Question about Craftsman Garden
Lawm mower blade adapter removal
The blade adapter on my craftman model #917.377540 is stuck. I have tried hitting it with a lead hammer to loosen it. Also tried using a 3 jaw puller and still nothing. On my other craftsman mowers they always slide right off. Am I doing something wrong here? I need to remove it to take off the drive belt cover and change the belt. Please help!
  • 376 Answers
I use a two jaw puller to take them off. Screw the blade bolt partially back in the hole so not to damage the threads, hook jaws on each side and they always come off. Penetrating oil could help.
Posted on May 20, 2009
When going over deep grass there is a metal sound. It's like the blade is hitting against something. Is this a common problem with this model? How could I fix this issue?
Hi Andrew:
It is quite possible that the blade is bent or the metal "grass discharge guide" has been damaged.
If you have a pickup truck handy and you can put the mower facing outward on the tailgate, this procedure is easier.
- remove the spark plug lead to ensure that the mower cannot accidentally start.
- Push the handle down so that the mower is tilted back and the underside of the cutting deck is exposed.
- slowly rotate the blade and see where it contacts (or has been contacting any metal parts.
- remove and replace the blade if it has been bent. (They can be straightened but it is not recommended)
- Use 2 hammers (one as a "dolly") to straighten or repair any bent sheet metal.
- Replace the plug lead and go cut grass.
Cheers
Apr 27, 2016 | Garden
Remove pulley from mower deck blade shafts
take belts off, loosen big nut on top of shaft, leave that big nut on the shaft just a few threads then take a hammer and tap on that nut to loosen the shaft from the bearings, take nut off then the shaft should fall out, if your bottom bearing is stuck on the shaft itself its gunna be fun to take that off, but if it didn't get stuck then take a punch and hammer to the bearings go thru the top to get the bottom one and vice versa, your gunna need a hammer for most of it, hope this helps its not that hard
May 20, 2015 | Garden
Rough sound coming from gas lawm mower on start up
Sounds like the blade is hitting the inside of your deck. Look under mower and I believe you will find area where blade is hitting deck . GOOD LUCK FRIEND.
Sep 12, 2014 | Briggs & Stratton Garden
Blade won,t turn
hey john bruce . what type of mower . there could be many reason . there blade clutch there a cable you have to hold down to start the mower could be causing it not to turn or the engine could be seized if so remove the oil ffrom the mower remove the spark plug tie spark plug wire away from any metal . get some :PBblast or trans fliud pour a cap ful down the spark plug hole leave the mower ( if small one vertical for1-2 days if there a blade clutch tie up with shoe lace to handle remove blade or use chnk of wood and big hammer hit the wood to see it blade will move if does try again the allow fliud in spark pug hole to loosen the blind ( understand when that blde may loosen and the mower may run it will smoke badly do not run on fast and after it run and hopefully loosen up change oil and good luck . i been in the lawn maintenance and repair for 43 yrs . if it work you may get a shorter life out of the mower of maybe not bruce
Dec 02, 2013 | Garden
How to remove stuck blade bolt on MTD Mower model 449
Jeff:
First make sure that you are loosening the blade bolt (Are you turning it in the right direction?) Turn the mower on it's side and lodge a piece of wood between the blade and the body of the machine and really crank on that wrench. The blade bolt is probably rusted in the crankshaft.
Mar 16, 2013 | Yard Machines 11A54MC006 21Inch 139cc MTD...
How to change drive belt on crafsman platinum model 944360080
since i dont see a drive from the front of the mower and i no its a rear wheel drive, usually u will see a belt system in the back above the deck. flip the mower over and u should see the belt going from the rear to the cutting blade. U Have to remove the blade and then with a hammer or mallet hit the spindle that sits above the blade not to hard! just enough to shock it a bit until it loosens and comes off, from there it shouldnt be to hard.
hope this helps
May 31, 2012 | Garden
Cannot loosen or tighten a loose impeller blade bolt on a ryobi leaf blower, rgbv3100
After taking the housing apart grab the opposite end of the impeller shaft with a good set of channel locks (my old standbys weren't sharp enough). Then while holding it tightly hit the old impeller blade with some sharp raps with a hammer, knocking the blade loose (hit the blade at a tangent, it loosens to the left like a regular nut and bolt). Once the impeller is loosened it can be unscrewed by hand and replaced.
Nov 09, 2010 | Garden
Trying to change belt for push mower , cant figure out how to get it off shaft , plastic guard off shaft , this belt is for the self propelled front wheels
If you have a large enough work bench it will make this a lot easier to do but it can be accomplished on the ground.
Lay your mower back on its handle bar and brace it with something heavy enough to hold it in place. This will keep your oil from running out into the air filter and/or into the cylinder as opposed to turning it over on its side.
Spray a bit of good penetrating oil around the shaft ABOVE the blade adapter and let it soak for a bit.
Remove the bolt holding the blade to the blade adapter then using a small hammer, gently tap downward on the blade adapter as you pull on it at the same time. Avoid striking it with enough force to break it. They usually slip off with just a little bit of effort.
Now you should be able to remove the plastic belt guard from the shaft and access the belt.
If you can't work it off the shaft pulley, remove it from the transmission pulley first. You will also need to remove the cover from the top side of the mower in order to replace the belt.
You didn't give a model number so I don't know if there are any screws securing the bottom guard but most of them just sit there on top of the blade adapter and slide into a cut-out area of the deck
Oct 24, 2009 | Craftsman Garden
How to remove old and install new blade adapter (753-0609)model 759 on MTD mower--
Remove the blade bolt and blade, slide the adapter off the crankshaft. If it will not slide off, spray it with a good penetrating oil and let is soak for a bit then take a SMALL hammer and gently tap on the sides of it while pulling at the same time
Sep 07, 2009 | Mtd 22" White Outdoor Self Propelled High...
HOW TO REMOVE MTD BLADE ADAPTER AND INSTALL NEW BLADE ADAPTER KIT 753-0609 on shaft for 21 in. MTD model 759 mower?
Remove the blade bolt and blade, slide the adapter off the crankshaft. If it will not slide off, spray it with a good penetrating oil and let is soak for a bit then take a SMALL hammer and gently tap on the sides of it while pulling at the same time. Slide the new one back on and repklace blade and bolt(s)
Sep 07, 2009 | Garden
Garden Logo
1,276 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
