Question about Samsung LN32A540 32 in. LCD HDTV
Volume goes to zero
The audio goes to zero and stays there. We can trick it by using the side panel controls. Put the audio up and quickly hit the menu button. If we try to exit the menu screen, audio goes back to zero.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 57 Answers
Sounds like you need to replace the buttons on the side of the tv. I can get you a part number if you will supply me with the full model code and version of your tv.
Posted on Apr 17, 2014
circuitcity
  • 137 Answers
SOURCE: SP42W5HFX menu problem
Here is what going on. This is a internal fix. You need to do a small voltage adjustment. There are 2 controls. Your VS adjust and your VA adjust. Maybe your VE adjust. Look inside the panel there will be a sticker with the correct voltage. Just adjust accordingly. Be very careful. These are very important adjustment.
Best regards
Circuitcity
Posted on Dec 06, 2007
SFroese
  • 141 Answers
SOURCE: Menu Trouble
perhaps the volume down button on the TV is stuck. It could be either physically stuck, or the electronic logic could be messed up. Just to rule out a problem with the remote, take the batteries out of it and then adjust the volume at the TV and see what happens.
Posted on Sep 07, 2008
  • 32 Answers
SOURCE: Yesterday I turned my volume down to zero on my tv
There are two possibilties, the buttons on your TV are stuck on one position or your control inteface board is damaged. I would need mopre info to rectify.
Posted on Jul 24, 2009
  • 8457 Answers
SOURCE: Our TV has been great. Have owned it A little over
Check the tv pannel manually control on the right,see if it work.Then it ur remote tries take it aparts clean it with some alchol with a Q tips there a screw under the batteries input,after that change the batteries,That one solution.The other have to take ur tv apart to change the sound board.
Posted on Sep 27, 2009
  • 4090 Answers
SOURCE: Volume automatically decreased to zero and won't go back up.
Plug the audio out to check it isn't the speaker itself failing. I suspect it is the audio circuit section of the board. But a few times I have experienced the speaker unit circuit where the magnet is caused the problem. So using an external speaker helps to determine speaker vs circuit
Thanks for using FIXYA
Posted on Oct 11, 2009
I have a Sharp Aquos LC-46D43U TV and the audio control is continuously going down to zero although I use the remote to increase the volume. The TV is automatically decreasing the volume to 0. I hea
this is a problem I rectified yesterday.
the audio ic is overheating thats why the tv is fine when cold and
after a few hours the volume disappears.
I fitted a heatsink to the ic chip as the sharp one is very poor quality
Sep 19, 2014 | Televison & Video
Volume control
Poltergeist in volume circuit is the diagnosis. Try a hard reset of the receiver to see if that does the trick with the electronics.
Sep 01, 2017 | Mitsubishi WD-82737 82" DLP TV
50pq12...lg hdtv... my volume stays at zero
If the display for volume goes up but there is not sound--a number of simple things to do.
Does the set have sound with a DVD etc hooked to one of the rear audio/video inputs?
If using a box for signal, a receiver etc--unplug each one at a time and after a short wait plug them back to allow them to reboot.
In set look to see speakers did not somehow get switched OFF.
Cable, Sat and receiver all have volume controls so make sure someone did not turn one of them to zero sound.
You could have a audio problem in the set itself but that is fairly rare.
May 23, 2012 | LG Televison & Video
Dv7-1023cl problems with quick touch buttons
You don't need to activate the drivers. if you reinstalled them then they are there and should be working.
There should be alternate methods to using the quick touch keys, such as using the conventional methods.
For example to change your volume, just click on the megaphone at the bottom right near the time and adjust the volume. Or click Start/Control Panel and look for Audio or Sound and adjust the volume. Also click Start/Programs/Accessories/Entertainment and see if there is a volume control there. Also normally you can adjust the volume by keystrokes. Normally you would Press and Hold the FN function key near the bottom left portion of the keyboard and press the volume keys (there should be 3 volume keys, volume up, volume down and volume mute).
As for the Wireless there is a switch on the side or in the front of the laptop that controls the wireless. Also there are keystrokes that can toggle it off or on once the wireless switch is on. Normally you would Press and Hold the FN function key then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the icon of a wireless signal )))) or it will have the icon of a tower with a wireless signal )))).
Apr 23, 2012 | HP Pavilion DV7-1023CL Notebook
Hi Folks - I have a Roland Fantom G6 that produces no sound! Everything else seems to be fine - the display registers that I am hitting the keys & even the skip-back sampling feature produces a wav...
This probably is not a DIY repair... The audio comes out of the CODEC and is buffered by Op Amp used as filters and then goes through the volume controls, After that it goes to the jack board with buffer OP amps. First thoughts might be a damaged volume control, however, the "B" outputs don't go through volume controls...
About the only thing I would think you could do is to CAREFULLY open the unit and look for a loose cable involved with sending the audio to the volume control panel and then the cable that takes the audio to the jack board...
More than that you would probably need to take it to a shop equiped to troubleshoot.
Nov 23, 2010 | Roland FANTOMG8
The volume won't stay up. When I turn the volume up, it immediately goes back to zero...and the volume display is permanently on
your TVs front panel control swwiches are in trouble. Replace all of the at the same time will resolve the problem.
Oct 15, 2010 | Zenith SY1931SG TV
Oct 11, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Our TV has been great. Have owned it A little over 2 years. Just now the Volume line appears on the screen and the volume goes to zero without anybody touching the remote. The volume line stays on the...
Sep 27, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Volume drops
um, it might be, simple or stupid, thought check the sides of the keyboard, the optional buttons, the volume down, might be stuck, hope it helps
=D
Feb 23, 2008 | Logitech Cordless Desktop S 510
Volume goes full blast when turned up from zero to just a "1" onscreen
I have seen a similar problem. get to design mode (that trick with the remote mute & the set menu button) & look for a data address in the audio section that is set to all (F)s. sorry i can't remember the exact address. you could always just guess just make sure you write down where they are currently set .
Hope this helps.
Jan 25, 2008 | Toshiba 19A26 19" TV
Samsung LN32A540 32 in. LCD HDTV Logo
47 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
