Question about Mindscape Close Combat 4: Battle of the Bulge for Windows
Unable to create multimedia stream - Mindscape Close Combat 4: Battle of the Bulge for Windows
I need to find a place to put my activation code in
First you need to create a roku account then you can enter that code in the link if unable call me on 1-800-969-3032 ( Sam Watson )
Sep 24, 2016 | Roku Streaming Stick
I just got a new Roku streaming device and cannot get the code to work and where do I sigh it in ?
When you power it on, you should get a setup screen that has a box that you put a number into. You get the number from the website when you sign up. If you cannot get the startup screen on the Roku use the reset button on the back to start over.
Aug 31, 2016 | Roku Streaming Stick
When we try to skype we are unable to have our picture shown to the receiver of the call. The video screen says,"Video source isn't delivering the stream in the correct format" What does this...
Observe the skype software program for functionality capabilities. In situations where the feature of displaying media either as photos is attainable yet malfunctioning is computer network structure related. Ascertain the computers networking methods. For example, dial up phone cable connected computers least provided the entire multimedia experiences. Wireless broadband or ethernet network devices provides the entire extensive capacity to multimedia experiences.
Feb 20, 2011 | Computers & Internet
How to activate & send mms in samsung s8000 mobile
you need to configure the mms settings from your internet menu... but you need the right configuration from your network provider to the settings..
to give you an idea, here's how you may do it.. from your phone, press menu select internet select browser profiles to lead you to internet profile settings.. from your settings, press create.  then create the mms profile your network preferred.  once created, press save and exit the settings for internet profiles..
to make the mms profiles be the default settings for your mms, do thes steps... from your phone, press menu select settings select phone applications select messages select multimedia from multimedia menu, select profiles assign the mms profiles you created for your multimedia. press save and exit the setup...
now to check if it's working, try sending a multimedia message to your own number to check if your phone can send and receive mms. once you successfully send it and received it, it means that your phone mms is already set and working...
take care..
Mar 30, 2010 | Samsung Jet S8000 Cell Phone
I'm just wondering if it's possible to stream live video of your PC desktop screen to a webpage on another PC using VLC 1.0? I've tried different settings in VLC and I just haven't been able to get it to...
You need to find a screen capture program that captures your desktop as a camera then find a streaming utility for your website to point to that camera that was created as your desktop. It is possiable I just do not know right off hand what the program names are.
Sep 23, 2009 | VideoLAN VLC
Unable to stream video on classic media player,vlc or windows media player even on installing the K-lite codec pack.only audio is streaming.please help
You probably need to install divx codecs too.
Download & install divx codecs from here and restart your computer to see if the videos play>>>>>>>>>
http://www.divx.com/en/products/software/windows/divx
Regards.
Sep 22, 2009 | Microsoft Windows Media Player
I am unable to play streaming videos in my pc
One time fix, save your favourates (book marks) & reinstall the internet explorer.
Get a new one via :
www.katzforums.com/showthread.php?p=256822 - 26k
Mar 18, 2009 | Computers & Internet
Multikey secure multimedia proxy using ARPS-java source code
Because of limited server and network capacities for streaming applications, multimedia proxies are commonly used to cache multimedia objects such that, by accessing nearby proxies, clients can enjoy a smaller start-up latency and receive a better quality-of-service (QoS) guarantee-for example, reduced packet loss and delay jitters for their requests. However, the use of multimedia proxies increases the risk that multimedia data are exposed to unauthorized access by intruders. In this paper, we present a framework for implementing a secure multimedia proxy system for audio and video streaming applications. The framework employs a notion of asymmetric reversible parametric sequence (ARPS) to provide the following security properties: i) data confidentiality during transmission, ii) end-to-end data confidentiality, iii) data confidentiality against proxy intruders, and iv) data confidentiality against member collusion. Our framework is grounded on a multikey RSA technique such that system resilience against attacks is provably strong given standard computability assumptions. One important feature of our proposed scheme is that clients only need to perform a single decryption operation to recover the original data even though the data packets may have been encrypted by multiple proxies along the delivery path. We also propose the use of a set of encryption configuration parameters (ECP) to trade off proxy encryption throughput against the presentation quality of audio/video obtained by unauthorized parties. Implementation results show that we can simultaneously achieve high encryption throughput and extremely low video quality (in terms of peak signal-to-noise ratio and visual quality of decoded video frames) for unauthorized access.
Oct 16, 2008 | Computers & Internet
Changing video or movie background
hi, if the back ground is of single colour then you can change the background by applying chrome effects, if it is multi color then not possible
Jun 23, 2007 | Adobe Premiere V 7.0 Professional for PC
Mindscape Close Combat 4: Battle of the Bulge for Windows Logo
163 people viewed this question
Top Mindscape Video Game Consoles & Games Experts
James Wishart
Are you a Mindscape Video Game Console and Game Expert? Answer questions, earn points and help others
