Question about Epson Stylus RX500 All-In-One InkJet Printer
Will read memory stick
It will not read sony memory stick pro duo 1gb. the green light comes on when i put the stick in but it does not read it.
  • Epson Master
  • 705 Answers
Memory Stick Pro Duo is NOT in the list of supported flash media for the RX500.
However I would expect the machine would be able to read the memory stick. Have you tried more than one Memory Stick Pro Duo? If not try another one and see of the problem persists. If it does, contact Epson and ask if the machine should read the format.
It is possible that the capacity and density is outside the range of the machine.
Posted on Oct 18, 2007
  • Inky Fingers
    Inky Fingers Oct 19, 2007
    You did not post a response to my question - Had you tried more than one Memory Stick Pro Duo?
    Have you now resolved the issue or do you still need help?
SOURCE:
Sony memory stick duo pro 1gb is using for Sony handycam is suddenly started giving error message like reinsert memory stick. I have important pictures and video in it, now i need to recovery them. Do...
Hi Devika,
Buy a card reader that can read your memory card and connect to the computer. (Less than $8 in Sri Lanka). Connect it to PC and insert the card to the card reader.
Download Recuva and run it. select the memory card. Try to recover the files.
Best of Luck!
Sep 21, 2011 | Sony 1GB Memory Stick PRO Duo Memory Card
When i put my sony PRO duo 8gb memory stick into the slot on my computer, the light does not shine green and my computer acts as if it's not even in it. PLEASE HELP A.S.A.P.!!!! Thanks, admlmbrtrckz
Jan 24, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
My pc does not read the memory stick PRO duo sony...
my memory pro duo in camera show picture , when it conect with computer ,picture no t show.how can i do?
Dec 30, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
How to repair a memory stick duo turn that to raw
Put memory stick in camera and format it, this is the only way to fix some problem in memory stick.
If that does not help, memory stick got hardware problem that is irreparable. Buy new memory stick then.
Thanks.
Nov 05, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
I have a sony memory stick pro duo 1gb and its not reading...it shows the memory card reader and then i put in the memory stick with the adaptor but is says that it has no card in it
i have Few suggestions....
Try connecting to different port on the same system, and see if it is connecting.,
if not working, try in some other system to isolate the issue., just to check whether the problem is with the system or the memory stick...
Oct 01, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Can't open files in sony memory stick pro duo 1gb.
did you reformat the memory disk before you put all the files in there? if you didn't, then that could be the problem.
Sep 05, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
My Memory Stick does not register to my Macbook Pro. I have put it in the the SD slot countless times every way.
memory stick pro duo slot is different from SD slot. get a inexpensive card reader which supports memory pro duo cards.
Aug 07, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Memory stick card reader won't read
have you installed the driver for the 5-in-1 card reader?
check hp for your model.
Jan 23, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Sony memory stick pro duo is too small to fit in my computer media stick compartment. it won't read
its to small b/c when u bought the media stick it should have came with an adapter that you put the stick into and it makes it bigger inorder to fit into the computer.
Sep 17, 2008 | Sony 1GB Memory Stick PRO Duo Memory Card
Epson Stylus RX500 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
