Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Replacing ballast how do you find bad ballast?
    Problem Solver:
  • 28 Answers
You would need to test the voltage coming to the ballast which depending on the ballast should be at least 320V but nothing higher than 370V maybe even 380V? (if someone know the exact please post)
CAUTION DO NOT TEST THE POWER GOING FROM BALLAST TO THE LAMP ITSELF (the ignition charge is too much ~15kV)
I assume you tried a new original Philips lamp and that you replaced the lamp door cover correctly.
Posted on Jan 16, 2014
KF42WE610 bad lamp... and ballast?
DLP Lamp has electrodes inside and ballast generates high voltage that makes spark on these electrodes thus got high bright light. New lamp wont die due to bad ballast so replace lamp and see tv works or not.
This tv has self diagnostic feature, turn On tv and let it shut down, now check standby light that would be blinking in specific order, for example 3 or 4 times blink then pause for 3 seconds and again blinks.
Let me know how many times standby light blinking in this tv to help you with more info.
Thanks.
May 16, 2010 | Sony Grand WEGA KF42WE610 42" Rear...
Replacing ballast
To confirm if the ballast is bad check the ballast board to see if the spark gap (on the ballast board) lights when you first turn the set on. If it does than the ballast is ok.
Sep 20, 2009 | Televison & Video
Tv turns on for one second then turns back off
I believe it is a Back Light failure. Either because of a bad Ballast, a Power Supply, or a bad Lamp that is not replaceable. If it is a bad Ballast or Power Supply they are replaceable. Checking the Voltage from the Power Supply for the Ballast will tell if the Power Supply is bad. It should read around 250V to 300V.
If the Voltage is there, the LCD Panel will probably need to be replaced. I recommend a professional to evaluate it to be sure.
I hope this helps,
Skyassoc
Aug 25, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I need to replace the ballast on my GDM 12 freezer and I need to know where the balast is located
The ballast is located on the bottom inside wall where the compressor is located. Its usaually mounted, and can be easily removed and replaced. The ballast is rectangular in shape and has a few wires protruding from each end. To replace simply dismount the bad ballast and clip the wires. Match the ballast to a new one, reattach the wires using wire nuts, and remount ballast.
Jul 24, 2009 | True GDM-12 Refrigerator Commercial
Ballast on samsung hlp4663w
The transformer can't damage the new lamp. Faulty transformers normaly take out the driving transistors or the fusible link in the power supply, if these are good then just replace the lamp. Espacially if you know the lamp is bad (test it by swapping with the others if unsure)
May 25, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Ballast
in quiet room listen for the firing of ballast.
May 29, 2008 | Samsung DLP HL-P5663W 56" TV
Ballast replacement
Your set uses the Phillips UPH100W 1.3 100http://servicemanuals.vstore.ca/ 1amp bulb part number 6912V00006A which uses Ballast EUC 6913V0002A and the actual ballast isMB03CA part number 6871VSMB13F I would contact LG and give them these numbers. Is your ballast bad or is the BallastEUC bad? Let me know if I can help you further.
May 12, 2008 | LG RU-60SZ30 60" Rear Projection...
Samsung LA40R71BD will not turn on stanby button keeps flashing and making a clicking sound.
This could be lamp or ballast. First I would check the lamp. It could be bad (causing the clicking) or it may just need to be reseated with the ballast. If the lamp is not bad make sure it is connected to the ballast and pushed all the way in. If you still hear the clicking (the clicking may be the ballast trying to light the lamp. when turning on your tv, look to see if the ballast is flickering causing the clicking) and your lamp is good and seated correctly, then you ballast is going bad and it needs to be replaced. Last but not least. If that is not the problem then the clicking is a broken color wheel. A broken color wheel will sound like a clicking or a high squeal when going bad.
Mar 23, 2008 | Televison & Video
Replaced lamp still not working
Power issues (Tv True True (``````````` (``````````` 0 95250 95250 clip_image002.gif not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung True True (``````````` (``````````` 0 95250 95250 clip_image002.gif is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Jan 16, 2008 | Samsung HLN5065W 50" Rear Projection...
My projection tv
Nov 23, 2007 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
211 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
