Question about Griffin Technology Evolve Wireless Sound System for Apple iPod - High-Gloss Black
When removing speakers there is a clicking sound and will not play
When I remove the speakers from the base unit, there is a click sound and the speakers do not play. If I'm lucky to pick up the speaker from the base unit and it does not click, then the speaker will play otherwise when it clicks, they will not play.
Magicjack and a usb handset device from tigerjet are suddenly in my computer's speaker mixers. now I get no sound through my computers speaker, however that sound is coming through my telephone speaker...
I am assuming you are on a windows machine.
Right click on the speaker icon (volume control icon) normally located near the time lower right hand corner of the task bar. When you right click a sub-menu should pop up.
Select "Playback devices" and then select the "Speakers" option you wish the sound to play back on.
Hope this helps.
Sep 07, 2013 | Computers & Internet
No sound
Audio is intergrated in most of the programs on a Windows XP-based laptop computer, especially those that play video games and movies. If the audio is not functioning properly, you need to troubleshoot the issue. Typically, this is a quick process that requires only a few different system checks to correct the problem.
1. Double-click the speaker icon in the lower right corner of the desktop. A window appears with all of the audio features. Make sure none of these are muted (uncheck the "Mute" box if you find some are), then turn up the audio on the different features. This ensures the audio is not turned down so you are unable to hear it.
2. Look to see if you have any headsets connected to the laptop. If there is something connected to the "Line Out" port of the laptop, no audio is going to play through the systems speakers.
3. Check that you have the laptop speakers selected as the device creating the audio for the Windows XP laptop. Click "Start," "Control Panel," then "Sound." Make sure the laptop speakers are selected (if not, click the audio playback pull-down menu and choose the laptop speakers), then click "Apply."
4. Download the drivers for the Windows XP laptop. If the drivers have been removed from the system, the computer is unable to produce any audio. Navigate to the laptop's manufacturing site, then choose "Support," "Downloads and Drivers," then enter in the model number of your computer, select "Windows XP" as the operating system, then choose the "Audio Driver" download. Once the drivers have finished downloading, double-click the file, follow the installation prompts of the driver wizard and click "Install" to install the driver. Once complete the laptop computer is ready to begin playing audio again.
I hope you find it very helpful. Best regards.
Aug 16, 2011 | Packard Bell Easy One II 3136 Notebook
I can't play music., beacause i removed my sound or audio device., how am i going to fix this!??
As you have not mentioned the Make/ Model of the motherboard/ PC, I cannot send you the direct link. But, in case you dont have the drivers - Dont worry, you can download the drivers from the internet for free. It requires a bit of googling or you can search the official support site of the motherboard /PC manufacturer. E.g. www.intel.com, www.hp.com, etc. Search for the model of the Motherboard/ PC you have, select the Operating System (OS) and download the required drivers.
Hope it helps! Good Luck!
CreativeTECH
Apr 12, 2011 | Microsoft Windows XP Professional for PC
Not working turns on, no sound, the stand by/on light goes on and I hear the unit amp click on but no sound. I tested the internal fuse for continuity and it was good, however I dont know how to check if...
hi,
first of all remove the speaker and check it, is it faulty or not. connect a battery between the two leads of the speaker .if it is ok then it will produce some cracking sound. check it first.
ok
Dec 27, 2010 | Yamaha YST-SW215 Subwoofer
My speakers were on but would not play any sound. I removed the fuse and then put it back in and now the speakers will not turn on
put you fuse back correctly and check fuse is ok or not and install your sound driver's if they are installed so go to control panel and then go to sound option and click on advance and chose your speaker like 5.1,4.1 or any other you know which 1 and then click apply and then check your sound that's all
Nov 18, 2009 | Audio Players & Recorders
I HAVE NO SOUND ON MY GATEWAY GT5660E. i HAVE TRIED EVERYTHING
Do you have the speakers plugged into the correct plugs in the sound card? Make sure speakers are not plugged into the mike jack. Do you hear any static as you remove and replug the jacks? Do the speakers have a power light?
Open Control Panel ->Sounds and click on Sounds tab. Do any sounds play? Click on the Audio tab and make sure Default device is your sound card. Click on Volume tab and then Advanced. Make sure nothing is muted.
Assuming you have Windows, check the sound card in Control Panel->System, Hardware, Device Manager. Check for correct drivers. If necessary, uninstall sound card and let Windows detect it again and install drivers.
Sep 16, 2008 | Audio Players & Recorders
I have gateway boston digital BA735 on a dell dimension 3000 with soundMAX integrated digital audio sound card but get no sound from speakers. What can i do to get speakers to work?
we have to check whether the issue with speakers or in sound card..just remove the audio jack from computr and touch the jack with ur fingers..u shuld hear some noise in speakers..if u can able to hear that speakerrs are fine and the issue with the sound card..do reply
Jun 17, 2008 | Computers & Internet
JBL OnStage - faulty connection
According to the user guide the clicking sound seggests a fault with the powersupply.
Apr 29, 2007 | JBL OnTour Portable Music Box for iPod...
Griffin Technology Evolve Wireless Sound System for Apple iPod - High-Gloss Black Logo
35 people viewed this question
Top Griffin Technology Audio Players & Recorders Experts
Gary
Gary
Are you a Griffin Technology Audio Player and Recorder Expert? Answer questions, earn points and help others
