Question about Dryers
Maytag 3000 series dryer
Squeaking while running
    New Friend:
  • 51 Answers
Belt going bad or belt tensioner bushing going out. Could also be a roller bushing.
Posted on Jan 06, 2014
WRMtech
  • 70 Answers
SOURCE: during the drying cycle, the dryer door opens
Chances are the little plastic latch keep is broken. Look at the door and locate a peice that will press into the front area where the clothes go in.
Once you see it, check the keeper and see if it is broken. The door should not just pop open.
Posted on Feb 26, 2009
SOURCE: Maytag dryer squeaks during cycle
I have a Maytag electric dryer model # LDE7334ACE that squeaks while running through the dry cycles. It began as some squeaking at the beginning of the cycle and then it would stop. Has recently progressed to squeaking off and on throughout the cycle. Can you please provide
Posted on Mar 11, 2009
How do you replace the glides/slides? I have a Maytag dryer that's squeaking, took off front and it's clear it's the glides. Found where to buy them just need directions for replacing. Anyone know how?
To change the glides you have someone lift the drum--after taking off the front panel--and pull out the glides. We bought the glides locally and just ordered on line the felt pads that go under the glides, as one was missing. So I haven't actually completed the project but should easily be able to once the felt pads arrive.
Posted on Mar 24, 2009
SparkyNZ
  • 43 Answers
SOURCE: Just bought a Maytag 3000 washer and dryer and
Most likely the metal is aluminum or stainless and you should worry about rust unless you wash your clothes with salt-water (seawater. not gonna happen.)
If you're really concerned, I'd attempt to reach a maytag customer service person.
800-462-9824
To reach a real person press 0 at every option. Should take three times.
Posted on May 11, 2009
EllaWatson25
  • 725 Answers
SOURCE: I would like to know how to switch the door so it
I actually did this myself so if I can do it, so can you.
If your door is reversible then you just have to remove the hinges from the side that they are on. Once your door is off, you will notice that the opposite side of the door has the place where the hinges will be replaced. You simply add the hinges and transfer the latch and strike to the other side.
We hope this answers your question and we wish you the best of luck. Ella
Posted on Nov 12, 2009
Maytag legacy series dryer
most likely susoect is the belt pulley or a roller,if you send the model number i can help you out better
Jan 19, 2014 | Dryers
Screen reads CF1, and does not work
Maytag 3000 series .Dryer screen reads CF1, then CF2... then Cf3 and does not work
Apr 03, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I have a maytag dryer that has a squeek
It's difficult to tell what might be causing a specific squeaking noise, but check the following:
The belt tensioner
The drum support rollers
These would be the two most common causes. You will need to remove the back panel of the machine to check these items. You may be able to lubricate the tensioner and support roller bearings temporarily, but if they are squeaking, they may be failing.
Dec 10, 2009 | Dishwashers
Maytag 3000 series dryer, coins stuck in dryer fin
open the top of the dryer. slide the belt down to the power unit. of course you shoudl always unplug the unit first before removing the cover. carefully lift up ont he drum and they shoudl fall out. carefull y palce the drum back and the belt. replace the cover and plug in to see if that works.
Dec 04, 2009 | Televison & Video
800-462-9824
May 11, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Mar 23, 2009 | Maytag PYE2300AY Electric Dryer
if replacing the rollers didn't fix the squeak, you need to replace the teflon drum slides and drum gasket material. mine sqalled so much it would run you out of the room. now it's quiet.
Jan 19, 2009 | Whirlpool LER5636P Electric Dryer
Dryers Logo
181 people viewed this question
Top Dryers Experts
