We turn the set on, either by remote or on-board button, and within 3 seconds it shuts itself off again. Is this affordably fixable or would it be better to just get a new unit altogether?
  • cschulz May 20, 2009
    Can i really check boards, capacitors and resisters in there myself? I hear this is a really, really dangerous thing to do...I'm a little apprehensive but i'll try it first thing in the morning. What do i look for besides brown "overheated" boards?the set is too heavy for me to carry and i am unwilling to pay our local service guy for a housecall if the tv is going to end up junk anyhow.
    thanks. will have a friend haul the tv to the shop this morning.
  • 952 Answers
I have encountered the same problem with one of my televisions. The culprit was overheating capacitors. Bring your TV to a local shop or a technician. Tell them that your TV has bad capacitors. Capacitors are cheap so having this TV fixed wont cost you a fortune. I hope this helps. Have a great day.
Posted on May 20, 2009
    President:
  • 2,923 Answers
There are could be more than one cause of the problem. And you need to check the all the boards first before deciding to replace your TV.
Please check first the following and you might save some money:
1. Check the power supply board: This part usually goes bad due to overheating and faulty components. You must check for brown spots on the boards , that are signs of overheating.
2. Bad components: Tthe common components that goes bad ares the Capacitors, Resistors and the Relay. You have to check if there are bulging capacitors or burnt resistors or bad relay.
3. Cold Solder Joints: you must be very careful working on the power supply board as it does have high voltages they can be very dangerous to the inexperienced user. Never test anything with the power on or connected.Use anti static protection straps and gloves around all the chips and microprocessors to avoid damaging them. Check all the other boards for the same problems. If you can find no problems, Then it is time to get help from a service center where they will have all the necessary testing equipment, To give the unit a more thorough testing for faulty components.Hope this helps you with your problem.
Once you found the cause of the problem, you may now replace it by yourself. But you have to make sure to use the same value of capacitor or resistor.
It would always be best to consult a TV technician if you don't have the right equipment.I hope this would help you save some money.
Have a good day!
Keyless for a ford freestar 2004 i replace the batery in the remote control and now the remote not work
You need to reprogram it here are the steps
1. Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in
RUN. Door locks will cycle to confirm programming mode.
2. Within 20 seconds press any button on first keyless remote. Door locks will cycle
to confirm programming.
3. Within 20 seconds, press any button on second keyless remote. Door locks will
cycle again to confirm programming.
4. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Mar 13, 2013 | Televison & Video
1999 Mercury Sable Keyless entry wont work
I only have the instructions. If it won't program you may have a problem in the module. In that case see the dealer for testing and diagnosis
. Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in RUN.
Door locks will cycle to confirm programming mode. 2. Within 20 seconds press any button on first keyless remote. Door locks will cycle to
3. Within 20 seconds, press any button on second keyless remote. Door locks will cycle
Jul 03, 2012 | 1999 Mercury Sable
Hello I have a Mazda Tribute 2002 model that the remote will not work on. i bought a new remote with the same number on it 1L87T-15K601-AA and I cant program it I have done the turn key 8 times to get door...
These are the correct instructions.
1. Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in RUN. Door
2. Within 20 seconds press any button on first keyless remote. Door locks will cycle to confirm
programming.
3. Within 20 seconds, press any button on second keyless remote. Door locks will cycle again to
Jun 22, 2012 | Cars & Trucks
Have mecruy montneer 2001 lost keys how to program it
Programming Instructions: 2001 Mercury Mountaineer.
Apr 26, 2011 | 2001 Mercury Mountaineer
How to program keyless entry? bought vehicle used from dealership
Feb 04, 2010 | 2003 Ford Expedition
Car key remote
Mar 24, 2009 | 2001 Ford Expedition
42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Aug 18, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Shut down when press
1.Check whether your Remote buttons jammed else on the TV.
2.there might be some problem Remote ir receiver unit in your TV
3. Microprocessor/microcontroller unit on Remote signal receiver board
Dec 28, 2006 | Philips 32PT6441/37 32" TV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
