Question about Keurig Coffee Makers & Espresso Machines
Keurig won't brew, only 2 months old, not a descaling problem
    Problem Solver:
  • 20 Answers
Hot water output nozzle may be stopped up with grounds. unplug, turn over, insert straightened paperclip into hole. then run with water only. this happened to me.
Posted on Feb 16, 2015
    Scholar:
  • 114 Answers
If it's only 2 months old you should contact Keurig directly. They have awesome customer service and will probably replace your unit. I have read numerous postings that they will do it even if you did not register your machine.
http://www.keurig.com/contact-us
Posted on Jan 10, 2014
  • 25 Answers
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
Posted on May 14, 2009
SOURCE: My Keurig B60 is Suddenly Brewing WEAK Coffee
I don't have a solution but have just experienced the same problem and am baffled. I am using the same beans same grind. In fact using the exact same grind it went from great one day to weak the next day.  I always run it for 15 - 16 secs to get the shot and that hasn't changed. Pressure and temperature appear fine. I cleaned the top of the top filter which was a little dirty but not seriously bad - no change. The coffee flow which is normally chocolate coloured to start with is just mid brown.
Posted on Feb 28, 2010
  • 5 Answers
SOURCE: Keurig Platinum shuts off after one brew. Will
I came up with a very simple workaround to fix this issue:
http://www.nate-lewis.com/blog/?p=288
The problem is with the water tank not having a proper seal to the brewing unit.
Posted on Jun 05, 2010
mcdevito75
  • 1970 Answers
SOURCE: Keurig B60 is real slow , displays brewing for 30 sec.
mcdevito75 here, It may need to be cleaned, water used to brew coffee leaves deposits in the brewing holes and must be cleaned every once in a while. Refer to the owners manual on cleaning the coffee maker.
Posted on Jun 20, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: My keurig machine wasn't brewing a full cup so I
do another descale..add more vinegar....run the entire full tank of water....you must have a big buildup of scale...
Posted on Dec 18, 2010
How do I descale my Keurig 20 coffee machine
Start the brew cycle without inserting a K-cup. Repeat until reservoir is empty, discarding the mug contents after each brewing cycle. This process will help remove lime and scale buildup. Keurig recommends descaling your brewer at least every 3-6 months depending on your water source.26 Apr 2015
How to Clean a Keurig Coffee Machine - Cleaning Lessons from The ...
www.thekitchn.com/how-to-clean-a-keurig-cooking-lessons-from-the-kitchn-218103 https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=How+do+I+descale+my+Keurig+20+coffee+machine
Dec 22, 2016 | Keurig Coffee Makers & Espresso Machines
My Keurig only brews a part cup
Most likely you need to change the filter and descale it as well.
I use a CleanCup once a month:
https://www.amazon.com/CleanCup-Single-Machine-Cleaning-Capsules/dp/B00E0QAS34/ref=sr_1_1?ie=UTF8&qid=1480095410&sr=8-1&keywords=keurig+cleaner+cup
I change the filter once every 3 months:
http://www.keurig.com/Accessories/6-Pack-Keurig%C2%AE-Water-Filter-Cartridge-Refills/p/Water-Filter-Cartridges
And I descale it every time I change the filter using this:
http://www.keurig.com/Accessories/Keurig%C2%AE-Descaling-Solution/p/Keurig-Descaling-Solution
Otherwise, the tubing is going to get clogged up in your machine and produce smaller and smaller cups of coffee, not to mention, when you keep your machine clean, your coffee will always taste its best!
Hope this helps!
Nov 25, 2016 | Keurig Coffee Makers & Espresso Machines
Keurig won't brew coffee
Take it back for an exchange. Not sure what model you have, but Keurig has a class action law suit going on because of the many problems they are having with their coffee makers. Again, take it back for an exchange (what I did).
Dec 31, 2013 | Keurig Coffee Makers & Espresso Machines
I have had my Kuerig coffee maker for over a year now which I believe means it's no longer under warranty. However, I paid quite a lot for it so I'd really like to see if I can have it repaired...
unfortunatly keurig treats any home model as throwaway once warrenty is up. They even do the same with mostcommercial models. By the sounds of your problems its time for a new one. sorry. try for a b145 or b150 they are a little more robust.
Sep 05, 2011 | Keurig Platinum B70 Coffee Maker
Ccoffe maker won't brew. Says it is Brewing but nothing. Only about 6 months old was descaled earlier this week.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 27, 2011 | Keurig B70 Coffee Maker
Jun 20, 2010 | Keurig B60 Coffee Maker
Keurig platinum only makes 1/2 cup
call customer service 1-866-901-BREW (2739)
Jun 17, 2010 | Keurig Platinum B70 Coffee Maker
Coffee Makers & Espresso Machines Logo
139 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
