Print head alignment on Gerber Cat UV
The Magenta 2 print will not align using the Calibration page that is provided on at Gerber. I have run a horizontal print test and put in values for unidirectional and bi directional and only the Magenta 1 print head will align.
SOURCE: Horizontal stripes on images
I tried even to exchange my printhead and it did not help.. The service said its a printers problem not the ink or printhead.. but they did not came up with a solution :C
Posted on Apr 30, 2008
jigsawbill
  • 398 Answers
SOURCE: Printer not aligned
Hurry, Hurry, and contact hp support, You have only one year warranty.
Posted on Aug 05, 2008
SOURCE: magenta won't print have done deep
It sounds like your print head my be blocked. On some printers they come with the cartridge, my canon has separate print head that can be replaced.
Posted on Jan 24, 2009
yooperbud
  • 8637 Answers
SOURCE: HP Business Inkjet 1200 printer always prints the Alignment Page
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 29, 2009
  • 214 Answers
SOURCE: Print Head Alignment test produces only a blank page.
Yes head probably clogged. You can try cleaning head multiple times, I think this is a pigment ink machine, so get only these carts for it
Posted on Apr 25, 2009
Installed new ink. it says out of alenment
Dennis: According to an old FixYa.com, urbanhookupz said: "You need to run a printer alignment page like you do when you put in new cartridges.
unplug your printer plug it back in.
open door and take out print ink cartridges.
put them back in and then close the door.
It should now prompt you to do a test alignment page.
now try and print it should solve the problem.
if it does not prompt you to do a test page
Aligning the Print Head
This operation must be carried out when using the printer for the first time.
Aligning the
Print Head positions allows you to print without shifts in the color registration.
Print head alignment is performed either automatically or manually. This section deals with
automatic Print Head alignment only.
?? Ensure that the Inner Cover is closed.
?? The Print Head can also be aligned from the printer itself.
1.With the printer on, load a sheet of Letter-sized plain paper in the Sheet
Feeder.
2. Hold down the RESUME/CANCEL button until the POWER lamp flashes four
times.
1 With the printer on, load a sheet of Letter-sized plain paper in the Sheet
Feeder.
2 Open the Printer Properties dialog box.
See "Opening the Printer Properties Dialog Box Directly from the Start Menu" on
page 28.
3 Print the pattern.
(1) Click the Maintenance tab.
(2) Click Print Head Alignment."
May 26, 2015 | Canon MX340 AllInOne InkJet Printer
My HP Photosmart c7280 will not print pink or magenta. How can I fix this issue?
Sounds very much like you have a clogged printer head you should run the deep clean procedure form the printer dialog. If that does not fix the issue you may need to replace the print head.
Jan 28, 2015 | HP Photosmart C7280 All-in-One Printer
Alignment failed when run
If Printer heads health condition is not good, alignment wont completes..
Four individual cartridges & Two print heads, each print head prints two colors.. Black& Yellow, Cyan & Magenta.. Verify which color is not printing properly(Color missing Or white bands)..
Perform 2 or 3 times print head cleaning through printer menu..Try for alignment.. If success end.. if no, replace the print head which is not printing properly.. Before replacing the printer head ensure that cartridge ink should be above 30%...
Oct 07, 2012 | HP Officejet Pro L7680 All-In-One Printer
HP C6180 all in one printer My printer will not print light magenta and magenta, all the other colours are fine. Tried everything Any suggestions Thanks Paul
This problem seems to be with the printheads of the printer If magenta ink cartridge has enough ink inside it and if print heads are damaged then you need to replace this printer.....
But still if u want you can follow the below mentioned steps :
If it is not printing in light magenta and magenta than you can try the below mentioned steps :
Step 1 - First clean print heads from the menu of the printer. You can look for clean printhead option under printers menu - Tools - Clean Print Heads.
Now print and see if it is printing or not. If issue is not resolved then move on
Step 2 - Check if your magenta ink cartridge & Light magenta ink cartridge has ink in it or not...if it is empty or if has very low ink then.....
replace it with a new ink cartridge......and now it is going to aling the printer....While it aligns it is going to make noise and will show a message printer aligning or alignment in process.
While it aligns dont touch the keys of the printer or dont interrupt in between the process otherwise hardware of printer might get damaged and you have to replace the whole printer
...and just wait...till the printer display shows the regular menu...
Note : - * During Alignment printer is going to consume more ink, so make sure you have enough ink in all the cartridges or otherwise it does not have enough ink in it
alignment process will not be completed properly.
Steps 3 - If it prints an alignement page then it is ok, check if all the colours on the alignment page and if all the colours are fine then ur issue is resolved...
for verifying you can print another document.If it does not print any alignment page then you can try printing an alignment page from the printers manually from the printers menu.
Now if it has resolved the issue then it is fine or else last you can try re-setting the printer.
Re-Setting the printer :
- Press and hold the "*" key.
- Press the "#" key and release both keys.
- Display should say "Enter Special Key Combo" then release the keys and press "1", "2" and "3" buttons in sequence.
