Question about Konica Minolta Bizhub C364 Color Copier / Printer / Scanner
Tray 3 cannot connect
It will not allow me to print from tray 3
  • Konica Minolta Master
  • 1,297 Answers
Pull out the tray and verify the motor and the sensors.If the tray indicated paper empty change the paper sensor.
Posted on Jan 02, 2014
Canon imageRunner C5180i Color Copier will not allow multi tray
XP? or similar then go to printers list and double click on the Canon 5180. Then click "Printer" then "Properties" then "Accessories"
Make sure on the options listing that the tray 3 and tray 4 are "installed" or their boxes are checked. This is the only thing I have ever seen cause you not to be able to access certain trays or other options.
Good Luck
Nov 17, 2009 | Canon imageRUNNER C5180i Color Copier
Do not see tray 4 in my print menu only tray 1 and tray 2
Hello sir; Do you see the tray 3 ,if did not see tray 3 as well, you better check the connector behind the machine, see there is connect property.
Aug 14, 2009 | Sharp MX-2700N Color Copier
I can't print from tray 2 or 3 from either Mac or PC
You need to remove the trys affected, most likely there is a sensor issue.
Remove the trays and check behind them as paper sometimes falls behind blocking the sensors. If so, remove the paper.
Also, check the paper slides in the tray themselves, remove the paper and slide them in and out all the way, put the trays back in the machine and put the paper back in the tray moving the slides right up against the paper and close the door. It should work normally from now on, if not try a reboot one more time.
Mar 26, 2009 | Xerox Phaser 7700DX Laser Printer
Hi, I would like to print on Transparency paper, but it will not allow me, what am I doing incorrect please . does it go into the photo tray or paper Tray ? Regards Ellen
Hi
First of all, are you working with a laser printer or inkjet? if it is laser make sure that you have the correct transparency, IT MUST BE HEAT RESISTANT! if it is not,u'll end up buying a new fuser unit. then...
1. Put the transparency in your MP tray
2. When selecting "print" click on properties and select your MP tray as your source,
3. Select Transparency for you media type.
after doing this you will be able to print your transparencies.
I hope it helps
Kind regards
Yolande
Mar 04, 2009 | HP Photosmart C7180 All-In-One InkJet...
I cannot get it to print from tray 2 automatically
choose the 2nd paper tray by entering PRINTING PREFERENCES when you are in the print driver Good luck
Feb 02, 2009 | HP LaserJet 5200tn Printer
Paper jam!!
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
put the cables back and switch on
Aug 25, 2008 | Brother HL-2070N Laser Printer
Xerox 8560MFP won't print first page from one tray and rest from another
Microsoft word overides the print driver for page choice. Choose from within word File | Page Setup | Paper.
Tray one on this printer is the manual feed tray. tray 2 is the first drawer.
Ensure the printer driver is set up for the additional trays
Jul 02, 2008 | Xerox Phaser 8560MFP Laser Printer
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
Konica Minolta Bizhub C364 Color Copier / Printer / Scanner Logo
108 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
