Question about Olympus SP-350 Digital Camera
My Olympus SP-350 cannot focus, wierd colors in the LCD screen
My camera suddenly does not show a clear picture in the LCD screen.  It is almost as if it were an old colored negative, but without clear edges on the items being viewed.  It's like special effects.  How can I get a clear picture again?
We took it to a camera shop,and found the sensor was blown.
Posted on May 21, 2009
I havea an olympus sp-350, shutter is stuck so
I had the same problem, so tried putting the zoom fully on to take a picture.
It worked.
May 12, 2010 | Olympus SP-350 Digital Camera
Broken LCD screen
your answer to this problem is easy. First take the batteries out of the camera, then open the camera ( screws should be in the back) the screen should just pop out of the cover and there is a ribbon cable that connects the screen to the circut board. Gently un-hook that ribbon where it plugs in to the board there might be a slid lock to hold the ribbon in place, it should unlock when you pull the cable out (memorize what position the ribbon is before unplugging). Now the fun part, do the same thing to the other camera, (carefully). To install the new screen, plug the ribbon back into the slot and it should be snug, if not there is a lock on it, gently push it back away from the ribbon ( a little finger pressure). Now, simply put it back together the same exact way you took it apart and don't forget the batteries. Have fun taking pictures...
Nov 01, 2007 | Olympus SP-350 Digital Camera
My fe-280 model has color problems.
Has this camera ever been left in a hot car?
Apr 17, 2010 | Olympus FE-280 Digital Camera
I am not getting the suff.no of snaps as batt is getting down for olympus( sp-350) . i have tried several type of AA 2500 mAh Ni-MH battery and purchased new LCD (simpex) charger.then also same.also when...
The problem you describe is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the inside contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe the ends of the batteries and replace them in the camera. This clears up the problem about 90% of the time -- I hope it works for you.
Sep 09, 2009 | Olympus SP-350 Digital Camera
LCD screen Olympus Stylus 1010 snowy and fuzzy with lines
This is a issue with just the LCD it needs to be replaced.
May 25, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Blurry pictures
When operating any digital camera, the camera tries to capture the best focus and exposure for that particular scene. By pressing the shutter button half-way down, the focus and exposure is being set. There will be a green circle on the upper left hand corner of the screen, then your camera is ready to take the picture. Slowly depress the shutter the rest of the way down to take the picture.
Also try to reset the camera back to factory defaults as there could be a setting that is causing the images to be blurry. To reset the camera - have the camera in shooting mode - go to Menu - left arrow to reset and press ok. Highlight yes and press ok. This will reset the camera back to factory settings. See if this clears up the blurry images.
May 03, 2009 | Olympus SP-560 UZ Digital Camera
SP-350 WON'T FOCUS
unfortunately it is repair issue.. the lens does go out on a track and may have got off track
Jul 16, 2008 | Olympus SP-350 Digital Camera
Something with lcd
try to lower the colour depth & adjust contrast
Feb 03, 2008 | Olympus SP-350 Digital Camera
No display object on LCD viewer screen
press the disp/guide and see if the display changes..if not then repair
Jan 19, 2008 | Olympus SP-350 Digital Camera
SP 350 Blue screen
Change the battery to crv3
Jun 04, 2007 | Olympus SP-350 Digital Camera
Olympus SP-350 Digital Camera Logo
290 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