- then you will get few options, now look for an option that says System Information or System Menu
- Press "OK" on System menu and look for an option Semi full re-set
- Press "OK" Button.Now printer will shutdown automatically and will turn on automatically after few seconds..as it is going to align the printer..
- Now it will make noise for few minutes wait till then and when you see regular screen on display then print a document and see if issue is resolved or not.
If issue is not resolved then you need to replace the printer. If it is in warranty then contact Hp customer care and they will replace it for free.
Feb 25, 2011 | HP Photosmart C6180 All-In-One InkJet...
I need to calibrate my hp deskjet 3845 but when I click the button to calibrate it says it's lost communication with the device
Hello
Calibration is one of the functions performed from the Printer Assistant icon on the desktop. If the Printer Assistant icon on the desktop has been deleted from the system, the same tasks can also be accomplished from the Printer Toolbox . The Printer Toolbox can be accessed through the Printer Folder or by right-clicking the Printer Icon on the Taskbar
Please follow these steps to calibrate your printer
Double-click the Printer Assistant icon on the desktop. The Printer Assistant menu will appear with a list of options
Select the Tools and Updates option or the Utilities option (depending on your driver version).
Printer Maintenance menu will appear.
Select the Calibrate Printer tab from the Printer Maintenance options
Click the Calibrate tab. The printer will print the first calibration page.
In the Cartridge alignment page, please inspect the straight colored lines in Sections A, B, C and D . Choose the straightest lines in each section to indicate the best cartridge alignment.
In the Page alignment area, please verify Section E . Then, select the bar and the arrow closest to the edge of the page without being cut off, to indicate the best page alignment.
In the Calibrate Device window, enter the selected alignment values in the Pen Alignment and in the Page Alignment fields and click the Continue tab
The second calibration page will be printed now. The page will contain two patterns: a square and a cross . The lines on the patterns should be horizontally and vertically aligned . Click the Done tab if the lines are correct or the Calibrate tab to repeat the calibration process
The first calibration page contains five sets of alignment patterns. The calibration will cover two areas of alignment. The Cartridge alignment is designed to obtain the best print quality and the Page alignment is designed to ensure that the print is aligned correctly on the page.
If the Printer Assistant and its files have been deleted from the system, the maintenance features in the Tools and Updates section of the Printer Assistant are also available in the Printer Toolbox .
Open the Printer Toolbox and perform the services by following the instructions below:
Right-click the Printer Icon on the Taskbar .
Click Open the Deskjet Toolbox option.
Select the Printing Service tab in the Printer Toolbox .
Choose the Calibrate the printer option.
NOTE:HP recommends to use HP plain paper when performing the cartridges calibration process.
NOTE:These printers could work with one or two print cartridges. HP recommends to perform the cartridge calibration process with the two cartridges installed in order to get the best print quality. Anyway, the printer can also be calibrated with one cartridge installed if the customer decides to work in that way.
Jan 16, 2011 | HP Deskjet 3845 InkJet Printer
HP Designjet 500, I have replaced the black print head twice, the first new print head would align and then fail the color calibration, the second new head aligns and pass's color calibration, but when I...
it seems there r some air in ur ink tube *** inser the priming heads & done the priming & reinstall the print heads if problem not resolved replace the carridge assembly,,,,,,,,,
Jun 03, 2010 | HP DesignJet 500ps (42 in.) InkJet Printer
Printing is offset
you need to run a printer alignment page like you do when you put in new cartridges.
Aligning the
􀁺 Ensure that the Inner Cover is closed.
􀁺 The Print Head can also be aligned from the printer itself.
Feeder.
times.
Feeder.
See “Opening the Printer Properties Dialog Box Directly from the Start Menu” on
page 28.
remember if my answer was of assistance please leave a positive rating and a testimonial.. THanks Good luck
Mar 28, 2010 | Canon Pixma iP3000 All-In-One InkJet...
Printer keeps showing Office Jet 8500 Wireless
The printer wants to align the print cartridge, if you print out the alignment sheet, and then following instruction, place on scanner and scan it in etc, and it fails to callibrate, I have found it is because some of the information on the calibration page is not being printed correctly so therefore machine cant calibrate the print heads from it, this is normally due to poor quality cartridges or failing/empty print cartridge or cartridges, these use two I think, and I bet one of the colours from the colour isn't printing properly, replace colour cart if blacks look good. Below is a link to HP so you can see what a alignment page needs to look like to pass calibration, compare yours and you may find a colour is dodgy on it.
see HP's support information
Nov 12, 2009 | HP OfficeJet 7310 All-In-One InkJet...
HP 2210, screen says to press enter to aling cartridges
Once you replace a cartridge on a 2210 ya page prints and you must put that page on the scanner window and then press enter. Your computer will go through a calibration to align the print head. once this is done you can throw away the paper and printing will be normal
May 27, 2009 | HP PSC 2210 All-In-One InkJet Printer
47 people viewed this question
jasbo
jasbo
