SOURCE: Maytag refrigerator cooling probelm
Defrost the fridge, take everything out of freezer and turn off for at least a day, check the drain is clear after defrosted and try again, if it happens again you may need a new defrost heater of timer.
Posted on Nov 18, 2008
SOURCE: Maytag MTB2156GEQ Top Freezer not working
The compressor not working, relay switch on compressor not working Had repair man put new switch in .Last year put in new fan motor in freezer compartment the cool air was not circulating both problems made the fridge not to cool and drip water
Posted on Nov 22, 2008
  • 686 Answers
SOURCE: fridge is warm even when i adjust temp. control.freezer is good.
if your fridge has 2 set of dials one numbers and the other letters than you need to adjust the dial that has letters on it. If the fan in your freezer is not blowing, then it won't force the cold air from the freezer to the fridge. Make sure fan blows then adjust the letter knob.
Posted on Feb 17, 2009
  • 2696 Answers
SOURCE: Maytag MZD2766GEW side by side refrigerator fridge not cooling
you have a defrost problem, could be bad adaptive defrost board,t-stat heater,when you open freezer door listen for fan if fan is blowing check the t-stat,look at it and see if it has a buldge on it,sometime you can see this and tell it's bad,you'll need a meter to read out the heater and other parts to see whats bad,might be a good idea to call a tech to do this,when you find problem you have to melt everything out again
Posted on Oct 31, 2009
heatman101
  • 43501 Answers
SOURCE: freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
s
Posted on Sep 30, 2010
Upper fridge not cooling, freezer still icy cold.
check fan should be run in freezer,no blockage should be in its air flow by ice or any other item
Jun 18, 2014 | Amana ABC2037DTB / ABC2037DTQ Bottom...
Refridgerator isn't cooling, but freezer is cooling more than it should
Some fridges use the same air fridge gets its cold from freezer the duct could be frozen closed a good defrost could do the trick
Jun 30, 2012 | Maytag Appliances Magic Chef 18 cu. ft....
Refridgerator is not cooling
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
Nov 28, 2010 | Maytag 25.1 Cu. Ft. Bottom-Mount...
Top refridgerator does'nt cool, lower freezer OK still cold. Where is the fan located?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 23, 2010 | Maytag MBB2256G Bottom Freezer...
Water on the inside floor of the refridgerator,
remove back panel from freezer and unglog hole where it collects water. its glogged
Feb 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
Refridgerator is not cooling but freezer works.
heatman101
Nov 14, 2009 | Maytag MBF1956HES Stainless Steel Bottom...
The top refridgerator is not cooling correctly
heatman101
fgmjfd
Sep 29, 2009 | Samsung RB1955VQ Bottom Freezer...
Maytag refridgerator not cooling
heatman101
Apr 06, 2009 | Maytag MSD2651 HE Side by Side...
Maytag 61002460 Refridgerator Door Shelf Bar Logo
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
