Question about HP Officejet Pro X576dw Multifunction Printer
The touchscreen display is flashing printer error when I try to print!
I am trying to print a document and the display screen will flash error and ask that I shut down the printer. Please help!
4 Suggested Answers
technotech
  • 183 Answers
SOURCE: Printer is online and says ready but won't even attempt to print
Click on Start,
Go to Control Panel,
open Printer and Faxes
look for the Printer which is HP C5280 or any icon related to same,
Right click
Choose set as default
Close Everything
Shutdown your computer and Printer
Check and make sure that the USB cable is connected propely
Restart the Printer first and then the computer,try Printing some thing.
if this doesnt resolve you issue then i would suggest you to uninstall the printer software and reinstall and update it from HP.com.
Please let me know about the resolution
Posted on Nov 01, 2008
sgoswami
  • 114 Answers
SOURCE: printer won't print error message remove and check right cartridg
Take out the power cable from the back of the printer keep on tapping the power button for 30 secs ; then plug it back.
Take out the catridges clean them with a Lint free cloth (copper contacts); also clean the catridge slot of the printer; put in back the catridges ;
Unplug the power cable from the back of the printer; press and hol down the (#) and the (6) button simultaneously with one hand and with the other hand put in back the power cable; and then release the (#) and (6) button;
It will perform a reset on the printer
IF still then it doesn't work then the catridge slot's copper contacts has gone bad and need to replace
Posted on Sep 16, 2009
edmacias
  • 70 Answers
SOURCE: Deleting paused and frozen there. Cannot use the
it seems you might need to rest teh PC..
Once you have done that and assuming you are running windows pls do the following (while the printer is OFF)
1. Go to "Start", "Run"
2. Type: CMD
3. press "Enter"
(now you should be in a DOS terminal window)
4. type: net stop spooler
press "enter"
5. type: net start spooler
press "enter"
6. type: exit
press enter
Turn on the printer...you should be clear now :)
Cheers,
Ed
(If this works for you, please grade this response)
Posted on Nov 07, 2009
Hi please help? My HP all in one deskjet f380 only prints certain documents, It starts as if its going to print, moving back and forth and then just stops and nothing is printed. The print job dissapears...
Try if one of these solutions help you.
1. Shut down you printer, wait a few seconds, start it again and try to see if you document is printing.
2. Install the printer again on your computer. This time, if possible use an other USB port.
3. If you can print PDF, you can try http://www.freepdfconvert.com/ and print your document after you mad a PDF.
Jul 07, 2011 | Office Equipment & Supplies
Was printing labels and the feeder pulled the page through crooked so it jammed. I pulled the paper out, it ripped, I opened the printer and got the remaining peices out and shut off the printer. When I...
ALthough you didnt give the model of the printer this has helped reset it on other epson printers.
unplug the printer from both USB and Power.
Hold down power button and then plug in the printer while the power is held down.
if this doesn't do it try holding down the paper button and the power, while plugging in. since this can be tricky, plug it into a power strip so you can power off and on easily. This is a help at the bottom for a R220 that mentions somthing similar.
http://files.support.epson.com/htmldocs/pho22_/pho22_rf/parts_1.htm
Mar 11, 2011 | Epson Office Equipment & Supplies
Canon MP510 wont print. Error message B300 or
May I know the exact error messages in the printer screen. If it's green and yellow lights that are flashing you need to push more the two cartridges that you replace....also try to clean it using the printer program installed in your computer....good luck and hope it will help....
Mar 31, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Hi I have a kyocera C5015Nand it keeps telling me to load MP 4 try can you help please
to get the print press down arrow key it will show use alternative paper ? in display then press two times enter key it will print.............
its is the problem with the document page setting which one you giving print .......... its shows because its asking the paper according the document page setting ..........
Oct 17, 2009 | Kyocera Mita FS 3800 Laser Printer
Document wont print
It could be a hardware issue.
Check first if the printer is working fine. Keep on holding down the paper button while you turn the printer on. Let go of the paper button when the power light starts to flash. if it printed out a color test pattern successfully, check if you are using the corrrect driver.
Tell me more if you need assistance in trashing and re-installing the proper driver for your printer. Include the full version of the operating system you are using too.
Goodluck.
sherlyn c.
May 23, 2009 | Epson Stylus C66 Photo InkJet Printer
Printer stopped printing durring project "Assert Error b52b00b4"
From the HP website:
ISSUE: The printer displays an assert error code. Assert error codes indicate that the printer has an internal condition that may respond to a hard reset of the printer. Beyond that, service may be required. This document applies to the following products:
  • HP Photosmart p1000/1000, p1000xi printers
  • HP Photosmart p1100, p1100xi printers
  • HP Photosmart 1115 Printer
  • HP Photosmart 1215, 1215vm, 1218, and 1218xi printers
  • HP Photosmart 1315 Printer
SOLUTION: Hard reset of the printer A hard reset of the printer may clear the error. Here is how to perform the hard reset:
  1. Shut down the computer.
  2. Open the top cover of the printer and remove the print cartridges.
  3. Close the top cover of the printer.
  4. Press the power button on the printer to turn the printer off.
  5. Disconnect the communications, (USB or Parallel), cable from the back of the printer.
  6. Disconnect the power cord from the back of the printer for one minute.
  7. Reconnect the communications cable to the printer.
  8. Reconnect the power cable to the printer.
  9. Press the printer power button to turn the printer on.
  10. Open the top cover and reinsert the print cartridges.
  11. Close the top cover and print the calibration page.
  12. Restart the computer.
Mar 18, 2009 | HP PhotoSmart 1115 InkJet Printer
Problem getting hp deskjet 6540 inkjet printer to print
shut down the printer and computer both then on only the pc and cancel allthe pending documents from it then again shut down your pc check allthe wires connected properly then on both printer and pc.it will work properly.feel free for further assistance.
Aug 08, 2008 | HP DeskJet 6540 InkJet Printer
INK SYSTEM FAILURE Ink system has failed. Unable to copy, receive faxes or print. Refer to printer documentation. error: 0xc19a0013 Press OK This is the error in which I am receiving and I need to...
Try the following reset:
Hold the OK and the Help button at the same time. While holding them down, plug the power in. Continue to hold both buttons until the unit shut off.
After shutting down, release both buttons and power on the printer.
Alternatively follow instructions on this document from HP.
May 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
Error message
Hi, i think that You must to upgrade printing system firmware.
Call support or service and ask informations about that,i thin that is not expensive.
Nov 21, 2007 | Kyocera Mita KM-3035 All-In-One Laser...
HP Officejet Pro X576dw Multifunction Printer Logo
121 people viewed this question
Seeker5211
Seeker5211
